Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of August 2008 (Fri)   #1
ryandavid__
ryandavid__'s Avatar
Default Octobox purchase in UK:
What are my options? I can't find any large ones - I want around 50inch.
ryandavid__ is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #2
Faolan
Faolan's Avatar
Default Re: Octobox purchase in UK:
What's your lights? If it's Elinchrom you can get the Octa-Midi at 53" other than that I'm not sure.
Faolan is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #3
ryandavid__
I haven't bought the heads yet, so any will do. Thanks for the suggestion.
Old 15th of August 2008 (Fri)   #4
Phil V
Lastolite Umbrellabox starts at 60" and has a universal fitting for various flash heads (including flashguns).
Phil V is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #5
Rudi
Rudi's Avatar
I love my 53" Octa Midi from Elinchrom.
• Wedding Photographer - Sydney and Wollongong
• Borrowed Moment (blog)
Life is uncertain. Eat dessert first.
Rudi is offline   Reply With Quote
Old 16th of August 2008 (Sat)   #6
Chris L
Chris L's Avatar
Try The Flash Centre. They carry the Elinchrom range and list a few Octoboxes:-
66" Here
53" Here
39" Here
I've used their Leeds store a few times as has a work colleague and we've both found them very helpful
Canon G12 | Mamiya RZ67 ProII | Rolleicord IV | Canon 540EZ | Yongnou YN560
Chris L is offline   Reply With Quote
Old 16th of August 2008 (Sat)   #7
Chris L
Chris L's Avatar
Bowens also do a 150cm Octobox here or if these are a little too pricey you could get a 47" Interfit Pro Octobox from here
Old 16th of August 2008 (Sat)   #8
Rudi
Rudi's Avatar
66" Here
It's actually 190cm, or just under 75".
Old 16th of August 2008 (Sat)   #9
Hermes
Manufacturers usually measure softboxes from corner to corner to make them sound larger.
Hermes is offline   Reply With Quote
Old 16th of August 2008 (Sat)   #10
Chris L
Chris L's Avatar
Yeah, mixing up my units and base.
The website listed it as 197cm which I worked out to be 77" which I then divided by 12 to get the measurement in feet )6.46). I then forgot to multiply the .46 by 12 to get the inches and just rounded it up and thought...hmm 6'6" which I then typed out as 66"... I think I need to give my brain a little more time to wake up!
Old 16th of August 2008 (Sat)   #11
TeeJay
TeeJay's Avatar
try www.photodeals.co.uk they may have something to suit. Don't worry too much if an item shows as out of stock - just email them with your requirements.
Most importantly, I have purchased several items from them; stands, octabox, flash heads etc and have found them really nice and helpful people to deal with.
TJ
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea
TeeJay is offline   Reply With Quote
Old 16th of August 2008 (Sat)   #12
Rudi
Rudi's Avatar
Yep, and a 75" Octa is STILL gonna be larger than a 66" Octa, even if they measure them that way.
Old 17th of August 2008 (Sun)   #13
Hermes
Just saying that the Octa does actually measure 197cm if you use their method.
Old 17th of August 2008 (Sun)   #14
Rudi
Rudi's Avatar
Aaaah, understood! The thing's HUGE!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sunpack octobox kobe629 Small Flash and Studio Lighting 0 19th of May 2008 (Mon) 18:25
Octobox as beauty dish? AginKajun Small Flash and Studio Lighting 1 24th of April 2008 (Thu) 13:47
softbox/octobox curcun Small Flash and Studio Lighting 0 7th of March 2008 (Fri) 17:30
Softbox/Octobox for Speedlight bcap Small Flash and Studio Lighting 3 15th of July 2007 (Sun) 10:56
Help! Softbox or octobox owners canon_user808 The POTN Lounge 5 17th of November 2004 (Wed) 11:52
