Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 15th of August 2008 (Fri)   #1
Twitch1977
Twitch1977's Avatar
Default One Lightroom Catalog For Two Computers
I have a computer and a laptop at home and I want to use one Lightroom Catalog between the two.
Right now my lightroom catalog is on my PC but when I try and access it on my laptop it gives and error saying it's on a network volume.
What are the rest of you doing to solve this problem? I could throw it on an external drive but I don't really want to have to run upstairs to get it when I feel like working on it downstairs and vice versa. If there's a way to get it working over the network that'd be preferable.
Thanks,
Kurt
http://www.flickr.com/photos/twitch1977/
Advice is a noun, advise is a verb.
Twitch1977 is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #2
SolidxSnake
SolidxSnake's Avatar
Default Re: One Lightroom Catalog For Two Computers
Well you'd have to make sure all of your images are available on network as well I'd assume.
That said, make sure the images and catalog are in a shared folder with 100% permissions to guests (ie. your laptop).
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART ~ My Heatware
SolidxSnake is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #3
Nortelbert
Nortelbert's Avatar
I put it on the server and share the catalog out. Each PC has a local copy of the same database because it syncs itself every xx minutes with some software.
Nortelbert is offline   Reply With Quote
Old 15th of August 2008 (Fri)   #4
Twitch1977
Twitch1977's Avatar
This is how I have it set up, it seems like LR is designed to balk at using a catalog that's on a network share. Even if I map the drive to a drive letter instead of using a UNC path I still get the same error.
Can you elaborate on this a bit please?
Kurt
Old 15th of August 2008 (Fri)   #5
SolidxSnake
Kurt
Hmm, then I guess nortelbert's idea is the best. He has a common fileserver that always has the latest catalog. All of the computers sync every xx minutes, so they also have the latest catalog. When they sync, they overwrite the older catalog on said computer with the updated one on the fileserver so both computers have the same catalog at all times (at least all times after a sync and before any editing )
1) RTFM.
2) Repeat Step 1.
Old 15th of August 2008 (Fri)   #6
Nortelbert
Nortelbert's Avatar
You got it ... except the catalog can't be on the server initially, so you start with one on your local machine, then sync it to the server, which can serve it out to the other PCs.
Old 15th of August 2008 (Fri)   #7
SolidxSnake
Well, you could have a combo work PC/fileserver... chances are you wouldn't want to take the performance hit of working on a computer running a fileserver, however.
1) RTFM.
2) Repeat Step 1.
Old 15th of August 2008 (Fri)   #8
Nortelbert
Nortelbert's Avatar
Kurt
Set up all your files on PC "A" and share the folder. Run Lightroom on PC "B" and point it to the files on "A" to get the files. This creates a local catalog on "B". You can then copy this catalog file to PC "A" again if you do edits on PC "B" and vice versa.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
maintaining a lightroom library on multiple computers? producerism RAW, Post Processing and Printing 5 13th of February 2008 (Wed) 13:08
Lightroom on 2 computers, sync back up to 1 RedHotLama RAW, Post Processing and Printing 2 3rd of February 2008 (Sun) 19:47
Installing Lightroom on Multiple Computers? JoeW RAW, Post Processing and Printing 10 28th of November 2007 (Wed) 09:10
lightroom catalog widgetrich RAW, Post Processing and Printing 4 13th of July 2007 (Fri) 12:40
Lightroom DB on Multiple Computers Mario. RAW, Post Processing and Printing 5 30th of May 2007 (Wed) 21:03
