Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 20th of August 2008 (Wed)   #1
jgrussell
Looking around nervously
jgrussell's Avatar
Default New PC/Old CS - upgrade path?
I'm about to put in an order for a new PC... and wonder about the right Photoshop upgrade path. I've been using CS on an old W2K Pentium 4 system. I can (a) continue with CS while waiting for CS4; (b) grab PSE6 while waiting for CS4; or (c) upgrade to CS3 and forget about CS4. I'm a pure hobbyist and I have a lot to learn, about both photography and PP, but I'm willing to work at it. What would you recommend for me, and why? Thanks!
-- jgr
blog | gear | my birds
jgrussell is offline   Reply With Quote
Old 20th of August 2008 (Wed)   #2
tim
Light Bringer
tim's Avatar
Default Re: New PC/Old CS - upgrade path?
Can you skip three versions with the adobe upgrade scheme?
CS works fine, all CS3 will give you is newer ACR and more adjustment layers, nothing else makes much difference IMHO.
tim is offline   Reply With Quote
Old 20th of August 2008 (Wed)   #3
jgrussell
jgrussell's Avatar
You can upgrade from PS 7 to CS3 (skipping CS and CS2) so it stands to reason you could upgrade from CS to CS4 (skipping CS2 and CS3). In my case, I'm eligible for academic pricing anyway, so the upgrade pricing is not the issue.
-- jgr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The Path to Nowhere SolidxSnake Wildlife 0 10th of July 2008 (Thu) 01:12
Good Upgrade Path? stefeb Canon EF and EF-S Lenses 15 5th of January 2007 (Fri) 06:32
Sigma EX Upgrade Path? EOSAddict Canon EF and EF-S Lenses 8 8th of July 2005 (Fri) 05:46
Reasonable upgrade Path Primevci Canon EOS Digital Cameras 4 12th of October 2004 (Tue) 15:05
