Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 25th of August 2008 (Mon)   #1
LeuceDeuce
LeuceDeuce's Avatar
Default B&W False Creek Pano
Ok I'm open to any critique, but I'm specifically requesting critique on the black and white conversion. I know it's a little dark, does this work? Should I be trying for more even distributions of tone? I really need help with my black & white photography. Thank you for any responses.
Edit: Removed original from flickr
my website: Light & Shadow
my flickr
LeuceDeuce is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #2
LeuceDeuce
LeuceDeuce's Avatar
Default Re: B&W False Creek Pano
Or should I go for something closer to this, with less contrast and more even tone distribution (I lose a little cloud detail). Possibly combine the sky and ground?
I'm just not sure what the ideal to achieve in b&w is...
_
my flickr
Old 25th of August 2008 (Mon)   #3
LeuceDeuce
LeuceDeuce's Avatar
The mix:
_
my flickr
Old 25th of August 2008 (Mon)   #4
Bill Boehme
Enjoy being spanked
Bill Boehme's Avatar
I vote for #3.
When we were in Vancouver early this summer we noticed that Vancouver seems to be the summer nesting grounds for the elusive Construction Crane. Sightings have become increasingly scarce around here and I was afraid that it might be headed for the endangered species list, but it seems to be alive and prospering in Vancouver.
Click here to help to support POTN operating costs
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill
Bill Boehme is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #5
photoguy6405
photoguy6405's Avatar
The mix. Hands down.
photoguy6405 is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #6
tylershumway
tylershumway's Avatar
I would vote the mix as well. The image really improved when you allowed more midtones (and really less black), a lot of detail was revealed. I think a lot of what black and white photography is, is the balancing of tones. The interactions/transitions of the tonal values with each other really seperates a good b/w from a great b/w. The only thing I would try to change now is the halo on the horizon, its a little distracting.
tylershumway is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #7
Flo
Gimmie Some Lovin
Flo's Avatar
Mix, and I am not seeing a halo
Flo is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #8
LeuceDeuce
LeuceDeuce's Avatar
Appreciate all the comments folks. I kinda figured the mix was the way to go. I didn't like losing the sky in the low contrast version, but the higher contrast sky killed the ground.
Not quite sure about the halo you're seeing though. Not saying it isn't there, I'm just not seeing it. It could be remnents from a quick and dirty layer blend.
my flickr
Old 25th of August 2008 (Mon)   #9
-g-
My vote's for number 3 as well. As a PS guru, I'm sure you've already dodged and burned the clouds.
Flickr-------------------- Facebook-------------------- Web-------------------- Twitter
GENO.CA - Vancouver wedding photographer
-g- is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #10
LeuceDeuce
LeuceDeuce's Avatar
Actually I didn't. I used the Black & White conversion and played with the sliders until I found a nice mix.
I've replaced my flickr photo so the original is no longer available.
On the full size image I'll probably visit it with some dodge & burn to see if I can breath more life into it.
B&W is way harder than colour
my flickr
Old 25th of August 2008 (Mon)   #11
LeuceDeuce
LeuceDeuce's Avatar
Isn't the construction around here crazy? It's so hard to get a nice skyline right now. Once they finish the Olympic Village behind Science World there, the view is going to be something else.
my flickr
Old 25th of August 2008 (Mon)   #12
-g-
Grab Gorman's action for B&W.
http://www.atncentral.com/Zip_Actions/gormanbw.zip
I find I like to change the fill layer to something a little lighter and sometimes play with the curves a bit as well.
Old 25th of August 2008 (Mon)   #13
LeuceDeuce
LeuceDeuce's Avatar
Thanks Geno, I'll give this one a try.
my flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Quarter Moon Over False Creek - And a Question LeuceDeuce Critique Corner 18 9th of August 2008 (Sat) 23:48
Twilight on False Creek LeuceDeuce Critique Corner 15 18th of February 2008 (Mon) 17:51
False Creek Panorama LeuceDeuce Critique Corner 1 19th of January 2008 (Sat) 23:37
Vanouver - False Creek crazyea Nature & Landscapes 6 24th of August 2007 (Fri) 11:28
Telus World of Science (Expo 86) False Creek, BC rwong2k Critique Corner 5 21st of August 2006 (Mon) 23:01
