Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 25th of August 2008 (Mon)   #1
photoguy6405
photoguy6405's Avatar
Default More flowers
photoguy6405 is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #2
Robert_Lay
Robert_Lay's Avatar
Default Re: More flowers
It doesn't work to have significant portions of the foreground out of focus.
Try focusing on the foreground, or take a vantage point where you can put the subject in front of everything else and focus on it.
Bob
Quality of Light, Photo Tool ver 2.0
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
Robert_Lay is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #3
aram535
aram535's Avatar
I find that the selective focus only works when you have a single object in focus that is the opposite of everything else in the frame.
An examples that comes to mind (anyone else know which photograph I am describing? I want to know too - it got me interested in photography): B&W, A homeless man sleeping on the streets of Manhattan, while everyone else walks by - all shoes are out of focus. Street level with the sleeping man being the furthest thing from the lens.
Gear List * www.tranquilphotos.com * My Blog
aram535 is offline   Reply With Quote
Old 25th of August 2008 (Mon)   #4
photoguy6405
I have the opportunity to go back and try again, so I just may do that. I'll try different vantage points as well, but I'm curious, do you think this one would have worked better if the foreground was in focus also?
Old 26th of August 2008 (Tue)   #5
Robert_Lay
Robert_Lay's Avatar
aram535 has a good point. In his view, depth of field (or selective focus) is a tool that can be used by the photographer, and one usage is to draw attention to the object focused upon.
However, selective focus, like selective coloring, can be overdone, and when it is, the objective of that image may fail.
While a somewhat out-of-focus foreground may contribute to 3-dimensionality (good), it may also mar an otherwise interesting image.
If I really want my viewer to appreciate the mid-range elements of the picture, to what extent could I allow his view to be obscured by irrelevant material? Most viewers will sub-consciously react unfavorably to unnecessary obfuscation.
To answer your question, it would change the picture dramatically to have the foreground in focus. The result may or may not be an improvement. We cannot always foresee the results of the change. You have to experiment with it. Thank goodness, we can trash what we don't like with the press of a button and use the file space for another version.
Bob
Old 26th of August 2008 (Tue)   #6
Broncobear
Broncobear's Avatar
I personally think so because the bokeh background of the multi colours would compliment the foreground.
"The real voyage of discovery consists not in seeking new landscapes, but in having new eyes." "Marcel Proust
Gear & Frank's Flickr
Broncobear is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #7
aram535
aram535's Avatar
My attempt at the scene, if possible (assuming its a field) is to raise the point so you can see the top of the last set of flowers. Show depth in the frame by actually showing depth.
Old 26th of August 2008 (Tue)   #8
photoguy6405
I'm thinking the main drawback wasn't necessarily the foreground being OOF itself, but that the OOF portion of the photo is too much. It's dominating and overbearing. In focus may work. OOF, but less dominating may work. I'll experiment. Thanks.
Old 26th of August 2008 (Tue)   #9
Bill Boehme
Enjoy being spanked
Bill Boehme's Avatar
I think that you have a pretty good handle on the situation. Also consider that the large size of the foreground flowers (Celosia 'Plumosa') would present a problem even if it were more nearly in focus.
A solution might involve backing away and elevating the camera more. If you want to maintain approximately the same framing then use a longer focal length. One nice thing that I miss about film SLRs is that I could smoothly vary the DOF with the aperture ring on the lens barrel while DOF preview was locked and then unlock it to adjust exposure with the shutter speed. I would need to become a contortionist and grow at least one extra hand to do this on a digital SLR.
Click here to help to support POTN operating costs
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill
Bill Boehme is offline   Reply With Quote
Old 27th of August 2008 (Wed)   #10
KarlosDaJackal
KarlosDaJackal's Avatar
You could also use that out of focus foreground as a framing tool, if you had just one of those out of focus objects to the left and right, or if you shot it through a gate or something like that. Its not always a bad thing.
But to echo the other guys comments, with this scene it looks better to raise the camera a little bit.
KarlosDaJackal is offline   Reply With Quote
Old 27th of August 2008 (Wed)   #11
fubarhouse
fubarhouse's Avatar
This would be a very wonderful photo, however the flowers out of focus right in front of the camera lens ruin it...
If you wanted the same angle, shoot through a gap between the flowers so you don't get any of them on the photo.
My 0.02c.
Canon 40D, 580EXII, BG-E2N, RS-80N3 (Remote), Velbon Vel-flo 5 PH 248 (Tripod), Velbon RUP-43 (Monopod), Hoya CP Filters
Canon EF 50mm F/1.4 USM Canon EFS 17-85/4.0-5.6 IS USM, Canon EF 28-300mm F/3.5-5.6 L IS USM, Canon EF 100-400mm F/4.5-5.6 L IS USM.
My Gear | My Website
fubarhouse is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
HUGE flowers! Habiscus flowers? Hmm, no clue. RbrtPtikLeoSeny Wildlife 6 11th of March 2010 (Thu) 17:12
some flowers conbu19 Wildlife 0 13th of December 2007 (Thu) 13:03
Flowers... Dbirdman Wildlife 2 28th of February 2007 (Wed) 14:52
Flowers... shadowwolf Wildlife 2 3rd of May 2006 (Wed) 02:55
