#1 |
| sponsored links |
#2 |
hahah released before the 5D replacement.
Canon EOS 50D specifications Sensor • 22.3 x 14.9 mm CMOS sensor • RGB Color Filter Array • Built-in fixed low-pass filter (with self-cleaning unit) • 15.5 million total pixels • 15.1 million effective pixels • 3:2 aspect ratio Image processor DIGIC 4 A/D conversion 14 bit Image sizes • 4752 x 3168 • 3456 x 2304 • 2353 x 1568 File formats • RAW (.CR2; 14-bit) • JPEG (EXIF 2.21) - Fine / Normal • RAW + JPEG (separate files) • sRAW1 (7.1 MP) • sRAW2 (3.8 MP) Lenses • Canon EF / EF-S lens mount • 1.6x field of view crop Dust reduction • "EOS Integrated Cleaning System" • Self-cleaning sensor unit (filter in front of sensor vibrates at high frequency at start-up and shutdown - can be disabled) • Dust Delete Data - Data from a test shot is used to 'map' dust spots and can be later removed using Canon DPP Software Auto focus • 9-point TTL CMOS sensor • All points cross-type for lenses of F5.6 or faster • Center point additionally sensitive with lenses of F2.8 or faster • AF working range: -0.5 - 18 EV (at 23°C, ISO 100) Focus modes • One shot AF • AI Servo AF • AI Focus AF • Manual focus AF point selection • Auto • Manual Predictive AF • Up to 8 m AF assist • Stroboscopic flash AF microadjust • +/- 20 steps • Adjust all lenses by same amount/individually adjust up to 20 lenses Metering • TTL 35 zone SPC • Metering range: EV 0.0 - 20 EV Metering modes • Evaluative 35 zone • Partial (9% at center) • Spot metering (approx. 3.8% at center) • Center-weighted average AE lock • Auto: One Shot AF with evaluative metering • Manual: AE lock button Exposure compensation • +/-2.0 EV • 0.3 or 0.5 EV increments Exposure bracketing • +/- 2.0 EV • 0.3 or 0.5 EV increments Sensitivity • Auto ISO (100-1600) • ISO 100 - 3200 • 0.3 or 1.0 EV increments • H1 (6400) and H2 (12800) expansion Shutter • Focal-plane shutter • 100,000 exposure durability • 30 - 1/8000 sec • 0.3 or 0.5 EV increments • Flash X-Sync: 1/250 sec • Bulb Aperture values • F1.0 - F91 • 0.3 or 0.5 EV increments • Actual aperture range depends on lens used White balance • Auto • Daylight • Shade • Cloudy • Tungsten • Fluorescent • Flash • Custom • Kelvin (2500 - 10000 K in 100 K steps) WB bracketing • +/-3 levels • 3 images • Blue / Amber or Magenta / Green bias WB shift • Blue (-9) To Amber (+9) • Magenta (-9) to Green (+9) Picture style • Standard • Portrait • Landscape • Neutral • Faithful • Monochrome • User def. 1 • User def. 2 • User def. 3 Custom image parameters • Sharpness: 0 to 7 • Contrast: -4 to +4 • Saturation: -4 to +4 • Color tone: -4 to +4 • B&W filter: N, Ye, Or, R, G • B&W tone: N, S, B, P, G Image processing • Highlight tone priority • Auto lighting optimizer (4 settings) • Long exposure noise reduction • High ISO noise reduction (4 settings) • Auto correction of lens peripheral illumination (vignetting) Color space • sRGB • Adobe RGB Viewfinder • Eye-level pentaprism • 95% frame coverage • Magnification: 0.95x(-1 diopter with 50 mm lens at infinity) • Eyepoint: 22 mm • Interchangeable focusing screen Ef-A standard (2 other types optional) • Dioptric adjustment: -3.0 to +1.0 diopter Focusing screens (optional) • Ef-A (Standard Precision Matte - included) • Ef-D (Precision Matte with grid) • Ef-S (Super Precision Matte for easier manual focus) Mirror • Quick-return half mirror (transmission:reflection ratio 40:60) • Mirror lock-up (once or multiple exposures) Viewfinder info • AF points • Focus confirmation light • ISO sensitivity • Shutter speed • Aperture • Manual exposure • AE Lock • Exposure compensation amount • AEB level • Spot metering area • Flash ready • Red-eye reduction lamp on • High-speed sync • FE Lock • Flash compensation amount • ISO speed (while changing) • WB correction (while changing) • Highlight tone priority icon * • B&W mode icon • Warnings • Maximum burst for continuous shooting • Buffer space LCD monitor • 3.0 " TFT LCD • 920,000 pixels • 7 brightness levels • 160 ° viewing angle • Dual anti-reflection LCD Live view • Live TTL display of scene from CMOS image sensor • 100% frame coverage • 30 fps • Real-time evaluative metering using CMOS image sensor • Best view or exposure simulation • Silent mode • Grid optional (x2) • Magnify optional (5x or 10x at AF point) • Three AF modes - Live mode/Quick mode/Face Detection • Histogram • Remote live view using EOS Utility 2.0 (via USB or WiFi/Ethernet using WFT) Record review • Off • On (histogram via INFO button) • Display mode same as last used Play mode • 2 / 4 / 8 sec / Hold Playback modes 1. Single image with exposure, file number, storage slot 2. As 1 but also image count and quality 3. Detailed exposure information, thumbnail and luminance histogram 4. Less detailed exposure info., thumbnail, luminance and RGB histograms Playback features • Optional blinking highlight alert • Optional AF point display • Magnified view (up to 10x) • 2x2 or 3x3 thumbnail index • Jump (by 1, 10, 100 images / by screen or date) • Delete / Protect Flash • Auto pop-up E-TTL II auto flash • FOV coverage up to 17 mm (27 mm equiv.) • Guide number approx 13 m / 43 ft (ISO 100) • Cycle time approx. 3 sec • Flash compensation +/-2.0 EV in 0.3 or 0.5 EV increments • X-Sync: 1/250 sec External flash • E-TTL II auto flash with EX-series Speedlites • In-camera flash configuration (currently only 580 EX II) • Wireless multi-flash support • PC Sync Shooting modes • Auto • Creative auto • Program AE (P) • Shutter priority AE (Tv) • Aperture priority AE (Av) • Manual (M) • Auto depth-of-field • Portrait • Landscape • Close-up • Sports • Night portrait • Flash off • Camera user settings 1 • Camera user settings 2 Drive modes • Single • High-speed continuous: 6.3 fps • Low-speed continuous: 3 fps • Self-timer: 2 or 10 sec (3 sec with mirror lock-up) Burst buffer • Large/Fine JPEG: 90 frames (with UDMA card) • RAW: 16 frames Orientation sensor Yes Auto rotation • On (recorded and LCD display) • On (recorded only) • Off Custom functions 25 custom functions with 74 settings in 4 groups Menu languages • English • German • French • Dutch • Danish • Portuguese • Finnish • Italian • Norwegian • Swedish • Spanish • Greek • Russian • Polish • Czech • Hungarian • Romanian • Ukrainian • Turkish • Arabic • Thai • Simplified Chinese • Traditional Chinese • Korean • Japanese Firmware User upgradable Portrait grip • Optional WFT-E3/E3A • Optional BP-E2N battery grip • Optional BP-E2 battery grip Connectivity • USB 2.0 Hi-Speed • Video out • HDMI connector • N3 type wired remote control • PC Sync flash terminal • Communication terminal on base for WFT-E3/E3A Storage • Compact Flash Type I or II (inc. FAT32) • Supports UDMA cards • Canon Original Data Security Kit supported ("Original Image Data") • No CF card supplied Power • Lithium-Ion BP-511A rechargeable battery (supplied & charger) • Supports BP-511 / BP-511A / BP-512 / BP-514 • CR2016 Lithium battery (date/time backup) • Optional AC adapter Wireless connectivity (optional WFT-E3/E3A) • Mounts on base of camera and also acts as vertical grip • Has its own BP-511A battery • Wireless 802.11b / 802.11g • Wireless security: WEP, TKIP/AES, WPA-PSK, WPA2-PSK • Wireless methods: Infrastructure or Ad Hoc • Wired ethernet (100 Base-TX) • Transfer: FTP, PTP (remote control by computer), HTTP (view / remote fire) • USB host capable: External hard drives, flash drives • USB comms: GPS devices (records coordinates and altitude in image header) Dimensions 146 x 108 x 74 mm (5.7 x 4.2 x 2.9 in) Weight • No battery: 730 g (1.6 lb) • With battery: 822 g (1.8 lb)
5D | 24-70L | 28mm f/1.8 | 580EX |
#3 |
we over look the simplest things
Not good Canon, Now you are starting to make me mad
David 5D | (2) 550EX | 17-40L | 28-135 | 50/1.8 | 85/1.8 | 70-200L IS Sigma 18-125 | (4)AB B400 | Load of Pentax M42's |
| sponsored links |
#4 |
yeah this is not so great... would be interesting to see the iso 3200+ shots with this new digic4.. but yeah, no 5D replacement.. sad
#5 |
#6 |
Canon EOS 1Ds MKIII 16-35L MK II, 24-70L, 24-105L 70-200L f/2.8 IS http://jeffrey-leung.blogspot.com/ |
#7 | |
#8 |
its on Canon usa
http://www.usa.canon.com/consumer/co...&modelid=17499 |
#9 | |
It's Official now.
http://www.usa.canon.com/consumer/co...&modelid=17499 Here's the press release too: http://www.usa.canon.com/templatedat...26_eos50d.html ![]() Some of the specifications
Image Sensor
Recording System
Image Processing
Viewfinder
Autofocus
External Speedlite
Drive System
Live View Functions
Direct Printing Yay! It's Direct Printing! Again!
Canon 1D Mark III | 16-35 2.8L II | 24-105 4L IS | 50 1.2L | 70-200 2.8L IS| 100 2.8 MACRO| 300 4L IS | Gitzo 3530S | Arca Z-1dp http://www.canonfuse.net It's for my Canon. Last edited by Imaginos : 26th of August 2008 (Tue) at 01:19. Reason: Added specs |
#10 |
Killing Joker
Cool!
|Julian D.| - " You can capture motion with stillness and, in that moment, hold time still, but yet experience the feeling of its passing"- Vincent Versace |
#11 | |
Semper Fi. http://spacialaudio.com Gear, 40D x2, EF 28-135 IS USM (kit), EF-S 17-85 IS USM, EF 70-300 IS USM, EF 50mm f/1.8 II (Nifty fifty), 430ex, BG-E2N Grip. And no talent to speak of.
#12 |
Does this mean I can finally afford a used 20D?
-Adrian [ Flickr ] [ MacBook Pro 13"|iMac 2.66 Alu|350D & BG-E3 w/ E1|Canon 35mm f/2.0|Canon 50mm f/1.8|Sigma 24-60mm f/2.8|430EX|TX-1|Flipside 200|Wish: 17-40mm f/4L, 50mm f/1.4, 85mm f/1.8, xxD ]
#13 |
Killing Joker
I want my HDMI!
#14 |
Maybe even a used 30d.
#15 |
Just triggering through a 580ex or st-e2.
From RG: http://www.robgalbraith.com/bins/mul...id=7-9314-9568 Sensor The mostly-unchanged body houses a new 15.06 million image pixel, 22.3mm x 14.9mm CMOS sensor designed and manufactured by Canon. The sensor has a pixel pitch of 4.7µm square and has been engineered for improved light-gathering efficiency by both increasing each pixel's light sensitive area and by increasing the size of the microlens over each pixel. The microlens array is now gapless; each microlens covers a greater percentage of its pixel's surface area than any previous Canon digital SLR sensor. This tech-speak, says Chuck Westfall, Technical Advisor at Canon USA, adds up to the 50D performing better at higher ISO settings than the 40D, despite the new camera's smaller pixels (4.7µm for the 50D vs 5.7µm for the 40D). Purchasers of the 50D, says Westfall, can expect noise levels to be roughly 1 to 1.5 stops better in the high ISO range. For example, this means that a photo shot at ISO 3200 on the 50D is expected to have similar noise characteristics to one shot in the ISO 1100-1600 range on the 40D. |
| Thread Tools | |
| Display Modes | |
| Official Canon USA 50D Release | frankdatank | Camera Rumors and Predictions | 2 | 26th of August 2008 (Tue) 00:54 |
| Canon 50D official specs in Korean Canon Website | tldoxmf87 | Camera Rumors and Predictions | 0 | 26th of August 2008 (Tue) 00:13 |
| OFFICIAL -- 50D Wish List!!! | mattograph | Camera Rumors and Predictions | 52 | 25th of July 2008 (Fri) 14:46 |
