#1 |
The highly respected Swedish bird and nature photographer Brutus Östling was one of the few selected photographers testing out the 50D this summer.
Here is the translated and slimmed down version of his thoughts from his blog at http://www.tidningenfoto.se/Sites/Fo...____54487.aspx Please visit his blog if you want to see some sample images from his shoot. Quote "At the end of June, a Dutch advertising agency asked if I wanted to be part of a product and commercials for a new camera. I didn't know what camera model it was, only that it would be a camera for amateurs with some enhanced features.One of the features mentioned was an improved AF. I said yes, my experience with Canon is that they deliver good cameras. But I would like to have the time to test the camera first, I have promised nothing. Competition between the camera has become tougher, and it is of necessity very hush-hush about new products to be introduced on the market. In mid-July arrived camera body up to my favourite place in Norway, in an anonymous cardboard - and along with it came a Canon representant from Europe office. I am familiar with Canon's EOS 1 D Mark III and 1 Ds Mark III. The former, with its extreme rates of up to ten pictures i use with fast action and when I need to exceed 1600 in the ISO (because of low noise). The image files of 12 megapixel accept even some cropping.EOS 1 Ds model with 22 megapixel do I use when a frame of five pictures in seconds is enough and when I have enough light to avoid having to go over the ISO 800-1600. Then is it in it's own class in terms of image quality. What I had in hand in July proved to be an advanced amateaur body or semipro with a 15 Megapixel sensor and 6.3 images per second. I have not photographed with the earlier XXD models apart from 10 D. Despite the instruction manual was missing, it took only a few minutes to get acquainted with the features of the new 50D. What interested me first and foremost with the camera was how th AF would react. According to oral information, it would be fitted with a new DIGIC IV processor, which would further improve the auto performance. Before I went out with my rental boat to photograph Gulls, I wanted to test the AF on dry land. In the one-shot mode, I put the focus on my 300 / 2.8 IS on infinity and i focused on the gravel three feet away and pressed down. I repeated the process with different motives closely adjacent and the AF sat there with surprising speed every time. Amazingly fast I must add. I tested the camera with 70-200/2,8 and set the AI Servo while I quickly panned down from the beach 200 feet away on the other side of the water to the surface of the water a few metres in front of me. The focus tracked fine all the time. When I took up my EOS 1 D Mark III and did the same thing the result was less convincing, I have experienced Mark III-s as fast, but EOS 50 D was clearly faster. I repeated the manoeuvre a dozen times with two cameras. När det i alla fall gäller stillastående motiv är min bedömning att EOS 50D har världens troligen hittills snabbaste autofokus. When the motive is still its my assessment that the EOS 50D has probably the world's fastest AF.The next question was how the camera would work out in the field. To photograph flying birds belongs to the most difficult and most challenging you can expose a camera for in terms of AF. The new EOS 50D with EF 300 / 2.8 IS and EF 70-200/2, 8 IS with and without 1.4 TC managed for the most part to follow the Gulls which flew after the boat or who flew at me when we anchored. If i aimed correct and gave the camera few tens of a seconds to react i always got sharp images. When it was not sharp, it was I who had missed having the bird in the centre. I used AI SERVO AF with only the central focus point active. To further test the AI Servo i tried to shoot with all AF points activated. I also stopped down a bit to further increase the DOF. To my surprise, the new EOS 50D with 70-200/2,8 and 300/2.8 worked quite well following birds even with all the AF-points activated. I do not think it works always, but this was clearly better than in any previous camera, I tried. The speed of 6.3 images per second is sufficient to be able to capture the eagle wings in different positions. My experience tells me that the critical point is located somewhere of about five pics per seconds. Is the speed higher than you can capture wings in different positions with most birds, including birds of prey and owls. Compared to MKIII with the ten pic per seconds it is of course a difference, but in practice it is rarely i would miss the images because to lover 6.3 FPS. Back in my hotel room I checked the image files. Unfortunately I had been forced to take photographs in JPG format, since none of the RAW converters didnt work with the 50D files. The files were larger than I had expected. I had expected a 12-13 mpix sensor but the 50D have 15 mpix. Image size of 15 megapixels give me as a photographer great opportunities to crop the images sharply and still use them for example, as a full page in a book (with some interpolation). Large image files is especially important for bird photographers. How many times is your framing perfect when shooting with only the center AF point active? Anyone who photographed birds know that now and then you have to crop. To see what the 50D is capable of ISO wise, I shot high ISO speeds (ISO 640 to 1600) almost all the time. Unfortunately, I had no way in such a short time to make a proper test. My feeling is that noise level is low, especially given the fact that I had to work with jpg files, and that Canon pressed in as much as 15 megapixels in a APS-C-sensor (22.3 x 14.9 mm). Another feature that was introduced already with the previous model wasthe Highlight Tone Priority. Its purpose is to save highlights from getting burned out. I have earlier mentioned in my blog the difficulty of exposing a white bird right against a dark background. Although the white bird occupies a relatively large surface area (25-35%), a darker background steals much light and fool the to think camera think that the subject as a whole is darker - and therefore expose brighter than the white bird actually tolerate. This applies to all cameras and brands. When I tested the EOS 50D I shot with Auto WB, something I normally never do in JPEG mode. Only when I shoot in RAW format I usually dare to shoot in Auto because I always can change WB after. But now I wanted to see how well the Auto WB worked. In 50% of the cases, I was completely happy, but when I had water in the frame and a little warmer evening light the camera tried to switch WB. I therefore recommend that at least when shooting in JPEG, where possible, itself set the WB to have complete control. In the case of flash automatic my experience is that they often underexpose, which certainly is better than the opposite. I had no expectations when I took a few test with the built-in flash on the EOS 50D.I used Auto and photographed a face that occupied 15-20 percent of the fram with a very dark background. I then photographed a room with white walls, and a number of different motives. I have no experience of the previous cameras in the series, 30D and 40D, and I am surprised that automatically managed all these situations. The white walls were not gray but remained white, the WB also acted well. I had only three days to test the camera and based on that limited i felt felt the camera very easy to work with. I have never before been so fond of smaller cameras but preferred a larger body to grip. But even without the grip the 50D felt comfortable. And after three days with a light body, I must admit that it has its obvious benefits to the heavier 1 series. LCD screen was bright and big enough that I could easily control the image quality - and the histogram. With the expanded file size of 15 megapixels, a frame rate of 6.3 images per second and with perhaps the fastest AFs on any camera the only one thing I could swear over was when Canon Representative wanted to pack the camera in the anonymous package again. Possibly could be one more thing to concern me. When the price of 1000-1200 € allows the majority (in our part of the world) to buy a body which in many ways is in class with the best pro bodies, yes how much difference is it between pro's equipment from amateur photographers? The latter, I take that as a professional challenge. Note: I received a compensation for being part of the advertising movie. I recieved however no compensation by Canon to write this. End Quote Hope you find this useful and take it for what it is. UPDATE 1: The video Canon shot while he was testing the 50D can now be seen here http://tv.mediaprovider.se/brutus_os...749756037.html UPDATE 2: I got a few msg's asking who Brutus Östling is and why anyone should take notice of what he says. As i mentioned before you have to take his review for what it is. A three day experience with the 50D, nothing more nothing less, from a photographer that uses the MKIII and MKIII Ds in his daily work. Brutus Östling was appointed "Nature Photographer of the Nordic countries" 2006-07 and his web is well worth checking out. There are some truly stunning images over there plus his newsletter offers really interesting reading. His English version of the web can be found at http://www.brutusostling.se/english/main.html
| sponsored links |
#2 |
Can the AF really be that good?
#3 |
That was my first impression as well to be honest.
Brutus is a highly respected photographer with loads of published articles and books under his belt. Well just have to wait and see i guess. I surely wonder if the new DIGIC IV can make such a different in the AF handling considering that the AF is more or less the same as in the 40D.
| sponsored links |
#4 |
Don't Hassle....
Thanks for posting; it is nice to hear about AF improvements from the real world.
How is it the same AF as the 40D? Same layout of cross points but that doesn't say anything about the algorithms running it. Once the equipment is capable, AF is more about programming than hardware, I think.
••Vancouver Wedding Photographer ••| [gear list] | Latest blog: 5 steps to stopping image loss |
#5 |
Sounds encouraging...
Currently shooting with a G11. Happy to answer any questions or take samples. |
#6 |
AF faster than a 1d? Can't wait to hear this from more than one source. That would be a huge step above the 40.
Too bad he couldn't do any real noise testing. As well as sRAW binning tests/info.
John Caputo |
#7 |
I always think there is a difference between zero to infinite focus speed tests. I'd rather hear about real world SERVO performance. That being said, if it is better than the 40D with the new DIGIC IV, I'm sure it's good.
#8 |
Crap.......another camera body that I have to get.
Scott Location: Michigan - Grand Blanc/Flint Michigan Area "Do or do not, there is no try" My Facebook Page /My Website |
#9 |
Nice review, thanks for sharing!
What we see depends mainly on what we look for. |
#10 |
human (barely) and bribable
Location: Living in the land of 50% white and 50% 18% gray
Thats what I am interested in as well. I have not been all that impressed with the 40D. My XTi does better.
JJ is never late, nor is he early, JJ arrives precisely when he means to. ::Flickr:: ::Gear:: |
#11 | |
Yoda
Me? IF this turns out to avoid the 1DM3 debacle, it's the upgrade I've been waiting for. Of course having (practically just) bought the 40D less than a year ago, it's a real pain having to upgrade again so soon. |
#12 |
- B E L I E V E -
im going to need a bigger sock this christmas!
amateurs argue about bodies, pros argue about glass, seasoned veterans let the pictures argue for themselves. ::::: 50D, 5D, 17-40 f/4L, 24-70 f/2.8L, 70-200 f/2.8L IS :::::
#13 |
thanks for sharing the review. I can't wait to see the sample pics that should be coming out as well.
#14 |
Interesting article indeed. Sounds like I should have waited another year to get into this photography stuff! No worries though. I have had a great time with my 40D and still love it. I do not see a whole lot of weaknesses with it myself. Being my first camera body, I am glad to have something this good to start out with in the first place. We are a truly spoiled generation of photogs if you ask me. I applaud Canon's efforts with this body, and hope that they can offer a revamped 5D with similar performance and the outstanding resolution that everyone has grown to love plus some. Now THAT would be a camera I might considering getting. For now, I'm fine with my 40D and will still enjoy reading about all the new technology coming out.
#15 |
Thanks for sharing, 50D is turning out to be something different afterall.
I'm quite happy with the 40D AF as it is, anything better in the same price bracket is a bonus |
| Thread Tools | |
| Display Modes | |
| 50D and 5D MKII, anyone knows? | fura.s28 | Camera Rumors and Predictions | 33 | 28th of August 2008 (Thu) 17:28 |
| 50D features? | strobe monkey | Camera Rumors and Predictions | 85 | 18th of August 2008 (Mon) 03:27 |
| 50d | jerrythesnake | Camera Rumors and Predictions | 0 | 15th of August 2008 (Fri) 15:04 |
| 50D on its way? | oassayag | Camera Rumors and Predictions | 10 | 4th of August 2008 (Mon) 14:55 |
| I think I'll wait for the 50D... | Cadenza | Camera Rumors and Predictions | 15 | 21st of August 2007 (Tue) 10:54 |
