Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 26th of August 2008 (Tue)   #1
midwestgirl4
Red face 430ex Flash HELP!! PLEASE!? :)
I have a Canon 40D, and just purchased a 430ex Speedlite. This is really a stupid question....but.....can you use this flash when shooting RAW?? How come I can't figure it out!? It only works when shooting in JPG. I like to shoot in RAW, in Tv mode. Any help is greatly appreciated!!! Thanks in advance!
midwestgirl4 is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #2
egordon99
Default Re: 430ex Flash HELP!! PLEASE!? :)
Of course it works with RAW!
For indoor shoots, you should generally use M mode. For outdoor shoots when the flash is being used a fill, use Av (and make sure HSS is enabled on the speedlite)
Go into M mode, set your ISO to 400, shutter to 1/250s, f-stop to f/5.6, point flash at ceiling. Make sure flash is powered on. Shoot. You should get a reasonably exposed picture.
egordon99 is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #3
pepperoni
pepperoni's Avatar
RAW has nothing to do with your flash.
If you're in Tv with a shutter speed faster than 1/250th, hit the lightning bolt on the 430 (once I think) to enable high speed sync. Look for the "H" symbol on the 430.
Mamiya. Canon. Elinchrom.
pepperoni is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #4
midwestgirl4
Ok, I tried what you said, and I'm telling you...it is not working! I switched over to M in RAW, and nothing! No flash. Then, I switched to "portrait" mode in JPG, and the flash works. What am I doing wrong?? What is the HSS on the speedlite? I pressed the "lightening bolt" button, and tried everything but it won't work. Is something wrong with my flash, or is it me!?
Old 26th of August 2008 (Tue)   #5
tsw910
tsw910's Avatar
well, your flash and type of file has nothing to do with one another ..
have you tried in your c. fn and see if the " flash fires " is enable?
Scuba Tom
NYC Wedding Photographer
tsw910 is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #6
msowsun
msowsun's Avatar
If your flash is not enabled, it will work in all the BASIC modes like Green Box, Portrait, Sports etc,
but not in the CREATIVE modes like P, Tv, Av, M.
RAW is only available in CREATIVE modes, so it looks like you are switching to the BASIC modes with your flash disabled. The Basic modes over ride the flash disabling and let your flash work.
Flash Firing is not a Custom Function. Flash Firing - Enable/Disable is in the flash control menu found in the second yellow "Setup" menu. (page 103 in your 40D manual)
Mike Sowsun.......... G1x / 5D Mk III / EF 40mm 2.8 STM / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF Extender 1.4x II / 580EX II / 430EX II (x2)
Full Current and Previously Owned Gear List over 40 years
msowsun is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #7
KWestbye
I am a bit new but is there not a small flash button on the left side that you need to push once you are in any manual mode?
KWestbye is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #8
KWestbye
OK - my bad - I did not read the full post - so you pushed the lighting bolt and still did no work. Man tuff one there
Old 26th of August 2008 (Tue)   #9
Mystwalker
As long as flash is ON in Tv, Av, M mode - it will fire. I think in the green box and other preset modes (portrait, macro, sports, etc ...), there are parameters to meet - I never bothered to read/understand because I'm never in those modes.
With flash attached, in Tv mode, I do not think flash will allow you to set shutter above 250 unless you have that "hi-sync" (soemthing like that) ON. Another mode I hardly ever touch so not too familiar with it
Not sure pushing the "internal flash pop-up" (lightning bolt) button will make difference wtih external flash attached. Flash will fire if it is "ON" - it should
Have you tried to email/call Canon Service? May be something wrong with flash.
RAW or JPEG should not matter - like others say, it's just a storage format.
Mystwalker is offline   Reply With Quote
Old 26th of August 2008 (Tue)   #10
pepperoni
pepperoni's Avatar
Guys... the lightning bolt "on the 430", not on the camera.
Looks like msowsun found the answer.
Old 27th of August 2008 (Wed)   #11
midwestgirl4
Thank you SO much! All I had to do was 'enable' the flash and now it's working just fine! Thank you, thank you, thank you!!
Old 27th of August 2008 (Wed)   #12
Q-bert
Q-bert's Avatar
I had a heck of a time with weird things going on with my flash. Turned out it was all in the 3rd party sync cord I was using. Sent it back and got a Canon one and everything worked like it was suppose to. Just a thought.
Q-bert is offline   Reply With Quote
Old 27th of August 2008 (Wed)   #13
Scott6
failed to mention it was on a cord eh?
Scott6 is offline   Reply With Quote
Old 28th of August 2008 (Thu)   #14
Titus213
Titus213's Avatar
Not the OP's post. That problem was resolved with a camera setting.
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Quantum flash module XB2 for 430EX flash. Pepeyoyo Classifieds: Buy 0 7th of March 2008 (Fri) 02:09
Using flash 430ex as fill flash.... TooManyShots Small Flash and Studio Lighting 5 3rd of March 2008 (Mon) 00:09
430EX Flash help Jonmorgan Small Flash and Studio Lighting 3 30th of December 2007 (Sun) 17:55
Flash Question (Sigma DG ST EF500 flash vs 430ex.) JaGWiRE Accessories & Storage 0 15th of September 2006 (Fri) 23:46
