Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 28th of August 2008 (Thu)   #1
birdfromboat
birdfromboat's Avatar
Location: somewhere in Oregon trying to keep this laptop dry
Default is my custom white balance technique a bad practice?
when I first saw an expodisc, I thought I wanted one. Then I saw the price, and that I needed a different one for all my different lens filter dia's. I bought a Lally cap ( has anyone else seen this?) because it was inexpensive and promptly lost it, but at least I got the jist of how it worked first. This is what I tried next, and what I still do to this day:
I purchased a yard of ripstop nylon that was as close to "photogray" as I could find (pretty dang close) and cut up several 12 x 12 sheets with a solder iron so the edges wouldn't fray. I set the lens to a suitable fstop for available light, manual focus, zoom length not important, and take an exposure with a sheet of my ripstop gray stretched over the lens opening and the camera pointed at the strongest source of light affecting the subject(s). This exposure is used to set custom white balance, with pretty good results. I shoot everything raw anyway, so I get a second chance at color, but I am usually pretty close, maybe just a little off in Cyan/green consistantly. I know there are other methods, what are yours? I have been advised to just use AWB and do it all in raw post process, but I am happy with my results and have not yet been convinced to try otherwise. I have never actually met anyone that uses the coffee filter trick, does that work for you? Anyone using a lally cap? Expo disc? gray card? copier paper? Anyone?
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8 (seeking a good used 300 f2.8)
Looking through a glass un-yun
birdfromboat is offline   Reply With Quote
Old 28th of August 2008 (Thu)   #2
Deckham
Default Re: is my custom white balance technique a bad practice?
I may get shot for this, however, shooting in RAW, I always keep it on auto. If I have a series (say, a warm interior shoot), I will correct the first photo in LR, than apply to the entire series. I do not believe there is any drawback to this system, other then perhaps some self-satisfaction with nailing wb onsite. Personally, I feel it takes times away when I could use it elsewhere.
Mixing light sources is another matter.
Deckham is offline   Reply With Quote
Old 28th of August 2008 (Thu)   #3
opus13
opus13's Avatar
Agreed.
Constantly checking a rechecking whitebalance just irritates me and gets in the way of shooting. AutoWB+RAW is great by me. After all, what is post processing for, if not to keep you enjoying what you are doing?
mah stuff
opus13 is offline   Reply With Quote
Old 28th of August 2008 (Thu)   #4
birdfromboat
Do people still get shot in Australia for not using all the technology available? Man, thats harsh. You are right, its all about satisfaction at nailing it. I used to be a photoprinter back in the days of the kodak 5s printers with the clicking and clacking filter decks, and I hated photogs that couldn't get it right. I like to get it right if I can, but you are right, I probably could be doing more shooting stuck in AWB and doing it all in post. Thanks for the input.
Old 29th of August 2008 (Fri)   #5
Deckham
hahaha - figuratively speaking, of course
Sometimes, Puritans can get a little excited
Old 29th of August 2008 (Fri)   #6
manutd101
manutd101's Avatar
I shoot a gray card in challenging situations, especially when shooting jpegs for sport.
Conor - my flickr
Do you enjoy these forums? Donate!
manutd101 is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
Gray Card…White Paper. What’s best?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 31st of August 2008 (Sun)   #8
gkas
I still love my WhiBal...
Gerry Kaslowski
gkas@socal.rr.com
Gerry's Pics http://MikeKazPhotography.com/Gerry/
gkas is offline   Reply With Quote
Old 31st of August 2008 (Sun)   #9
primoz
POTN Sports Photographer of the year 2005
primoz's Avatar
Since I shoot in jpeg, proper wb is a bit more important then when shooting in raw. But no matter what, simple white paper works good. If there's no white paper, snow, gray asphalt, kinda white t-shirt and similar things do just fine
Expo disc is cool, but plain paper works good enough, so it feels a bit stupid to pay $100 for it.
PhotoSI | Latest sport photos
primoz is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Custom White Balance - Grey or White? dfuccillo Canon EOS Digital Cameras 38 22nd of December 2008 (Mon) 17:31
Custom White Balance - white or grey card? bcap General Photography Talk 28 18th of July 2007 (Wed) 13:26
do I use white or grey for custom white balance? viodea Canon EOS Digital Cameras 26 13th of April 2006 (Thu) 15:52
White card custom white balance adjustment Nabil-A Canon EOS Digital Cameras 14 27th of July 2005 (Wed) 19:29
Custom White Balance Laurab Canon EOS Digital Cameras 8 31st of December 2004 (Fri) 09:20
