Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 29th of August 2008 (Fri)   #1
grandadraymond
grandadraymond's Avatar
Default Charging 40D Batteries
Do batteries have to be flat before recharging, or can half charged batteries be topped up
Canon 40D Canon EF 100mm f/2.8 USM L IS macro , Canon EF 100-400mm f/4.5-5.6L IS USM
grandadraymond is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #2
yogestee
"hangs around male genitalia"
yogestee's Avatar
Default Re: Charging 40D Batteries
Definitely the latter..
Jurgen
50D~20D~EOS M~S95
http://www.pbase.com/jurgentreue
yogestee is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #3
grandadraymond
Thank you...Ray
Old 29th of August 2008 (Fri)   #4
smcclelland
smcclelland's Avatar
I charge mine under either of those conditions. If I am shooting the entire weekend at a track then even if I'm at 50% charge I'll pop them in the charger as I don't know how taxing the next day will be and last thing I want is to get caught without any fully charged spares. Currently using 6 BP511A's for two 40D's and when the 3rd arrives that amount is certainly going to have to increase a lot more
Shawn | Flickr | Blog
There used to be Canon gear here but it disappeared.
smcclelland is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #5
watchtherocks
watchtherocks's Avatar
Yeah, you can charge lithiums from whenever, unlike the NiCads.
watchtherocks is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #6
tim
Light Bringer
tim's Avatar
Whenever. www.batteryuniversity.com
tim is offline   Reply With Quote
Old 29th of August 2008 (Fri)   #7
Glenn NK
Glenn NK's Avatar
No, this concept is a hold-over from the old NiCad batteries which had a memory.
"Be yourself - everyone else is taken". Oscar Wilde
Glenn NK is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1D Batteries and Charging Them calicokat Accessories & Storage 56 24th of May 2008 (Sat) 19:00
Charging Batteries DxHatchback Accessories & Storage 8 17th of July 2006 (Mon) 19:55
Re-charging Batteries paulajayne Accessories & Storage 21 19th of May 2006 (Fri) 01:47
non-OEM batteries not charging cowman345 Canon EOS Digital Cameras 9 22nd of August 2003 (Fri) 20:55
Charging batteries in the U.K. ajax General Photography Talk 3 2nd of November 2002 (Sat) 00:26
