#1 |
Hi,
Trying to get some practice in before my son's high school football season start this Saturday. His games will start around 10:00 on Saturdays. I took this picture during midday and shot in AV, with +2/3rd's exposure. I probably should of tried 1 or 1 1/3 but was afraid of blowing highlights. Should I have metered his face that way no shadows would have appeared ?
Canon 1D Mark III|Canon 40D| Canon 350D| Opteka Battery Grip| 430EX| EF 85mm f/1.8 USM| EF 70-200mm 2.8L USM|EF 300mm IS 2.8L|EFS 17-55mm IS USM 2.8 |Kenko 1.4X A.L. Sports MaxPreps Profile/Sports Shooter Last edited by mnez17 : 4th of September 2008 (Thu) at 19:14. |
| sponsored links |
#2 |
Have you thought about using fill-in flash?
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs |
#3 |
There is little to nothing you can do about this, other than dodge in photoshop. It is just the nature of the beast. If you overexpose any more, you will blow everything out.
Canon 1D (MARK III), 10d, Elan IIE (old school), 580exII 70-200 f/2.8L, 17-40 f/4L, 85 1.8, 50 1.8 (nifty) http://josephcyrphotography.smugmug.com |
| sponsored links |
#4 |
I agree. In fact, I usually don't go much more than + 1/3 or so in Av and that's just to adjust for the fact that I think my camera tends to underexpose by about that amount. In photoshop, I will select areas I want (usually faces) and use the shadow/highlight sliders to adjust those areas. While selected I will apply a little selective USM as well.
#5 |
Yep, simple 15 second fix in photoshop
#6 |
If you meter for the shadow, everything will be blown out. You need to accept it, shoot from a different angle, or find some way to get light in there.
You can always adjust it in photoshop later. There are many different ways to go about it. If it bothers you that much, find one that works for you and go for it.
#7 |
Thanks for the responses! I enhanced it a little by using the shadows/highlight slider priot to posting. I'll try different angles. I guess these are the problems you will run into while shooting around midday.
Canon 1D Mark III|Canon 40D| Canon 350D| Opteka Battery Grip| 430EX| EF 85mm f/1.8 USM| EF 70-200mm 2.8L USM|EF 300mm IS 2.8L|EFS 17-55mm IS USM 2.8 |Kenko 1.4X A.L. Sports MaxPreps Profile/Sports Shooter |
#8 |
One of the worst times to shoot anything is under a bright midday sun. VERY harsh lighting.
#9 |
I think you did fine.
I wouldn't go any higher. Your shadow/highlight adjustment did enough. Thanks for sharing.
Comments, Questions, Observations Welcome 1DsII, G12, 17-40, 50 f/1.4, TS-E 24mm f/3.5L, 70-200 f/4L IS, Gitzo 1541 w/ Markins M10 ballhead. "Art always shows itself by doing much with few and simple things." A. W. Dow |
#10 |
agreed! Funny thing is that non photogs think bright sunny days should be the best for pic taking.
#11 |
shoot from the backlit side.
#12 | |
#13 |
Meh...Its debatable what the "best" time is. Im kinda partial to 1.5~2h before sunset. LOTS of different opportunities there.
#14 |
Mmm...good time there, but for sports you run the risk, if shooting JPEG, of the light getting too warm on you.
#15 |
Sorry to say but this quote is so true, Im no pro but helments and ball caps will test the best of them
| Thread Tools | |
| Display Modes | |
| Helmet shots | cryton | Motorsports | 41 | 9th of February 2008 (Sat) 09:29 |
| Fire Helmet | IMARLOW | Still Life, B/W & Experimental | 1 | 11th of January 2007 (Thu) 10:16 |
| Any pictures of Helmet? | meantime000 | Performing Arts | 1 | 28th of July 2006 (Fri) 03:04 |
| Squeeze that helmet on | ronmayhew | People | 1 | 20th of October 2005 (Thu) 06:26 |
