#1 |
I've noticed that the built in flash on the digital rebel pretty much sucks ass. I'm not entirely sure whether it's just an insufficent flash or whether there's a way to adjust the strength of the flash like on the A series point n shoots.
If there's not, anyone know a way to get better exposed pictures using the onboard flash? I checked the flash sticky, but it didnt seem to have anything pertaining to the rebel. Thanks
My website. My picasaweb gallery. All pictures taken with a Canon Digital Rebel XTI with the kit lens, 24-70 f2.8L, Sigma 10-22mm or a 50mm f1.8 II. All flash pics taken with a 430EX or a Sunpak using Cactus remotes. |
| sponsored links |
#2 | |
You're right though, it's weak. Especially if you shoot wide angle, your built in flash won't be able to properly light up the entire frame in most cases. I dont't know if you can set FEC on the built in flash with the hack, but if you do, that's a solution.... never tried though. I'd just get an external flash if I were you. |
#3 |
The best work around is to buy a flash with its own controls like the 550EX or Sigma 500 DG Super.
Scott |
| sponsored links |
#4 |
Well if you get the hacked firmware on the digital rebel, you can hit the Jump button on the left to bring up FEC ( Flash Exposure Compensation ), to increase/decrease the flash intensity. FEC isnt provided on the Drebel from canon, gota get the hacked firmware.
But ya the onboard flash isnt very versitale, and usally best to have an external flash, preferably one that supports E-TTL. |
#5 |
Cough hack rocks cough
#6 |
Light Bringer
An external flash is a great investment, I highly recommend getting one.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
#7 |
I found Digital Rebel’s flash strength adequate. It has a guide number of 43 feet. If you are using your 50mm lens you can shot from up to 20 feet (7 meters) with f2.0 at ISO100.
The real problem is E-TTL, which often outsmarts itself by giving mostly underexposed shots. E-TTL “decides” about the strength of the flash based on the lightness of the tiny area in the middle of the frame. And there is no way you can manually set the flash strength like in A-series. Try one of the following: - Before taking a shot point the camera to a darker object and press FEL(Flash Exposure Lock) button (marked with *). Than recompose and take a shot. You can also use a palm of your hand to cover some light from the flash while pressing FEL button. - Upgrade to the hacked firmware as it was suggested. You will get up to 2 f-stops up and down. |
#8 | |
---Bob Gross--- |
#9 | |
---Bob Gross--- |
#10 |
Install the HACK. After installing, I am now able to adjust the FEC and made a big difference. It was originally set at lowest setting and was awful. Now it's much better since I can adjust it.
__________________ My gear: Lots of bodies... Lenses: Bunch of different metal tubes with glass in them... |
#11 |
What steps did you take to adjust the FEC?
www.dcsportsbox.com http://www.pbase.com/skcphotography http://www.skcphotography.blogspot.com/ 1DMKIIN, Canon 30D, Canon 70-200 2.8L IS, Canon 24-70 F2.8L, Canon 50 1.8, Sigma 1.4 TC, 2 Quantum Q Flash, Canon 580 EX and EX II, Alien Bee 800/400, and lots of other stuff. |
#12 | |
2) Pop up the flash 3) Press the "jump" button on the right 4) Rotate the wheel to adjust FEC from -2 to +2 stops. Cheers |
#13 |
Moderator
Even with the hack and FEC, you're still limited to the relatively low power output of the flash (and the lack of bounce and manual controls). You're really much better off acquiring a dedicated Speedlight flash such as the 420EX, 550EX or 580EX. (You'll need the EX series and not the EZ series for your digital camera).
Mark ----- Some primes, some zooms, some Ls, some bodies and they all play nice together. Thirty-five years of shooting and still learning. My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW) G&N FORUM EARLY ACCESS & IMAGE POSTING RULES |
| Thread Tools | |
| Display Modes | |
| Adjusting aperture on Canon Rebel XT | chapt0r | Canon EOS Digital Cameras | 4 | 23rd of March 2007 (Fri) 07:24 |
| Flash for Digital Rebel | BillH2 | Canon EOS Digital Cameras | 2 | 17th of January 2005 (Mon) 14:22 |
| From SLRs to DSLRs: Adjusting to Digital Technology | Sam North | General Photography Talk | 11 | 19th of October 2004 (Tue) 05:02 |
| Flash For Digital Rebel | KAMPhoto | Canon EOS Digital Cameras | 1 | 26th of October 2003 (Sun) 19:24 |
| how do i set the strength of my flash in manual mode? | danieldy | Canon G-series Digital Cameras | 1 | 2nd of March 2002 (Sat) 10:04 |
