#1 |
So I thought I had successfully changed my password. I logged out and now I'm stuck out. I did a search on resetting the password, but I couldn't understand the one thread that seemed to address this, so I'm going to ask:
What is the best way to reset your password in EE? (Speak slowly, I am a newbie.) |
| sponsored links |
#2 |
El General Moderator
I sent you a PM, but this may be useful for others, too:
Save the following code in your input folder as file SCRIPT_reset_username_and_pass.php Then browse to http://www.yoursite.com/your_gallery...e_and_pass.php (edit address to suit your site) That will set user: admin pass: pass REMEMBER to set a new username pass after that in misc settings. Or edit them to file below and run it again. PHP Code:
This signature signifies my significance significantly Photo Gallery ---------------------------- Last edited by Pekka : 2nd of February 2005 (Wed) at 16:55. |
#3 |
Awesome, that did the trick. I will certainly save a copy of this code somewhere (not in the input directory, of course). Thanks for the help.
| sponsored links |
#4 |
Thanks. It just saved me!
Join us in Chicago on April 22nd (Click here for more details) 5D, 85 f1.8, 24-70L f2.8, 70-200L f/4, 580ex, 430ex. |
#5 |
I was trying this on a 1.5 EE, just moved from one server to another server, I ran this script for a couple of times, and the login of admin and pass did not work. I tried with IE and firefox. Any other way I can reset the admin password?
Thanks!
visit http://www.dancewithlight.com |
#6 |
Unzip SCRIPT_reset_username_and_pass.zip in your admin folder and run it. Then delete the php file.
This signature signifies my significance significantly Photo Gallery ---------------------------- |
#7 |
I used the code that you posted above. I did not see there is a zip file of SCRIPT_reset_username_and_pass.zip in the admin folder. I am on 1.5 version.
#8 |
ok, that explains it. Sorry for misinfo.
#9 |
Ok, so what should I do next to reset the password?
#10 |
Are you sure that the database connection details are correctly configured in EE? If so, I can't see why the chunk of PHP that Pekka posted above isn't working.
Do you have an installation of phpMyAdmin that you can use to manipulate the EE database? If so, that would provide another alternative - select the database, select the ee_admin table, press Browse and change ee_admin_pass to 1a1dc91c907325c69271ddf0c944bc72 (which is pass in the appropriate format). David |
#11 | |
1a1dc91c907325c69271ddf0c944bc72 So that means the password reset script has already made the change. But I cannot login. The admin name is "admin". When I put admin and pass, the screen flash for a second or so, and I am back to login page again... very wired.
#12 |
have you flushed your browser cache?
what about removing the EE cookie? |
#13 |
I have three web sites with EE installed. But they worked fine before. I even tried with a different computer, and it does not work with this particular one now. I have tried to clear the EE cookies, it did not help. I cleared the cache, also no help.
I have used EE for a long time, and this is the first time it happened to me.
#14 |
Pekka,
I know you are a busy man... But we really need your help. We are completely stuck here. Gallery has been off for days. Thanks in advance for your help.
#15 |
PM me access details and I'll see what the problem is. PHPmyadmin access would be a plus.
| Thread Tools | |
| Display Modes | |
| Admin Password recovery??? | Tromac | Version 1.0-1.5 discussion | 4 | 4th of December 2005 (Sun) 09:34 |
| Rename admin and change password | Oceanwatcher | Version 1.0-1.5 discussion | 2 | 6th of May 2005 (Fri) 17:44 |
| Resetting admin password? | koen_brader | Version 1.0-1.5 discussion | 1 | 12th of January 2005 (Wed) 09:50 |
| Change admin password? | mol | Version 1.0-1.5 discussion | 1 | 26th of August 2004 (Thu) 12:30 |
| Password for admin area | richa3turbo | Version 1.0-1.5 discussion | 4 | 26th of March 2004 (Fri) 07:13 |
