Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 21st of September 2008 (Sun)   #1
osia9745
Default IXUS 70 problem (LCD Screen is just black in shooting mode)
Hi
I used a Canon IXUS 70 digital camera last Friday. when i was using this at a birthday party it was working fine the whole day but late afternoon once i switched on the camera the LCD screen was just only showing plain black and when i took photographs the photographs were also black.(The LCD screen was functioning properly on play back mode and i was able to go through the pictures with out any problem) I tried changing all the settings i removed the battery and the CF card and put them back in and tried but still it didn't work. After trying a lot of times i gave up but after a couple of hours when i switched it on it was working fine. I would be really grateful if some one can explain this strange behavior. Thank you.
osia9745 is offline   Reply With Quote
Old 21st of September 2008 (Sun)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: IXUS 70 problem (LCD Screen is just black in shooting mode)
Stuck shutter, maybe? Or the batteries were getting weak, and revived after the several hour rest?
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
HELP.... IXUS 75 Blank LCD screen hasan_Z Small Compact Digitals by Canon 1 1st of September 2007 (Sat) 13:42
IXUS V3 - black screen problem Mike S Small Compact Digitals by Canon 1 14th of July 2007 (Sat) 09:37
screen problem with IXUS 430 Benb Small Compact Digitals by Canon 2 16th of June 2006 (Fri) 03:14
Canon ixus 700 lcd screen WCES Small Compact Digitals by Canon 0 14th of July 2005 (Thu) 12:50
LCD screen Ixus 330 Koenobi Small Compact Digitals by Canon 0 22nd of December 2003 (Mon) 14:26
