Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 26th of September 2008 (Fri)   #1
Strawberry Fields
Default High ISO: Old 5D obliterates EOS 50D
The new EOS 50D versus the 3-year old EOS 5D. I believe these were shot in RAW. The EOS 5D RAW file was pushed/expanded to ISO 6400, and compared to ISO 6400 Expansion on 50D.
Scroll down to the very bottom of this page to see the direct comparison.
[Added More Links Below]
Here is another comparison between a retail version of the new EOS 50D and an old EOS 5D. The test was done by a helpful member (motopram) at DP Review who bought a 50D, and borrowed a 5D. Some things to consider, before looking at the pics:
  • Shot in RAW, converted through DPP, identical settings, NR sliders at ZERO in DPP.
  • Both shot with the same 180mm Macro lens @ f/11
  • Identical settings means the EOS 5D will be 1/3 stop brighter. The advantage of the EOS 5D is that its sensor is 1/3 stop more sensitive than the newer cameras.
  • Identical settings means EOS 5D will have 1.3 stops shallower Depth of Field in these samples
  • Focus is a bit off between samples, so we can't compare details. Especially since DoF is different. But we can still compare noise grain, since NR=off.
  • The images were not resized, since the difference between 12.8 MP and 15.1 MP is negligible. less 9% difference in vertical, horizontal size.
Here is the EOS 5D at ISO 3200
Here is the EOS 50D at ISO 3200
Here is the EOS 50D at ISO 1600
In my humble opinion, the EOS 5D at ISO 3200 looks as good (or better) than the EOS 50D at ISO 1600. It's interesting that the 5D has very fine noise grain, compared to the lumpy noise blotches on the 50D. Anyways, in my opinion there's slightly more than one stop difference. But I'd advise people can look at those pictures themselves, and make their own judgements.
Some more comparisons from the test above:
Here is the EOS 5D at ISO 1600.
Here is the EOS 50D at ISO 800.
It just goes to show that fancy new technology is no substitute for a bigger sensor. When the EOS 90D shows up in 2014, I'd bet it *still* wouldn't be as good in high ISO as a then-9-year old EOS 5D.
Last edited by Strawberry Fields : 29th of September 2008 (Mon) at 19:24. Reason: Added More Links
Strawberry Fields is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #2
_aravena
_aravena's Avatar
Default Re: High ISO: Old 5D obliterates EOS 50D
Maybe there will be a bigger sensor on the 90D? That's too far but to say 70D, yeah.
Well I never doubted the 5D's capabilities. It's why I'm strongly considering just saving for awhile, put off weddings (having only one camera) and get a 5D as my main. Armed with a 18-50 on the 20D and 70-200 on the 5D I'd be happy. At 200 I can push the ISO and get a decent shutter speed.
POTN CRUMPLER MAN!!!
My Site ~ Gear List ~ Bag Reviews
_aravena is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #3
HaroldC3
Wow, that really makes me rethink buying a 50D...hmmmm
Flickr ~ Buy/Sell Feedback
Canon 60D / Canon 10-22mm / Canon 18-135mm / Sigma 30mm 1.4 / Canon 70-210mm f3.5-4.5
HaroldC3 is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #4
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Is there a RAW converter for the 50D yet?
FlyingPhotog is online now   Reply With Quote
Old 26th of September 2008 (Fri)   #5
Indecent Exposure
Indecent Exposure's Avatar
My first reaction to the title of this thread was , "Another person overstating what amounts to a minuscule difference."
I was wrong. I admit it.
Gonna have to follow this.
- James -
www.feedthewant.com
500px
Gear List and Feedback
Indecent Exposure is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #6
sadatk
sadatk's Avatar
acr.
sadatk is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #7
chevysales
not even close for a true comparison... but you go with your swedish comparison and enjoy your 5d.
what blows my mind are all these totally off the chart comparisons that mean nothing...done with beta acr of thru jpegs of one raws of another...all conjecture.
me i am a little more realistic and will wait for true comparisons done under true controlled tests that actually mean something... 5d may come out on top who knows. but at least the testing procedure will be legitimate
D700 paired with 24-70 f2.8; 70-200vr f2.8 capped off by B+W MRC fPro UV filters, B+W Kaesemann Circular Polarizers, Manfrotto 055xprob/488rc2. All comfortably carried with Kata R102 backpack... adding as needed :>) yep sold my canon gear and switched to the dark side
chevysales is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #8
khkohl
Who shoots 6400 iso ?? I certainly don't or wouldn't unless it was an emergency situation!
khkohl is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #9
_aravena
_aravena's Avatar
I've done 3200 and would have been absolute grateful to have 6400 like that.
Old 26th of September 2008 (Fri)   #10
DDWD10
DDWD10's Avatar
I certainly wouldn't expect a 50D to beat out a 5D at high ISOs. It's just a matter of sheer sensor size.
The real question is can the 5DII beat the 5D at the pixel level at High ISO?
30D | X-Pro1 | X10 | Q
EF-S 18-55mm IS | XF 35mm f/1.4 R | Q 5-15mm f/2.8-4.5
DDWD10 is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #11
khall
That's when you need ISO 6400
YNWA.
khall is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #12
darosk
darosk's Avatar
Exactly.
Website | Facebook | Gear
darosk is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #13
Lucy Brown
Lucy Brown's Avatar
umm, this is a silly thread
Lucy Brown is offline   Reply With Quote
Old 26th of September 2008 (Fri)   #14
gjl711
human (barely) and bribable
gjl711's Avatar
I kind of expected the 50D to perform better than the 40 though. If you go back to page 1 and look at the 40/50 comparison I'm not seeing any difference.
Does look like the 50D does a better job with white balance though.
Not sure why, but call me JJ.
Today is only yesterday's tomorrow
::Flickr::
::Gear::
gjl711 is online now   Reply With Quote
Old 26th of September 2008 (Fri)   #15
Tsmith
Formerly known as Bluedog_XT
Tsmith's Avatar
In the 4 years now with DSLR's I've gone above iso 800 only a few times other than for pixel peeping tests.
Its kinda amazing all these high iso samples flying around the net. I've seen quite a few 50D iso 6400 that are very good. A lot of variables can affect the results.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS
Canon PowerShot S95
MY PBASE GALLERY
Tsmith is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
50d is way better than d300 for high iso! connexile Canon EOS Digital Cameras 5 27th of September 2008 (Sat) 13:17
50D high ISO sports sample images Tsmith Canon EOS Digital Cameras 11 25th of September 2008 (Thu) 23:37
50D high ISO picture links ddenig Canon EOS Digital Cameras 13 7th of September 2008 (Sun) 16:08
Canon 1DS MKIII (MK3) high ISO samples 500-3200 ISO F14fanatic Canon EOS Digital Cameras 3 24th of October 2007 (Wed) 18:57
EOS-1D MarkIII Vs. EOS-5D - ISO (Low & High) Noise comparisons roli_bark Canon EOS Digital Cameras 0 28th of August 2007 (Tue) 03:29
