Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 26th of September 2008 (Fri)   #1
cfcRebel
cfcRebel's Avatar
Default How to dual boot (WinXP in IDE, Vista in SATA) ?
Currently my computer is running Windows XP in an IDE. I just bought a new SATA disk and would like to install Vista on it. I heard of dual boot before but have zero knowledge about it. Can you guys help? How do it go about setting up dual boot?
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
cfcRebel is offline   Reply With Quote
Old 27th of September 2008 (Sat)   #2
MaxxuM
MaxxuM's Avatar
Default Re: How to dual boot (WinXP in IDE, Vista in SATA) ?
It's pretty easy... the main thing is to install XP first. After installing the SATA drive boot into XP and toss in the Vista DVD. You can do the compatibility test first if you like, but if you have a pretty new system (2yrs) there shouldn't be a problem. Hit install, put in your number and then pick the SATA drive as the Vista drive then let it go. It will reboot several times by itself. Once its on the final step it will prompt you to pick OS, Vista or previous version of Windows. That's pretty much it. Here is the thing though, NEVER erase VIsta else XP won't work. There are tools however to remove Vista's new boot loading software though. Make backups too. I use Drive Image XML to make copies of Vista and XP just in case.
Canon 7D & 60D With Grip's
Canon: EF-S 17-55 F2.8 IS, EF 70-200L F4 IS, EF 85mm F1.8
MaxxuM is offline   Reply With Quote
Old 27th of September 2008 (Sat)   #3
equetefue
equetefue's Avatar
Do a search for VistaBootPro...awesome little program, and yes you can uninstall Vista and XP still works...
The Vista MBR is diferent but easy to remove.
http://www.Photo-Galleria.com
Powered By Canon
1D Mark III l 5D with Grip l 50mm f1.8 l 17-40mm f4 L l 135mm f2 Ll 70-200mm f2.8 L IS l 400mm f5.6 L l EF 1.4x II l 580EX II l Feisol CF tripod l Wimberly Head II with F9 Bracket l Better Beamer
equetefue is offline   Reply With Quote
Old 27th of September 2008 (Sat)   #4
cfcRebel
cfcRebel's Avatar
That's good to know. It sounds easier than i originally thought. Thanks guys.
Fee
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Dual Boot... DeadMansLife The POTN Lounge 6 10th of May 2008 (Sat) 03:04
ExpressCard 54 to eSATA/SATA Cable to SATA Enclosure? cdifoto Accessories & Storage 37 10th of December 2007 (Mon) 00:15
