Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 13th of February 2005 (Sun)   #1
seaspray
Default youth team photos
I was just approached to take some 5-6 year old individual and team photos. I'm shooting with a 20d and my bracket and new 580ex should be arriving tomarrow. I have a little time to play with it but no since in reiventing the wheel if I don't have too. I have the 17-85 is usm lense which came with the camera and also a 50 f1.4 usm. My question is which lens and what f setting would give the sharpest image? Also along with the flash i've ordered a diffuser. Thanks
Canon 20d, 17-85, 50 1.4, 70-200 f2.8
seaspray is offline   Reply With Quote
Old 13th of February 2005 (Sun)   #2
KevC
KevC's Avatar
Default Re: youth team photos
50mm f/1.4
Shoot at f/5.6 or narrower. Lenses are beautifully sharp stopped down 3 stops from wide open.
With your flash you might as well do f/8 or f/11 @ 1/125. But then again, that's what I've heard you're supposed to do with a flash. I don't personally have one.
Too much gear...
take nothing but pictures .... kill nothing but time .... leave nothing but footprints
KevC is offline   Reply With Quote
Old 13th of February 2005 (Sun)   #3
seaspray
Thanks. That will give a me starting point. I've have a week before the photos are to be taken so I'll play with it this week.
Old 20th of February 2005 (Sun)   #4
WestFalcon
Seaspray, I do these frequently. Your 17-85 will work fine. You didn't say inside or out did you? If you are outside, line them up from tallest to shortest first. Lets say there are 12. Count from the shortest back to the 5th and 6th person. they are in the middle in the front row on two knees. The 3rd and 4th person from the short end are on each side of the first two. the two shortest are at the ends of the first row. The two tallest are standing behind the two center people etc....Coaches may stand behind row 2 since the kids are short at this age. I usually try to put the group in a shaded area...never in bright sun unless you have to. I shoot manual at F8 and 60th -125th of a second at asa 200-400. Check your histogram and adjust F stops or ASA till u get a good histogram. Never shoot below f5.6...too shallow of depth of field. Now do individuals. U can use a similar f stop and shutter speed. Keep um in the shade with simple backgrounds. Once you get it down, they are pretty easy.
WestFalcon is offline   Reply With Quote
Old 20th of February 2005 (Sun)   #5
pdrow
Have you thought of how you are printing them? Several of the labs have a way to process them in batches, They provide a simple software that you set up with templates and then you can do custom cropping or they will crop. They also package them with the group photo. They also provide a way to make the ever poular trading cards. I did this with a banquet I shop (we skipped the trading cards) and it was very simple. It was also much cheaper than processing them regualrly. It also saved a lot of time over cropping and resaving, etc in photoshop.
Pam
pdrow is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Some Youth Symphony Photos SYS Performing Arts 4 11th of February 2007 (Sun) 20:41
Team Photos xcal007 Canon EF and EF-S Lenses 11 6th of February 2007 (Tue) 15:23
Backgdrop size for youth basketball team jdouglas003 General Photography Talk 7 4th of February 2007 (Sun) 11:08
Team photos.. Travis F The Business of Photography 3 26th of May 2006 (Fri) 19:27
Team Photos Burrellimages Small Flash and Studio Lighting 24 20th of October 2005 (Thu) 12:18
