Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of February 2005 (Tue)   #1
DionM
Default Macro Flash work
Hi all,
I was this close (very close) to buying the MR-14EX macro ring light. But the deal fell through and now I am rethinking it ... especially after seeing a few interesting brackets around this forum.
I also plan to upgrade my 380EX to a 580EX some time soon, as I can see the limits of my 380EX in some of my shots. I have the off-camera cord 2 (the curly one that works with E-TTL).
And then I saw a few links to some interesting butterfly brackets and the like.
So I am wondering if rather than getting the macro ring light, I would be better served getting a bracket to mount my flash over and near the end of the lens. I realise its not as 'neat' as a macro ring flash, but are the results still good? E-TTL would take much of the guesswork out of the whole affair, I guess.
My main interest is flowers, butterflies and small insects.
I guess the other factor is if I got the ring light, I would have to hold off on getting the 580EX, and I think the 580EX would help me a lot more with my other (non-macro) flash photography - more power to bounce with, better exposure, etc etc. So its a tough decision.
Comments? Anyone use a bracket for macro work rather than a macro ring light?
I have the 100 f2.8 macro, by the way.
Gallery
DionM is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #2
mbze430
mbze430's Avatar
Default Re: Macro Flash work
I personally am looking at the MR-24EX, but in the mean time I have 4x 580EX, so I might as well use them.
Since I do all my macro work on a tripod(heavy 180mm), I ususally use a remote TC-80N3 and hand hold my 580EX with a Lightsphere II with the dome on it. I just point it in the general area and use E-TTL to make the rest of the adjustments.
Here is a recent shot, though it is NOT a digital image. It was shot with a EOS 7e w/ NPS 160 film. The color is not exaggerated like with Velvia, it is very neutral tone from this film.
My Hub to my personal work (just click on the banners)
mbze430 is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #3
DionM
Thanks ...
That's an interesting point too ... the ring light is probably an easier thing to "hand hold" (yes I know, macro and handholding ... bad bad bad!) and maybe I should experiment with the camera on the tripod and handhold the flash.
I too have looked at the MR-24EX ... from all reports it is better than the 14EX and not that much more expensive (50% more).
Gallery
Old 16th of February 2005 (Wed)   #4
steven
One complaint I have heard about flashes like the 14EX is that pictures look flat due to no shadow lighting.
That is probably why the 24EX is considered a much better flash.
1Ds
Canon Lens
16-35mm L, 24-70mm L, 28-135mm IS, 50mm II, 70-200mm L ISf2.8, 100mm Macro, 100-400mm L IS
Sigma Lens
180mm Macro
steven is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #5
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
IanD sent me this last week: http://www.photosafaris.com/Articles...Flutterbys.asp
John Shaw's advice on shooting butterflies with a flash. He has some great suggestions, home-made bracket info, etc. Well worth reading.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #6
J Rabin
I suggested yesterday a poster learn here:
http://www.sphoto.com/techinfo/phot...loseupsandflash
J
J Rabin is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #7
darkdrakon
darkdrakon's Avatar
well flat lighting is kind of the point with ringflashes. also there is quite a learning curve with theses as well. I ues the MR-14Ex and am quite happy with it I decided on it over the MT-24 because I did not need the swivle lights nor the extra power for what I take pictures of. you need to look how you are going to use the ringlight before you buy one so you can get what's right for you. here is a link to check them out.
http://www.fredmiranda.com/reviews/showcat.php?cat=30
FM Reviews - Flashes
darkdrakon is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #8
Chris P Bacon
I've had the MT-24EX for a couple of months now and it's great, although it's expensive I think you can't go wrong with it if your into macro shots, you'd need a adaptor for the 180mm macro though mbze430 because it only fits 58mm lenses.
Chris P Bacon is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #9
stuartf287
It is wrong to assume that you can't get shadows with the MT-14 ringlight. I just bought the MT-24 but the owner's manual covers both units. You can set the lighting ratio between the two sides of the MT-14 ringflash from 1:1, 2:1, 3:1 through 8:1 and even 1:0 (i.e., one side of the ring doesn't flash at all). The booklet illustrates macro shots using different ratios with the MT-14 and the lighting isn't "flat" at all. You actually have a great deal of control over the direction of the lighting and the degree of shadow cast on the subject. The MT-24 allows for similar control over the lighting ratios between the two flash heads.
I'm really enjoying using and learning about the MT-24, but no one should shy away from the MT-14 out of fear that it can only be used to produce flat, shadowless lighting.
stuartf287 is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #10
DaveG
Originally Posted by DionM
Hi all,
I've always had a vague interest in a ring flash too, although I've suspected that it could be a one trick pony, all too easily. Anyway I've never thought that it was something that I'd like to spend a lot of money on.
After reading your post I went on the B&H site to see what was available and the Vivitar 6000AF TTL Macro Ringlight Flash caught my eye. It's $100 US and looks to me that it'd do what it needs too. I don't think that it has Wireless capabilities like some other flashes but I'm not sure it that means much.
I sort of want to say that this is all the money I'd invest for infrequent use, but I'd had any number of Vivitar flashes over the years so I know how reliable and tough they are. In any case this would be my choice.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
DaveG is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #11
iwatkins
Don't forget that Sigma now also have a ring flash out now. I've no experince of it, but it is out there.
Ian
iwatkins is offline   Reply With Quote
Old 16th of February 2005 (Wed)   #12
steven
Looked at the Sigma it is full E-TTL but at over $300 it is getting up there in price.
1Ds
Canon Lens
Sigma Lens
180mm Macro
Old 17th of February 2005 (Thu)   #13
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Macro work is fussy enough as it is - I'd really prefer E-TTL to GN calculations relying on my being within 1/2 in. or better of the right flash-subject distance or to hoping that the external sensor has picked the right subject for the auto-cutoff.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Some macro work with the Sigma 70-300mm APO DG Macro El Duderino Macro 4 7th of April 2007 (Sat) 13:01
Is this a good flash for Macro and will it work on Digital 350d? Ferco Macro 4 13th of December 2006 (Wed) 06:51
First try at Macro work i2iSTUDIOS Macro 7 19th of February 2006 (Sun) 16:57
Most flexible flash solution for tabletop macro work? iamnemo Macro 7 21st of December 2005 (Wed) 13:42
Macro Work $ Lens Options. 70-200 IS, 100mm Macro, 100-400L MadMesh Canon EF and EF-S Lenses 4 8th of August 2005 (Mon) 12:00
