Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 17th of February 2005 (Thu)   #1
Dare1325
Default Room enough for Studio setup
I want to setup a small studio in my spare room. I've saved some money for studio lighting and backdrops and perhaps another lens. My big concern before I make that investment is the size of the room: 12' x 13' with an 8' ceiling. What are your thoughts regarding that room size and what lighting equipment would you recommend. I've a 20D with 17-40L and 50 1.8. By the way, the room is painted white with dark green carpet. Thanks!
Dare1325 is offline   Reply With Quote
Old 18th of February 2005 (Fri)   #2
Mike Panic
Default Re: Room enough for Studio setup
your gonna be extremely cramped, to say the least, unless you plan on doing small scale product shots or macro work
if you intend on shooting people...get a friend or family member in there and hvae them stand about a foot away from the wall, now you stand as far away as you can and look at them thru your viewfinder... you'll prob find your shooting between 17-24mm or so on your lens. lighting will also be a huge issue since shadows are bound to hit nearly every surface
MikePanic.com photography | web design | social media | content creation
CripsyHundos.com instagram photos for your viewing pleasure
Mike Panic is offline   Reply With Quote
Old 18th of February 2005 (Fri)   #3
JohnEBongo
I think it depends on what kind of photography you are going to be doing. I just finished my space which is only a little bigger than yours. See it here: http://photography-on-the.net/forum/...ad.php?t=57943
I also had carpet, but replaced it with Pergo. I am planning on doing mostly kid photography and portraits. Some full lenth and group work would be difficult for me. I think if you know what you want to do and work within the size limitations of the space you will be fine.'
John
JohnEBongo is offline   Reply With Quote
Old 18th of February 2005 (Fri)   #4
Dare1325
Thanks for the info. Would you guys recommend I paint the walls a dark color? John, is the pergo on the floor only for convenience? I want to shoot children and perhaps small family groups, portraits, maybe seniors. But I can see that full length might be difficult.
Old 18th of February 2005 (Fri)   #5
JohnEBongo
I went with the Pergo mainly because I am using paper backdrops and I wanted a smooth, solid surface under it to keep wrinkles, holes etc from damaging the paper.
Old 19th of February 2005 (Sat)   #6
w10d
w10d's Avatar
Originally Posted by Dare1325
Would you guys recommend I paint the walls a dark color? .
Probably. But before you do, have a good play around with lighting, especially if you're lucky enough to have good daylight. I sometimes test models in my flat, using a room that's painted white. It's great for soft beauty lighting, but much harder to use with very controlled light - it just wants to bounce everywhere! But if you paint the walls dark, you may then find you use more & more reflectors. Try to find what suits your style before you open the paint tins.
The reason I mentioned daylight is that good daylight studios are generally painted white; when you've got good natural daylight in a space you normally don't want to dampen it with dark walls.
HTH
w10d is offline   Reply With Quote
Old 20th of February 2005 (Sun)   #7
Avalonthas
i dont think it will suit any type of medilling. However macro would be accomplishable.
DAD:
Canon 20D [Canon EF 300mm f/4L USM, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF 50mm f/1.8 II, Tamron 28-75/2.8 Xr Di, Speedlite 580EX]
Canon 300D Digitel Rebel [Same As Above]
ME:
Canon Powershot Pro1
Kodak Easyshare CX7430
Canon Powershot A200
Avalonthas is offline   Reply With Quote
Old 22nd of February 2005 (Tue)   #8
dlhedg
I am in the process ofbuilding a studio and also need help I have a 18x24 room. I need ideas on lighting and also colors can you all please help.
thanks
dan h
dlhedg is offline   Reply With Quote
Old 22nd of February 2005 (Tue)   #9
Mike Panic
dan - get 2, preferably 3 strobes, a backdrop stand or fasten a way to hang paper from the wall or ceiling... and you've got the goods
one strobe for front, one for hair and one for background illumination
Old 22nd of February 2005 (Tue)   #10
cactusclay
One main light (key) one fill light and or background /hair light.
cactusclay is offline   Reply With Quote
Old 22nd of February 2005 (Tue)   #11
w10d
w10d's Avatar
What type of photography are you most interested in doing in the studio?
Do you have the chance to use daylight?
Old 23rd of February 2005 (Wed)   #12
dlhedg
what brand of lighting would you all prefer something not very expensive. But not cheap either. I am planning on senior pictures. and family portraits
thanks
for all the help
dan h
Old 24th of February 2005 (Thu)   #13
w10d
w10d's Avatar
Can't help you much with brands, what's available depends where you are & we're not on the same continent.
Over here Elinchrom were selling the 500 monoblocs with a basic kit at very good prices, as the design was very old and still in production despite newer ranges being available.
Old 24th of February 2005 (Thu)   #14
Mike Panic
brand - alienbees - b800's are $279 - if you are a student (of any kind, at any school) and have a valid photo id they will give you a 10% discount
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sharing a Studio/Meeting Room Jono A Weddings and Other Family Events 1 19th of May 2007 (Sat) 05:39
Trying to get the hang of my living room studio. awad People 21 14th of March 2007 (Wed) 11:48
Bonus Room Studio burntpixel Small Flash and Studio Lighting 9 24th of January 2007 (Wed) 10:22
Light Room/Studio Tent xxsmiffyxx Small Flash and Studio Lighting 6 9th of January 2007 (Tue) 07:53
Is this room large enough for a studio??? Jeff H Small Flash and Studio Lighting 17 13th of August 2005 (Sat) 02:45
