Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Urban Life & Travel
Reply
Thread Tools Display Modes
Old 15th of October 2008 (Wed)   #1
D1337
Default The Rose Theatre
This is a somewhat new theatre we got here in Brampton, Ontario. The lights and fountain surrounding the front of the building can get some good picture results.
Website: http://jamesmillsphoto.com
Equipment: Canon Rebel XSi Gripped, 18-55mm IS, 50mm f/1.8 II, 28-135mm IS USM, 430EX II, B800 x2, Large Softbox, 2 Umbrellas, Cybersyncs
D1337 is offline   Reply With Quote
Old 15th of October 2008 (Wed)   #2
D1337
Default Re: The Rose Theatre
Bump up.
Old 16th of October 2008 (Thu)   #3
Subyn00by
Did you use a tripod? This is a great shot fo being handheld, if you used a tripod, you need to bump the iso up and close the aperture a little
- Canon EOS 5D
- Canon EF 16-35mm f/2.8L II
- Canon EF 50mm f/1.4
- Canon Speedlite 430EX External Flash
- Canon EF 70-200mm f/2.8L IS USM Zoom Telephoto Autofocus Lens (soon!)
Subyn00by is offline   Reply With Quote
Old 16th of October 2008 (Thu)   #4
JBlue
JBlue's Avatar
Awesome pic!
JBlue is offline   Reply With Quote
Old 16th of October 2008 (Thu)   #5
D1337
Yes, I did use a tripod.
Just wondering, what does the ISO do? I've been told so many different things it's ridiculous.
Also, "closing" the aperture would mean turning it down?
Old 16th of October 2008 (Thu)   #6
aewon
aewon's Avatar
closing the aperture means turning the aperture up, no? higher numbers?
the fountains look like flowers. nice pic!
aewon is offline   Reply With Quote
Old 16th of October 2008 (Thu)   #7
Darsk47
Darsk47's Avatar
The ISO value is a rating of the camera sensor's ability to pick up light. In film cameras it means the same thing, but it is the film's ability to pick up light, or its sensitivity.
The higher the number, the faster the ability. example - if you take a perfectly exposed shot at ISO 400, f4.0 1/400 shutter, and then took a second shot under the same lighting conditions and same settings except for ISO 800, your shot will be overexposed because your sensor caught the light faster on the revised settings.
The trade off is image quality. The higher you go, the noiser the picture gets (grainy) especially if you're cropping in tight on a subject. Top model pro cameras minimize this effect, but on most consumer models, the noise is easy enough to see, especially under low light and/ or long focal lengths.
"ISO" itself stands for International Organization for Standardization. There are a number of different standards written over the years to provide a the guiding value on film speed and now DSLRs. There is a lot of math and science behind it. I suggest you ask Mr. Google or wikipedia if you want to go deeper to understand the science behind it.
Darcy
7D, 30D, 24-70 2.8
L; 70-200 2.8L IS; 580EX II; a hearty laugh;
Pair of AB 800s & lots of other stuff 'n' junk.
POTN Fantasy Football; aka Wide Right (charter member & perennial also ran)
Darsk47 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Quasi Macro...but a rose is a rose... conbu19 Wildlife 5 11th of June 2007 (Mon) 15:38
Which Lens to take to the theatre? DenZ Canon EF and EF-S Lenses 12 25th of February 2007 (Sun) 21:15
Jim Rose Circus Sideshow - Footbridge Theatre, Sydney [not for faint hearted] RockSlut Performing Arts 12 18th of November 2005 (Fri) 07:38
Theatre Photography Paul Jordan General Photography Talk 5 14th of March 2004 (Sun) 14:07
