Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 20th of October 2008 (Mon)   #1
HHolland
Default Studio colors???
Can someone with an existing studio give me some tips about the best colors to paint a studio?? Thanks for your help!!
HHolland is offline   Reply With Quote
Old 20th of October 2008 (Mon)   #2
Hermes
Default Re: Studio colors???
Paint it dark grey or black and make sure there is enough room lighting to make up for this. White will reflect light and make your strobes impossible to control in a practical way. Any other colour will add an unwanted colour cast.
Hermes is offline   Reply With Quote
Old 20th of October 2008 (Mon)   #3
HHolland
Thanks!!
Old 20th of October 2008 (Mon)   #4
TMR Design
TMR Design's Avatar
I agree with Hermes but black can be quite gloomy. I went with a middle gray and it works very nicely. Mine is a fairly small studio and I don't have any trouble with control or unwanted reflections. White is not advisable unless you have a larger space and lots of gobos and flags for control. If you use gray be careful because many grays contain a small amount of blue which can add a color cast.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 20th of October 2008 (Mon)   #5
Mark1
Mark1's Avatar
Paint stores can match just about any color you want. So to make it easy take in a gray card and have them match it. This way it will be as neutral as you can get. Dont trust the paint catalog to tell you it is neutral. Be sure. A slight color cast will cause you many hours over time in PP just in trying to correct it . I prefer in a flat paint.
Keep in mind "Its not the camera, its the photographer" works just as well for bad pictures as it does for good ones.
www.the6by6frame.wordpress.com
Mark1 is offline   Reply With Quote
Old 20th of October 2008 (Mon)   #6
Fellipe de Paula
So the best color choice for studio walls is the "18% gray"?
www.fellipedepaula.com.br
Fellipe de Paula is offline   Reply With Quote
Old 20th of October 2008 (Mon)   #7
TMR Design
TMR Design's Avatar
18% gray doesn't enter into the color selection for your walls unless you plan on using it to set your white balance. We are suggesting gray simply because it's not black (which is gloomy and dungeon-like) and white (which is highly reflective). So gray is a happy middle ground without color.
Old 20th of October 2008 (Mon)   #8
Fellipe de Paula
Robert, the commonly backdrop named "studio gray" is of the same cast of 18% gray?
Old 20th of October 2008 (Mon)   #9
TMR Design
TMR Design's Avatar
Nope! Unless something is specifically manufactured and lableled as 18% gray you can't and shouldn't assume anything is 18% gray. As a matter of fact, many gray cards being sold are not even 18% gray. Studio gray is just a shade of gray and can certainly work for a white balance reference just as a white piece of paper can be used but you shouldn't bank on the fact that it is 18% gray.
I painted my walls with a pain called 'Gray Area' and while it is not 18% gray I've actually used it for setting white balance and gotten excellent results with very nice skin tones. Rendering skin is a very subjective thing any many people will tweak white balance in post even if they did have an 18% reference, opting for a more pleasing skin tone.
Old 20th of October 2008 (Mon)   #10
Mark1
Mark1's Avatar
I didnt mean 18% is the best. I simply meant cards that are printed specifically to be photo cards are a neutral gray. How dark or light you want it is your choice. BUT MAKE SURE IT IS NEUTRAL!!! I have seen paints labeled studio gray as well. They can vary in darkness. But most of them are in fact neutral. I just dont risk it, and have a gray card matched.
Old 20th of October 2008 (Mon)   #11
Fellipe de Paula
So the option for dark walls is to prevent unwanted light bounce... So with a "medium to dark gray" it will avoid that kind of unwanted reflection?
Old 20th of October 2008 (Mon)   #12
TMR Design
TMR Design's Avatar
Any color will reflect some light but the darker the color, the less reflection. Many people, including myself opted for gray walls, keeping the white ceiling. Reflection is minimized, the room still has some life to it and it works very well.
Old 20th of October 2008 (Mon)   #13
Mark1
Mark1's Avatar
Yes. Dark flat paint is best to kill reflections. And neutral colored paint will stop what is reflected from picking up a different color ballence that is possable to effect your images.
Old 21st of October 2008 (Tue)   #14
FlashZebra
This space available
FlashZebra's Avatar
Black walls for purists.
White walls for pragmatists.
Gray walls for those that cannot decide and want to have it both ways.
Enjoy! Lon
http://flashzebra.com/
FlashZebra is offline   Reply With Quote
Old 21st of October 2008 (Tue)   #15
TMR Design
TMR Design's Avatar
I made the conscious decision to not have black or white. I wanted gray and knew its properties. It was absolutely an educated decision
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Is this studio ligh kits good for home studio born2blove Small Flash and Studio Lighting 5 16th of September 2008 (Tue) 22:00
club pictures made studio into studio feel badgerstudios77 People 5 25th of April 2008 (Fri) 02:03
Oooh! Ahhh! The colors! The Colors! Billy D Wildlife 4 4th of November 2006 (Sat) 22:07
Fall Colors at my Favorite park- Unbelievable Colors- 3 photos EricKonieczny Nature & Landscapes 9 21st of October 2005 (Fri) 19:20
Studio Set up? SHOW YOUR STUDIO PICS :) kwang0429 General Photography Talk 1 8th of March 2005 (Tue) 09:26
