Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 27th of October 2008 (Mon)   #1
shutterfiend
Default 1 - Nikon SB-26 OR 2 - Vivtar 285HV ? Please help.
I'm going crazy trying to figure out why a used Nikon SB-26 should be almost twice that of a new Vivitar 285HV?
I'm not sure how I could use the built-in slave on the Nikon but there are more power settings, which is a plus. Otherwise both have pretty similar specs. (from what I could tell).
Am I missing something? Any help would be appreciated.
shutterfiend is offline   Reply With Quote
Old 27th of October 2008 (Mon)   #2
ekie
ekie's Avatar
Default Re: 1 - Nikon SB-26 OR 2 - Vivtar 285HV ? Please help.
if you dont need the built-in optical slave, you can always look for the SB28, which is similar but no optical slave. i have 3 of those which I prefer over the vivitars.
ekie is offline   Reply With Quote
Old 27th of October 2008 (Mon)   #3
MD Steelerfan
I have a reallu old SB20 and I like that better than my Vivitar. If you want to go on the cheap the Vivitar will work though.
MD Steelerfan is offline   Reply With Quote
Old 27th of October 2008 (Mon)   #4
PhatheadWRX
PhatheadWRX's Avatar
you can get a SB-26 for $120 on eBay.
That's only 113% of the vivatar.
frenchbrownphoto.com - flickr - stomping ground
Canon 40D
Sigma 10-20, Canon 18-55 IS, Tammy 28-75, Canon 100 macro, Canon 70-300 IS USM
Canon 430EX, Nikon SB-26
PhatheadWRX is offline   Reply With Quote
Old 28th of October 2008 (Tue)   #5
shutterfiend
Thanks for the responses.
ekk_xt, MD Steelerfan, what's better about the Nikon?
SB-24s go for about the same price as the Vivitars. I could get those if they are better.
PhatheadWRX, I've noticed that the ones that go for under $150 usually have some problem, like a stuck zoom or a missing slide-out panel. I'll keep an eye out anyway. Thanks.
Old 28th of October 2008 (Tue)   #6
ekie
ekie's Avatar
you have more variable power adjustments, smaller in size, and also easier to make modifiers for. also the nikon has the standard pc connector.
Old 28th of October 2008 (Tue)   #7
MD Steelerfan
I agree with ekk_xt. The only thing that is strange about the sb 20 is the shape of it. It is a kind of non standard. The other Nikon SBs are more standard looking I think.
I feel like the Vivtar controls are in a bad place for some strobist stuff. In a softbox far example, there is no way to see the control dial for the power without completely taking it out of the softbox. That is a real pain the in the Butt. The Canon and Nikon flashes have the control panel on the back so you can get to it easily. Also the fact that the Vivtar has a different connector is a pain. It also doesn't have 1/8 power for some reason. It only goes to 1/16 power as it's minimum which is the same as the SB20, but maybe not the same as some other SB models. My 580 goes to 1/64 power. That kind of precision is actually useful for strobist work.
Old 28th of October 2008 (Tue)   #8
yuriyo923
yuriyo923's Avatar
hm... I was looking for some 285hv as some cheap flash... I'll look into SB-28
Canon 5D2 ~ 40D + 17-50mm in da booth!
www.seattleboothrental.com
yuriyo923 is offline   Reply With Quote
Old 28th of October 2008 (Tue)   #9
shutterfiend
ekk_xt, MD Steelerfan, thanks. I think I'll have to look for some SBs now.
Old 28th of October 2008 (Tue)   #10
ekie
ekie's Avatar
if anything, you can try to find them at KEH.com .. they often have used ones there as well. i got two there and it works with no issues (so far .. *knock on wood*) lol
Old 28th of October 2008 (Tue)   #11
The_Duke_Of_Eli
Hi there.
I have all of the SB series (24,25,26,28) and the 285HV. The 285 is best found cheap and used. I wouldn't pay more than 50$ for one. Manually turning a knob in dark environments sucks. Plus, there's no 1/8th power. I have the ND filter for it (slot-ins that rock!) but that's really cumbersome. The SB-24s are cheap, but it only goes down to 1/16th power. The SB-26 is just a SB-25 with an optical trigger. I'd say buy an SB-25 and then buy a separate optical trigger for the hotshoe. It'll run <20$. I love the SB-28 because it's the smallest of the bunch.
The_Duke_Of_Eli is offline   Reply With Quote
Old 29th of October 2008 (Wed)   #12
shutterfiend
Thanks Duke, that was really informative. I saw a few listings for SB-28 but they're about the same price as the SB-26. I'm planning on getting cybersyncs so I wouldn't need the slave feature anyway.
I had a question about the delay setting on SB-26. How is that used? Also, is there a delay setting in any of the other one's?
Old 29th of October 2008 (Wed)   #13
turbodude
turbodude's Avatar
Originally Posted by The_Duke_Of_Eli View Post
Hi there.
heck yes!!! so do i, all the modifers i make for teh 580exs work on teh 28s. unlike the other SB flashes. and the power difference is nominal.
turbodude is offline   Reply With Quote
Old 29th of October 2008 (Wed)   #14
turbodude
turbodude's Avatar
its used for teh preflash of ETTL. it works, just if you plan on using manual everything with triggers anyway it would be of no use to you.
Old 29th of October 2008 (Wed)   #15
shutterfiend
Thanks turbodude!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Nikon SB-24 or Vivitar 285HV pbpancho Classifieds: Buy 1 21st of October 2008 (Tue) 02:50
Question about the Vivtar 285HV Vari-power sensor maxsoul Small Flash and Studio Lighting 4 20th of January 2008 (Sun) 17:45
Vivtar 730AFNi rohnds Small Flash and Studio Lighting 0 14th of September 2007 (Fri) 21:34
