#1 |
I use sigma 30mm 1.4 with XSi (450D). if I shoot stuff, it looks focus well. however, if i take photos of my son with big aperture like 1.4 to 2.0, it is so hard to get sharp pictures focusing on his face. about 1 of 10 is sharp.
the lens probably focuses OK because about 3 of 10 tests are good using f1.4 and a chart. my confusion is that when you use the central AF point to focus and recompose, doesn't it change a little bit. other word, is the fousing plane flat or an arch.? I normally handhold the camera, what speed is safe? when use F1.4, the DOF is so shallow. so the central AF point became a little too big for locating the focus point. also there is a small circle surrounding this point and a box outside. do those do some kind of focusing job as well? I normally put the AF on the middle of my son's eyes, but wonder is it possible the focus is moved to the eyes or lashes if those areas have more contrast. |
| sponsored links |
#2 |
Tip #1: Don't focus and recompose. Especially at somewhere like f/1.4 - you're absolutely looking for trouble there.
Secondly, you should be aware of the extremely thin DoF at f/1.4. I pretty much NEVER take portraits wide-open on my 35L - I'm not a real fan of the whole one-eye in-focus, nose outta focus etc. yadda. 1/50th should be relatively safe, but 1/60-1/80th is even better. |
#3 |
I learned something here.
I am not young enough to know everything. O.W. www.medjugorje.net *** Amateur tools *** |
| sponsored links |
#4 | |
#5 | |
"After 40 years still not housebroken, I still piddle on the carpet"
Focus/recompose is not a good technique with very large apertures, as Colin said. It'd work well if the focus "plane" were spherical, but it's not. Here's a good treatise on the subject: http://visual-vacations.com/Photogra...pose_sucks.htm -js
"Be seeing you." 50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash I do not piddle on the carpet! |
#6 |
Really? I assumed the 'plane' of focus would be curved like the inside of a sphere, so it covered points of equal distance (equal distance from what exactly eludes my limited knowledge of optics, I guess the focal plane?). Making it flat would be quite an optical trick. Perhaps it just looks flatter in macro shots as you're looking at a smaller area of the sphere?
Canon EOS 450D | Canon 18-55mm, 55-250mm, 50mm | 430EX |
#7 |
"...in too much trouble"
i find that the lens just needs to take some getting used to.
i have used f/1.4 several times, at slow shutter speeds and no tripod and got some pretty sharp images. it took a couple weeks for me to get used to it.. but i used it so frequently, its by far the best lens i own. shan |
#8 | ||
And yes, it's difficult to get this fairly-flat plane, especially with wide angle lenses. Quote:
At high magnification, up to 1:1, the very thin depth of field would make any deviation from a flat plane more obvious, not less. Flatness of field is most obvious when copying documents, not really at macro distances generally. The flatness of field is one reason macro lenses are more expensive than general purpose lenses. There are other unusual goodies in the 60 macro too, like a second diaphragm to control flare. It's a nice lens. -js
"Be seeing you." 50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash I do not piddle on the carpet! Last edited by number six : 30th of October 2008 (Thu) at 17:09. |
#9 |
I visualise the plane of focus like this: Think of a letter T, the horizontal line of which represents the plane of focus and the vertical line of which represents the distance between the subject and the camera. Swing the camera around just a few degrees in adjusting your composition, which moves the T around by the same angle, and the horizontal line is now shifted away from the subject and is effectively passing behind it. That line corresponds to the brick wall in number six's analogy. If the DoF is shallow enough, the shift will be visible and your shot is ruined. The fact that there is less DoF in front of the plane of sharp focus than there this behind it does not exactly help either, though this is much less the case at close subject distances.
www.dofmaster.com is worth using to help you to visualise DoF at a given focal length, distance, aperture, etc. |
#10 |
thank you all for those very helpful information.
now it's clear that the focus plane is perfectly flat generally. the best contrast pin point fall in one of the set AF areas or 9 catchment areas will be set as focus point. (the manual doesn't mention it but indicates this on P19) after more than one year possession of sigma 30mm 1.4, it's too late to know those basic knowledge but so helpful for afterward shots. |
#11 |
"hangs around male genitalia"
When focus is critical especially when using large apertures I find focusing manually works best..
Jurgen 50D~20D~EOS M~S95 http://www.pbase.com/jurgentreue The Title Fairy,, off with her head!! |
#12 |
i'm learning to use live view x10 and focusing manually. it looks it sorted my focusing difficulty no matter which f number used.
#13 | |
-js
#14 | |
"Got a thick monopod?"
With macros I always just find a working distance I like and then rock my body back and forth for focus. This won't work if you're light-limited and need huge shutter speeds though. OP: Since you mentioned focus&recompose, when you recompose, just flick the focus ring a little bit to bring it back into perfect focus. I never rely on autofocus with really fast lenses. |
#15 |
| Thread Tools | |
| Display Modes | |
| WTB: Sharp Sigma 30mm f/1.4 | darksparkz | Classifieds: Buy | 0 | 2nd of October 2008 (Thu) 21:16 |
| WTB- Sharp Sigma 30mm | chilli710 | Classifieds: Buy | 0 | 6th of February 2008 (Wed) 19:44 |
| sigma 30mm f/1.4 - sharp wide open? | bowlesbe | Canon EF and EF-S Lenses | 3 | 19th of February 2007 (Mon) 14:41 |
| WTB- Sharp Sigma 30mm 1.4 for Canon | chilli710 | Classifieds: Buy | 2 | 13th of January 2007 (Sat) 23:57 |
