Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Astronomy and Celestial
Reply
Thread Tools Display Modes
Old 31st of October 2008 (Fri)   #1
Jeff
Jeff's Avatar
Default A few from last night M27, M45, Perseus Cluster
It was a beautiful night but pretty windy which ruined most of the shots through the scope. Gotta get me one of those equitorial mounts
M27 - Dumbbell Nebula - Yeah, I know...yuck
M45 - Pleiades - Wish it had more of it's blue color
Perseus Cluster - Happy with this one
Jeff
50D Grrrrip'd | Tokina 12-24 | Canon 50mm f/1.4 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: Meade 10" LX200/UHTC, Orion 5" Mak, Vixen 80mm f/5, Coronado PST, Atlas EQ-G to keep it all off the ground.
MY AIRPLANE PICS | MY ASTRO PICS
Jeff is offline   Reply With Quote
Old 31st of October 2008 (Fri)   #2
Celestron
Default Re: A few from last night M27, M45, Perseus Cluster
Looks good Jeff , just needs some levels adjusting in the gray point and noise worked on some . That M27 is better than i have ever done . I've not been ale to attempt M27 for lots reasons . Mainly hard to see from my location because of LP . That last one is Mel20 in the Perseus constellation . I've done that before in the past and heres my image of Mel20 along with a jpeg image from Cartes Du Ceil program .
Ron
"Still Learning"
Flickr
http://home.grandecom.net/~r.hodges/
Celestron is offline   Reply With Quote
Old 31st of October 2008 (Fri)   #3
ebann
Once an ugly duckling
ebann's Avatar
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Originally Posted by Celestron View Post
[snip] ... and heres my image of Mel20 along with a jpeg image from Cartes Du Ceil program .
Cute little program! How does it compare with The Sky?
Ellery Bann
Fuji X100
E-PL2 | 14-42 | 20/1.7
7D | 24-70 ƒ2.8L | 70-200 ƒ2.8L IS | TS-E 24 ƒ3.5L | 85 ƒ1.2L
270EX | 2x 580EX | ST-E2 | Sekonic L-408 | MacBook Pro
ebann is offline   Reply With Quote
Old 31st of October 2008 (Fri)   #4
Nighthound
Given the conditions you still made good Jeff. The 10 inch LX200 is plenty solid feeling but it also offers up a lot of wind resistance and consequently shake. I generally shoot with my refractors unless there's little or no wind. Even the R200SS really grabs some air. Do you remove your dew shield when there's a breeze? It helps quite a bit up to a point.
Any plans for which GEM you might consider?
Steve
My Astro Gallery http://s3.photobucket.com/albums/y67...OTN%20Gallery/
Nighthound is offline   Reply With Quote
Old 31st of October 2008 (Fri)   #5
Jeff
Jeff's Avatar
I did last night but it was just too breezy. I then mounted the 70-200 on top with a little better success. One new toy I got to try was a wireless remote trigger and loved it. My hands got to stay warm in my sweatshirt pocket and still hit the trigger.
As far as a new mount goes I was looking at some Orion Atlas mounts - the EQ-G I think was the model. I've been using about 35-40lbs as a load for it to support. I'm thinking I'll be putting about $1000 into it. I'll most likely keep an eye out over the winter and get serious about buying in the spring.
Jeff
Old 31st of October 2008 (Fri)   #6
Celestron
Honestly i can't compare because i have never had the Sky ( more than i care to pay for a program that i won't use totally or enough) . I know lots ppl rave about the Sky program and how you can use it with go-to scopes . Also images of objects are real images in the Sky if i'm not mistaken and with CDC only the planet images are realistic and work with the animation part of the CDC program well . The main difference between the SKY and CDC is the price . CDC is a FREE program , the SKY has different versions i believe and cost different $$ . CDC is probably one of the most detailed planetary program available that is FREE . I would say that the TheSky6 program is probably the best program on the market to all public that still cost $ . Some telescopes came with some version of the Sky program and worked different so as far as to compare them , sorry but all i can tell you is what i know and have read about the Sky since i have never tested it .
Ron
"Still Learning"
Flickr
Old 31st of October 2008 (Fri)   #7
Celestron
Just to mention , Celestron just came out with a new CGEM Computerized mount probably in the same class as the Orion Atlas and pretty close to the same $$ . I only know what is readable , haven't read any reviews yet .
Ron
"Still Learning"
Flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
First Light for 50D! M45 The Pleiades markjpcs Astronomy and Celestial 18 24th of October 2008 (Fri) 15:24
First light for 50D! M45 markjpcs Astronomy and Celestial Talk 0 4th of October 2008 (Sat) 23:32
M45/Pleiades R Hardman Wildlife 1 10th of November 2007 (Sat) 19:33
Cluster fly racketman Macro 4 29th of March 2006 (Wed) 17:46
Astrophotography w/300D - M27 Dumbell Nebula vwestervelt Canon EOS Digital Cameras 28 11th of October 2004 (Mon) 13:56
