Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 2nd of November 2008 (Sun)   #1
canon shooter
canon shooter's Avatar
Default Alien Bees Cybersync wireless
Using the Cybersync to fire WL5000 and 580EX.
Wanted to set up so the master was the WL5000, but for some reason could not get the 580EX to fire as the Slave. Don't seem to have any problem firing the WL5000 as slave from 580. Hooked the Cybersync up to the 580EX and it fires the flash fine and in turn the WL5000 fires as slave.
I don't think I even set the 580 as master, just let that flash fire, triggered by the Cybersync, and the auto slave of the WL, fired the WL.
The WL seems to fire fine as slave with the built in auto slave.
Does the 580 need to be facing the WL to fire as slave? The WL was fired through white umbrella straight on. And the 580 was fire away from the subject into a silver umbrella.
Jim
5D Mark III Grip, 40D Grip, 20D, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts! Visit http://www.genphotosaz.com
canon shooter is offline   Reply With Quote
Old 2nd of November 2008 (Sun)   #2
dshankar
Default Re: Alien Bees Cybersync wireless
The red "box" in front of the 580 EX needs to see the light from the WL5000. So turn the body of the flash so that the "red box" faces the light coming from the WL5000 - i.e. there needs to be a line of sight between the light and the 580EX sensor.
If the WL5000 fires through umbrella, the light reflected off something needs to hit the 580EX sensor in order for the 580EX to trigger and fire as well.
dshankar is offline   Reply With Quote
Old 2nd of November 2008 (Sun)   #3
Titus213
Titus213's Avatar
Sorry, the WL5000 won't fire your 580EX unless it can transmit ETTL compatible signals. If it can Paul Buff will make a real fortune.
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Old 2nd of November 2008 (Sun)   #4
dshankar
It can....
The 580EX can be triggered by the WL5000 if it has an optical slave trigger attached to it.
An example of an optical slave trigger would be the Wein Optical Peanut triggers.
The WL5000s have built in optical slave triggers, thats why it works the other way around with the WLs as slave and 580EX as master.
Old 3rd of November 2008 (Mon)   #5
Titus213
Titus213's Avatar
Canon EX flashes are notorious for not playing nice with optical triggers.
Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
alien bee - cybersync - thoughts? Sancho Small Flash and Studio Lighting 17 24th of September 2008 (Wed) 17:15
Alien Bees CyberSync™ Battery Powered Trigger Receiver aridan Small Flash and Studio Lighting 2 29th of June 2008 (Sun) 18:15
Best way to trigger my alien bees wireless? Photolistic Small Flash and Studio Lighting 11 5th of February 2007 (Mon) 11:40
Alien Bees wireless Action Taken Small Flash and Studio Lighting 15 21st of February 2006 (Tue) 00:12
4 Alien Bees, L-358, Wireless Bee Package and CONFUSION!!! RTMiller Small Flash and Studio Lighting 22 26th of January 2006 (Thu) 09:34
