Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 3rd of November 2008 (Mon)   #1
hockeyshooter
Default Fluctuating pictures quality
I shoot a lot of hockey pictures with my Canon 40D. I have noticed at times when I shoot a burst of pictures, say 5 to 10, that at times, that I will have completely different looking pictures, despite that fact that they are taken so close together. One will look perfect, then the nxt one will have a pinkish hue to it, then the next one is perfect. Is there something causing the White balance to alternate?? I cannot figure why the camera would be doing this. Any ideas? I have been shooting mostly in Program mode.. then setting the ISO anywhere from 1000 to 3200, depending on the arena.
hockeyshooter is offline   Reply With Quote
Old 3rd of November 2008 (Mon)   #2
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Default Re: Fluctuating pictures quality
May be a couple of reasons:
- The lights themselves may be cycling their color (really...) and you're catching them on even/odd cycles.
- Are you shooting in Auto White Balance? Try setting one custom white balance off a grey card and use that for the whole game.
FlyingPhotog is offline   Reply With Quote
Old 3rd of November 2008 (Mon)   #3
eigga
eigga's Avatar
yep, light cycling. Only way to avoid this is to add flash. Otherwise you just have to edit
-Matt
eigga is offline   Reply With Quote
Old 3rd of November 2008 (Mon)   #4
FlyingPhotog
Cream of the "Prop"
Isn't there a way to avoid the cycle by either matching or cancelling it by shutter speed...
(Suffering a brain fade at the moment...)
Old 4th of November 2008 (Tue)   #5
eigga
eigga's Avatar
Yes, but I think the required shutter to achieve that is around 1/40... basically usesless for sports.
Here is a good read on the issue...
http://www.sportsshooter.com/message...html?tid=20873
-Matt
Old 4th of November 2008 (Tue)   #6
scot079
scot079's Avatar
I think you can shoot 1/120 and you'll only see 2 cycles in your photo...or something like that.
- Tim
scot079 is offline   Reply With Quote
Old 4th of November 2008 (Tue)   #7
hockeyshooter
Thanks. I had never heard of that before, but it sounds possible. I shoot mostly in AWB. I suppose I should adjust it to match the ice. I've tried it set to various light sources and never liked any of the results from those tests.
Old 4th of November 2008 (Tue)   #8
dmwierz
dmwierz's Avatar
Whenever your shutter speed exceeds the frequency of the AC, you run the very real risk of seeing light cycling. No amount of Custom White Balance will eliminate this.
You can, however, do a CWB with your shutter speed set to 1/60s or less to ensure your white balance is OK when you're not getting the impact of the color cycling.
This topic is dicsussed at length in episode 3 of this podcast:
http://www.sportsphotographycast.com
As mentioned above (and in Guy Rhodes' SportsShooter post), if you overpower the AC lighting with flash or strobes you can totally eliminate this color cycling.
Ain't this fun?
http://www.denniswierzbicki.com
http://www.sportsshooter.com/dmwierz
Dennis "
Yeah, well, sometimes nothin' can be a real cool hand."
dmwierz is offline   Reply With Quote
Old 4th of November 2008 (Tue)   #9
hockeyshooter
If white balance adjustment is not the answer, it looks like I may just have to live with it. I can edit them to some degree after. It would be easier not to have too. I am only talking about a very small percentage of my pictures. I was just wondering if it was something I had done wrong, or some setting I had accidentally hit.
Old 4th of November 2008 (Tue)   #10
PhotosGuy
Moderator
PhotosGuy's Avatar
It's just something you have to live with unless you can kick in just a touch of fill flash.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 5th of November 2008 (Wed)   #11
mpeters
Shoot RAW, fix in post....or shoot at 1/500th and always shoot 9 frame burst. 1 will be right (that's a joke BTW.)
You can find the color shifts by simply pointing the camera and the ceiling so that the lights are not in the frame and shooting a 6-8 shot burst.
Even worse - they don't all cycle together...
mpeters is offline   Reply With Quote
Old 30th of November 2008 (Sun)   #12
pwrmac
pwrmac's Avatar
The lights usually cycle at around 60Hz and any shutter speed divisible by 1/60 can get you correct exposures more consistantly. Other than that fire away and cross your fingures that "the Shot" hit the brighter light cycle.
Canon 50D | Canon 24-70 2.8L | Canon 70-200 2.8L IS | Canon 580ex II | Sigma 500DG Super
pwrmac is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How to take quality pictures edave Canon EOS Digital Cameras 18 7th of July 2007 (Sat) 09:39
S3 poor quality pictures...??? andy_fozzy Small Compact Digitals by Canon 23 1st of May 2007 (Tue) 20:52
How Do I Get Good Quality Pictures Without A Flash mrterrible Canon EOS Digital Cameras 9 26th of November 2006 (Sun) 03:49
Does Compressing Pictures decrease Quality? Zakary The POTN Lounge 6 1st of February 2006 (Wed) 21:36
Same quality pictures with XT or 20D ? boqueron Canon EOS Digital Cameras 10 13th of May 2005 (Fri) 08:53
