#1 |
I've been thinging again, sorry. Here is what I wonder about. If I'm shooting say a basketball player running toward the area I'm standing and I press the button, when the focus occurrs there is a slight delay (albeit slight) before the shutter activates. Will the subject be out of focus because of the slight lag?
"If you want to buy happiness, spend kindness" EOS Rebel 300D X 2, 30D gripped, 50mm f1.8, 18-55mm f3.5-5.6 and 75-300mm f4-5.6. 85mm f1.8. Just getting started. Upgrades will come as I learn more. |
| sponsored links |
#2 | |
Next is unfortunately experimentation, but running towards you is easier than running at right angles across your field of view. So you should be ok but you do need to know how your camera is going to react. One trick is to prefocus at a point and then take the shot as the moving object hits that point, the object should be then in focus but you may get blur from its movement, depending on your shutter speed. I used a very slow Fuji s304, for a couple of weeks the photo I took, and the photo I got were quite different, in fact I blurred some shots because I did not wait long enough for the camera to do its job, took it away from my eye before it had finished recording I took this shot on that same Fuji http://www.flickr.com/photos/chriswa...24440/sizes/o/ I focused on the cross bar, held it, and took the shot while she was doing her run up, seriously, then held the camera still until she landed. So a lot of it is about timing and knowing your camera. The 300d should by no means be as slow as that
Gear- 400D, kit lenses Dell dim2400 on XP My flickr pics http://www.flickr.com/photos/chriswaynz/ My no longer used flickr http://www.flickr.com/photos/chriswaypix/ Last edited by kiwichris : 8th of November 2008 (Sat) at 07:19. |
#3 |
There's Moderators under there....
This spec is for the XTi but I don't think it should not be much different than your 300D.
Soft-touch electomangetic release; shutter "lag time" approx. 100 msec. That should be fast enough for all but speeding bullets. |
| sponsored links |
#4 |
Thanks guys. I wasn't aware the lag was that short. It seems like forever when your worrying about, ha ha....
That is a relief.
| Thread Tools | |
| Display Modes | |
| My brand new 70-200 2.8 IS making odd click noise on focus stop | Nick G | Canon EF and EF-S Lenses | 8 | 6th of April 2008 (Sun) 14:17 |
| S3 auto focus delay with flash on | DanteCaspian | Small Compact Digitals by Canon | 3 | 24th of June 2007 (Sun) 08:26 |
| numbers to quantify digital view screen delay and shutter delay on compact cameras | pcDigiMan | Small Compact Digitals by Canon | 1 | 24th of September 2005 (Sat) 07:00 |
| shutter delay & poor focus | fmarotta | Canon G-series Digital Cameras | 1 | 29th of September 2003 (Mon) 22:01 |
| s50 focus delay? | tfmccull | Small Compact Digitals by Canon | 1 | 15th of September 2003 (Mon) 02:16 |
