Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 8th of November 2008 (Sat)   #1
James M
James M's Avatar
Default Lens combo for airshow
Would a 400mm 5.6 L + 1.4x still Ai Servo ok on a 1D mkIII using the the center point assuming the weather is ok?
1D Mk III | 85mm f1.2 L II | 70-200mm f2.8 L IS | 17-40mm f4 L | 400mm f5.6 L| 1.4x II | 580EX II
James M is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #2
andrewhuxman
andrewhuxman's Avatar
Default Re: Lens combo for airshow
I would think that would be good if the light is good but its the UK and its cloudy quite often and dont they fly closer? So you might not even need the 1.4 on there at all.
A little L goes a long way.
Canon 7D,40D, gripped,16-35MM 2.8L,24-105MM F4L,70-200MM 2.8 IS USM L,500MM F4L
www.machtwomedia.com
andrewhuxman is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #3
Benjybh
Benjybh's Avatar
To be honest 400mm is more than enough on 1.6x at large venues, and too big for smaller airfields such as Duxford. On 1.3x I would have thought it would be great as-is.
flickr
gear
website
Benjybh is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #4
PhotosGuy
Moderator
PhotosGuy's Avatar
Take the TC just in case you need to use it. Marauder61 likes tight shots:
http://photography-on-the.net/forum/...5&postcount=17
Airshow guys - prop freeze?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 11th of November 2008 (Tue)   #5
chris78cpr
I just got back from Vegas where i shot Aviation Nation at Nellis on Saturday and i used my 1dmkii with 100-400 for pretty much everything. I found the range perfect for shooting the Thunderbirds in single and formation moves, the raptor, and the various other aircraft.
I think just 400 on a 1.3 would be too limiting. Maybe think about your 70-200 with convertors or borrow/rent a 100-400.
Chris
Canon 5dmkii | 7d | Canon 1dmkii | Canon 400D | Canon 10D | Canon 1VHS | Canon Eos 3 | 17-40F4L | 24-105F4LIS | 70-200F2.8LIS | 100-400LIS | 15F2.8 | 20F1.8EX | 50F1.4 | 85F1.8 | 100F2.8 Macro | 2 x 550EX | 1.4xII
Hasselblad 500CM | 80mm F2.8 CFE | A12 back | WLF
chris78cpr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2 Lens combo... Jimmer411 Canon EF and EF-S Lenses 11 10th of July 2008 (Thu) 15:50
Airshow Lens Combo adam LC Transportation Talk 23 14th of June 2008 (Sat) 19:41
Lens combo Sickness Canon EF and EF-S Lenses 15 24th of September 2007 (Mon) 11:52
Which Lens combo is most used for MS? michael_ Canon EF and EF-S Lenses 7 16th of April 2007 (Mon) 09:47
Lens Combo R1200C Canon EF and EF-S Lenses 8 28th of November 2006 (Tue) 22:59
