#1 |
Thought you guys in this part of the forum might know a little more about this. What tripod heads would you recommend for a camera like the 5d II for video?
Thanks! |
| sponsored links |
#2 |
Cream of the "Prop"
Depends on how much glass you hang off the front.
Smaller glass would be fine with just about any mid-grade video pan head. As the glass gets bigger, give more consideration to fluid heads as they dampen motion better and allow for more aggressive drag settings. You actually want to have a little tension to work against so the camera doesn't wander on you.
"If you aren't getting extraordinary images from today's dSLRs, regardless of brand, it's not the camera!" - Bill Fortney, Nikon Corp. |
#3 |
Thanks for the reply FlyingPhotog
Do you have any specific models you can recommend of both? I'm not really sure what a midgrade pan head consist of |
| sponsored links |
#4 | |
Cream of the "Prop"
This is the link to the Bogen/Manfrotto "Consumer Video" section at B&H which should give you some idea of what's available at a "moderate" price point. http://www.bhphotovideo.com/c/shop/5...d_Systems.html One thing I can tell you is you do need to pay attention to the reccomended weights that can be supported. If you go too heavy, a fluid head can begin to bind and that defeats the purpose of having a fluid head .. Smoothness... Pro gear can easily run $5K and up with full on pedestle systems costing upwards of $50K Sorry I can't be of more help off the cuff... Good Luck
#5 |
I have no experience with video, but I intend to change that with the 5DII. Looking around on B+H, I found this:
http://www.bhphotovideo.com/bnh/cont...s=REG#features It's rated for 18 pounds. Is that okay? Too much?
There are no rules for good photographs, there are only good photographs. ~ Ansel Adams Gear |
| Thread Tools | |
| Display Modes | |
| does anybody us a video head on there tripod? | midlife_crisis | Accessories & Storage | 1 | 11th of July 2007 (Wed) 03:14 |
| Need a recommendation for a tripod head for video | dtrayers | General Photography Talk | 0 | 9th of February 2007 (Fri) 10:04 |
| Those of you who use Manfrotto 501 video head.. | Amorous | Accessories & Storage | 11 | 8th of August 2006 (Tue) 17:50 |
| Head for photo and video? | DEMO | Accessories & Storage | 5 | 17th of May 2006 (Wed) 12:21 |
