Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Astronomy and Celestial
Reply
Thread Tools Display Modes
Old 8th of November 2008 (Sat)   #1
Celestron
Default Uranus & Star 96 Aquarius
Last night i finally got out with the C8 SCT Celestron f/10 , on an EQ mount . Attached the Rebel 300D up PF and shot 29 images of Uranus and the Star 96 Aquarius which at the moment is just east of the constellation Aqurius . The moon was bright , sky clear , transparency clear but seeing was not as good . Therefore caused alot of distortion on a planet so far away . In order to capture color without burnout i had to shoot 26 x 1/15th-sec shots and for disc shape 3 x 5-secs . Out of 29 images only 22 were worth stacking which i did manually in PS7 and extra PP for final image . Each image was cropped @ 50% before stacking . If you know where to look you can see Uranus in binocs but most likely you will not see color correctly . This is definitly a scope object with alot of patience . However looking at Uranus in a scope with high power Eye-Pieces sure makes for a night of viewing ! Hope you enjoy & C&Cs' welcome ! Also i have included a jpeg copy from Cartes du Ceil program showing the moon location last night and marking Uranus for directions .
Ron
"Still Learning"
Flickr
http://home.grandecom.net/~r.hodges/
Celestron is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #2
Nighthound
Default Re: Uranus & Star 96 Aquarius
Wow, talk about solar system and deep sky distant. Great job Ron.
So glad you were able to get out and enjoy some imaging and the night sky.
Steve
My Astro Gallery http://s3.photobucket.com/albums/y67...OTN%20Gallery/
Nighthound is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #3
bowtie`
Cool shot. I really like the color. Amazing the detail a little 8" can get.
bowtie` is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #4
Celestron
Thanks Steve ! Mainly i was shooting for the moon but was checking out CDC and saw that Uranus was close by decided to give it a try and this is what the results were . Most here probably wont think too much of this image but if they are aware of the distance and detail about Uranus then it might make them more interested . I usually look for Uranus every year and get excited to just see it . Still trying for Neptune and it's close by but haven't tried for it yet , but hope to someday . In one image that was 5-secs with burnout i actually got one moon to show tho . Also got the companion to 96 Aquarius show up a little .
Ron
"Still Learning"
Flickr
Old 8th of November 2008 (Sat)   #5
Tumbl3w33ds
Tumbl3w33ds's Avatar
Good job! Great color.
Deb
Canon 40D | Canon 30D
Canon EF-S 10-22 | Canon EF 24-105 4L IS | Canon EF 50 1.4
Canon Speedlite 580EX II
| Manfrotto tripod
Celestron 6" EQ Scope | Nikor 12Xx40/55 Binoculars | Nikon Coolpix S4
Zenfolio stuff
Tumbl3w33ds is offline   Reply With Quote
Old 8th of November 2008 (Sat)   #6
Celestron
Thanks bowtie ! Actually the 8" SCT is probably more common in DSO than most other scopes , mainly because of the price and second cause it's minimum size for lot's of DSOs' , and it's ease of transportation . Neptune is also close to resemblance only smaller and blue in color . Here is the original 5-sec shot which shows a companion to 96 Aquarius and one of Uranus moons called Ariel . Uranus is blownout from too long of exposer . I'm also including images from Cartes du Ceil program showing Neptune inset with Uranus . The moon belongs to Uranus .
Ron
"Still Learning"
Flickr
Old 8th of November 2008 (Sat)   #7
Celestron
Thanks Deb !
Ron
"Still Learning"
Flickr
Old 9th of November 2008 (Sun)   #8
txcwboy
txcwboy's Avatar
I have a 8" SCT but never tried to see Uranus. I ll have to check it out. ( That was hard to say without cracking up ) Nice shots
Dave
Canon 50D
Canon 28-135
Canon 50mm 1.4
Canon 75-300
txcwboy is offline   Reply With Quote
Old 9th of November 2008 (Sun)   #9
Celestron
Thanks Dave ! The moon will be fuller but farther away so maybe it will be easier to find . Good luck and let me know if you find it .
Ron
"Still Learning"
Flickr
Old 9th of November 2008 (Sun)   #10
Adrena1in
Cool, I've yet to view or see Uranus, (I assume). Wanted to go out the other night as the moon was occulting Uranus the other night, (well, not quite an occultation from where I am, but it was for the north of the UK), but as usual the weather put paid to it.
Great capture.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
Adrena1in is offline   Reply With Quote
Old 9th of November 2008 (Sun)   #11
Celestron
Thanks Adrena1in ! It's alot easier to see when the moon is gone or not close by . It doesn't shine like a star , or as bright as a star . Disc shape is very distinct tho and color can be seen but not deep color like my first image . If you have never seen either of the two i highly recommend them . Eventually i will find Neptune tho !
Ron
"Still Learning"
Flickr
Old 9th of November 2008 (Sun)   #12
txcwboy
txcwboy's Avatar
i printed a map but I am not familiar enough with the sky as I should be and I couldnt find it. I was looking South about 20 degrees up ? I just dont know what I should be looking for. I saw Jupiter and Saturn . where is it from those ?
Dave
Canon 50D
Canon 28-135
Canon 50mm 1.4
Canon 75-300
Old 9th of November 2008 (Sun)   #13
R Hardman
R Hardman's Avatar
Nice capture!
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert
R Hardman is offline   Reply With Quote
Old 10th of November 2008 (Mon)   #14
Celestron
Thanks Rick !
Txcowboy , heres a map from my Cartes Du Ceil program . I have Uranus marked . At this size of map Uranus and 96 Aquarius look like one star but they are seperated over a 1/2-deg from each other in the EP . Hope this helps some .
Ron
"Still Learning"
Flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Halloween Pop Star & Army Girl emnmandasmom People 4 31st of October 2007 (Wed) 15:45
star &rope, not sure what to title it neil85 Still Life, B/W & Experimental 2 25th of August 2007 (Sat) 12:07
Star Performance & TVR tracknight 4hero Motorsports 5 8th of April 2007 (Sun) 19:45
Movie Star & Nature Boy Dante King People 18 10th of October 2006 (Tue) 21:21
Star light star bright... bvi steve General Photography Talk 0 17th of December 2005 (Sat) 09:18
