#1 |
Hi Everyone,
I have been asked to take some pictures at an outside, late night party. There will be some light from a bonfire, but unless the guests are close to the fire I don't think I will be able to document the party without using flash. I have a 30D, 550EX, and the 17-85 EFs lens. If using the flash, should I crank up the film speed to 1600 (or H), and with my camera on P try and capture as much ambient light as possiible, or should I try some other approach? Thanks, ~Dom
Digital: 5D, 50mm f/1.8 Mk 1, 85mm f/1.8, 17-40L, 24-105L, 70-200L f/4, 580EX, 580EX ii Film: AE-1, A-1, M6
| sponsored links |
#2 |
The 17-85 will not be cabable of shooting in such low light without a flash, as you've already stated.
I'm sure that most people will agree with me that you should shoot this in manual, not P or Av/Tv. This is because in P/Av/Tv your camera will try to capture the correct exposure but using the flash only as "fill flash". This will result in slow shutter speeds and blurry images (even at ISO1600). (This could be an effect you might desire, if people are dancing and you want to capture the motion. ) Shooting in manual will allow you to crank up the shutter speed to 1/200 for example, and the flash will pump out the light needed for the proper exposure. If it is too dark/bright then adjust the flash exposure compensation (FEC). I would shoot between ISO400 and ISO800 for reduced noise. The higher the ISO you use, the more ambient (background) light you will capture relative to the subject you are aiming at.
5D, 30D, Powershot S100 Sigma 24-60 f/2.8-SOLD.. Sigma 50mm f/1.4 . Canon 85mm f/1.8 http://dstanic.zenfolio.com twitter.com/DStanicPhoto |
#3 | |
Moderator
Got time to run a test? See post #3 Tips for Xmas Ball Please
FrankC - 20D, RAW, Manual everything... Classic Carz, Racing, Air Show, Flowers. www.FrankCizek.com Find the light... A few Car Lighting Tips, and MOVE YOUR FEET! Have you thought about making your own book? // Need an exposure crutch? |
| sponsored links |
#4 |
Hi,
Thanks for the replies. I have bookmarked the suggested postings and I am finding them useful. This evening I will go out and take a few test shots, in Manual mode! ~Dom
#5 |
THe 17-85 is too slow an apeture to take night fire pictures. You'd need a 50 f1.4 or 30 f1.4 shooting wide open at either iso1600 or 3200 depending on the brightness of the bonfire. But an external flash outdoors at a fire may be a tricky thing not to get too much flash since the camera is going to meter a lot of blackness.
#6 |
f/1.8 is almost a must. Get the 50mm f/1.4 but use it at f/1.8. DOF at 1.4 is paper thin - 1.8 and 2.0 are much more tolerable.
50mm f/1.8 is a bare minimum, in my opinion. Don't worry about shutter speed. Use an ISO around 640-800, and shoot in AV mode f/1.8 or 2.0 with flash in ETTL. If you're comfortable, go full Manual in both camera and flash. The reason I say don't worry about shutter speed is obviously because the flash helps to freeze action, and with good hands, shake is not too bad. I've shot sharp images at 1/3rd and 1/5th of a second with a flash filling in (I primarily used ambient light). ISO 800, and it worked well. ![]() http://flickr.com/photos/dshankar/2563162770/ I shot at 1/15th of a second, f/1.4 (I regret this, I should have used 1.8 ), and 640 ISO. I could have gone for a slower shutter speed, cranked the aperture down, and even knocked ISO higher since noise is very minimal. Last edited by PhotosGuy : 10th of November 2008 (Mon) at 17:23. |
#7 |
Thanks for the replies and suggestions. I think the 17-85's aperture is somewhat limiting for bonfire pictures, an looking over my library I can see that low light/flash photography of groups is something I have perhaps been struggling with for a while now.
I already have a 60mm f/2.8 macro, but have found it slow in focusing in dim light. What I think I am reading is that the 50mm f/1.4 be the way to go. Is this OK with a 1.6 crop camera when photographing groups? Thanks, ~Dom
#8 |
Yes, just step back a little. You have to be a good 4 feet from two people for a group shot, 6-10 feet if you wanna get 6+ people. It depends on how you arrange the people, but its not very wide.
On a crop, its a small telephoto... |
#9 |
Here's some of my campfire pix if you are interested. Too blurry without a flash, if you are particular. I don't care for flash for family and candids, so I'm willing accept a lack of sharpness, and a low keeper rate to get the color and dimension I like. Taken with my 40D. Most at ISO 1600 @F/1.8 Av between 1/8 and 1/30
#10 |
I would always use a wide aperture lens, a medium ISO of around 800-1000 and then use a flash aswell on second shutter sync.
Chris
Canon 5dmkii | 7d | Canon 1dmkii | Canon 400D | Canon 10D | Canon 1VHS | Canon Eos 3 | 17-40F4L | 24-105F4LIS | 70-200F2.8LIS | 100-400LIS | 15F2.8 | 20F1.8EX | 50F1.4 | 85F1.8 | 100F2.8 Macro | 2 x 550EX | 1.4xII Hasselblad 500CM | 80mm F2.8 CFE | A12 back | WLF |
#12 |
Yeah flash would have definitely helped you in those shots. Flash doesn't always = hard, cooked light that burns people's faces...
#13 |
Great pics. Thanks for sharing. These are all handheld, witout flash. I do like the campfire atmosphere the pictures show.
~Dom
#14 | |
Thanks! ~Dom P.S. -=HERE=- and Tips for Xmas Ball Please are two great threads. Thank for sharing!
| Thread Tools | |
| Display Modes | |
| A night shot high ISO pictures, far north! | garrinn | Urban Life & Travel | 0 | 25th of April 2008 (Fri) 18:13 |
| direct flash vs high iso | psxindo | Weddings and Other Family Events | 13 | 2nd of May 2007 (Wed) 05:34 |
| Night Time - PARTY Photography | AUSTRALIAN_kid_29 | General Photography Talk | 20 | 18th of November 2006 (Sat) 17:15 |
| Karting at Night - High Iso, High Noise! | Ves | Motorsports | 7 | 5th of November 2006 (Sun) 11:49 |
| TAKING PARTY PICTURES of people at night time | AUSTRALIAN_kid_29 | General Photography Talk | 8 | 20th of October 2006 (Fri) 08:49 |
