Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > HDR
Reply
Thread Tools Display Modes
Old 11th of November 2008 (Tue)   #1
jsinon
Default CS2 Merge to HDR command, what am I doing wrong?
I'm trying to try my hand at HDR and I keep getting an error message saying there "isn't enough dynamic range to create a useful HDR image". I've been using a twice processed single image if that makes any difference at all. Here is the image I was playing with(this version has had the exposure brought down a little). I was trying to bring out the blue in the sky (-2 stops ) and bring out the shadows ( + 1 1/2 - 2 stops ) and merge the two. No matter how many ways I set the exposure I get the same message. I may spring for some HDR if I absolutely have to, but if I can get what I already have to work that would be preferred. Please help.
Jeff
Canon 7D, 17-40L, 70-200 f2.8L(For Sale), Gitzo GT2541 with Acratech Ultimate ballhead.
http://www.jeffsinon.com/
http://jeffsinonphotography.wordpress.com/
jsinon is offline   Reply With Quote
Old 11th of November 2008 (Tue)   #2
bfreas
Default Re: CS2 Merge to HDR command, what am I doing wrong?
You'll need to do a "Save for Web" in Photoshop to kill the EXIF data when saving the different exposures.
Photoshop reads the camera data in the EXIF and it sees that they both used the same exposure settings (shutter speed, aperture, ISO) so it thinks there isn't enough dynamic range for a useful HDR.
bfreas is offline   Reply With Quote
Old 11th of November 2008 (Tue)   #3
jsinon
Thanks for the reply. I was wondering if it had something to do with all the images originating from the same image.
Old 11th of November 2008 (Tue)   #4
canonloader
canonloader's Avatar
Well, it does. That's what he just said. Each copy you make, still has the same EXIF data attached, and that's what CS2 is reading when it loads them. It thinks it's loading the same image. While you did change them, you did not change their EXIF Data.
Mitch- ____...^.^...____
My Microscope Stuff
Gear List, My Flash Gallery, My You Tube, Ride My Bi-Sickle
canonloader is offline   Reply With Quote
Old 12th of November 2008 (Wed)   #5
René Damkot
Moderator
René Damkot's Avatar
Alternatively (if you don't want to save a jpg, using save for web), open a blank document, and copy the file into that. You'll also loose the EXIF, but can use tif.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PS CS2, "Cannot Merge to HDR because a Command is not Available kai-chun RAW, Post Processing and Printing 11 18th of April 2011 (Mon) 16:27
How do you merge images in CS2? Ianfp RAW, Post Processing and Printing 6 11th of February 2008 (Mon) 07:45
Merge to HDR? Travis F RAW, Post Processing and Printing 14 9th of November 2006 (Thu) 10:14
HDR manualy done -no photomatix, no Merge to HDR chansh Still Life, B/W & Experimental 10 19th of May 2006 (Fri) 14:30
CS2 Merge to HDR (Large Images) chris.bailey RAW, Post Processing and Printing 12 17th of October 2005 (Mon) 20:06
