Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 13th of November 2008 (Thu)   #1
soxfan356
soxfan356's Avatar
Default PS and printing question
When editing a picture for printing do you resize then edit? Or edit then resize?
-Dan
Canon 40d, 28-135 IS, 70-300 IS, 100-400L IS, Sigma 10-20, 430exII
My Flickr
soxfan356 is offline   Reply With Quote
Old 13th of November 2008 (Thu)   #2
Dchemist
Default Re: PS and printing question
I edit first and save the work. Sizing for the print is the last step (after sharpening).
POTN Book Vol4 Astronomy Image Manager and BC Member
20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX
Dchemist is offline   Reply With Quote
Old 13th of November 2008 (Thu)   #3
R Hardman
R Hardman's Avatar
Only thing I do different is sharpen after resizing prior to sending to the printer.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert
R Hardman is offline   Reply With Quote
Old 13th of November 2008 (Thu)   #4
canonloader
canonloader's Avatar
I edit lighting, levels and so on, then resize. Noise reduction and sharpening are last, after resizing.
Mitch- ____...^.^...____
My Microscope Stuff
Gear List, My Flash Gallery, My You Tube, Ride My Bi-Sickle
canonloader is offline   Reply With Quote
Old 13th of November 2008 (Thu)   #5
Damo77
Damo77's Avatar
I echo what the others have said - sharpening must be done after resizing.
Damien
Trying to build a Brisbane retouching, restoration and canvas printing business in the face of a global financial crisis
Check out my Photoshop portfolio, tutorials and articles
, and my blog: The Info Palette
Damo77 is offline   Reply With Quote
Old 13th of November 2008 (Thu)   #6
-Douglas-
-Douglas-'s Avatar
for me it depends on the composition, if I'm not going to use or print any part of a shot, I get rid of it first. Why muck around with all that extra data if it's not going to be used !
Douglas >myGEAR<
"Brain Fart" = an essential bodily function.
-Douglas- is offline   Reply With Quote
Old 14th of November 2008 (Fri)   #7
Lowner
"I'm the original idiot"
Lowner's Avatar
I never resize.
I always have a quick glance at the print resolution, but otherwise its sized in the printer driver. I keep my processed image without output sharpening and exactly the shape the composition needs, if that looses me a half inch of paper here and there so what?
Richard
http://rcb4344.zenfolio.com
Lowner is offline   Reply With Quote
Old 14th of November 2008 (Fri)   #8
Joemt
Joemt's Avatar
From one of the photoshop tutorials I saw, ( I got 1 month free access to ps tuts
on my upgrade from PSE6 to CS3 ), it said the work flow should be:
This is not the to die for order, I don't always follow it, I'm just passing along
what I saw.
1. duplicate
2. size to final dimensions ( changing the resolution, NO RESAMPLING )
3. cropping
4. pattern removal
5. highlight shadow
6. neutrals
7. correct color key ( skin tones )
8. brightness/contrast
9. saturation
10. sharpening
Joemt.
Joemt is offline   Reply With Quote
Old 14th of November 2008 (Fri)   #9
Damo77
Damo77's Avatar
This is the bit I don't agree with. I think it's very important to resize to not only the correct dimensions, but also the correct printing resolution.
As I've stated a thousand times before, good sharpening is entirely dependent on image size.
Damien
Old 15th of November 2008 (Sat)   #10
Lowner
Lowner's Avatar
Damien,
You have far more knowledge than me. Am I wrong then to see what percentage the image is in the printer driver when its the size I want it, then output sharpen based on that?
All my images are 360ppi out of DPP, through Photoshop and final saving. So lets say the printer driver tells me I'm about to print at 120%, I divide 360 by 120 and multiply by 100 which gives me 300. So I use the Pixel Genius 300 sharpening routine. It sounds more complicated than it is in action.
I never save the image after output sharpening, preferring to do it afresh on each occassion.
Richard
Old 15th of November 2008 (Sat)   #11
Damo77
Damo77's Avatar
Yeesh, I wouldn't say that!
I confess I don't quite understand the process you've described, but it certainly sounds like you are applying sharpening specific to size, which is wise, IMO.
Yes, I do the same.
Damien
Old 17th of November 2008 (Mon)   #12
joelham
Ahh im so unaware of sharpening!!! Is this some essential process for printing, do you huys sharpen all your images. Could someone please explain, many thanks
joelham is offline   Reply With Quote
Old 17th of November 2008 (Mon)   #13
canonloader
There are a couple of good ways to sharpen in CS2 and CS3. I use these variations depending on the subject matter. Some work better on one kind of image and not on others. You just have to try them and find what you like. Some, you can do twice, some you can use, then tone it down with the Edit/Fade/ tools. Sharpening is always the last thing to do though, before saving the image, no matter what technique you use.
1. Unsharp Mask. This is simple and effective. Go to Filter>Sharpen>Unsharp Mask. a panel opens with three sliders. Canon recommends using these settings. From the top down, 50.0, 0.3, 0.0. this is a nice subtle sharpening technique that you can set up a quick action for.
2. USM in LAB Color Mode. I use this one when sharpening bird images. It is quite subtle, yet does the job without leaving jaggies all over the place. Go to Image>Mode>LAB Color. Then to the Channels Palette and select the Lightness Channel. Now go to Filters>Sharpen>Unsharp Mask again and set the sliders to 45.0, 0.9, 0.0. Rather than trying to change the numbers, I will run this one twice if it needs more. If that is too much, then go to Edit>Fade Unsharp Mask and this opens a little panel with a slider. Just slide it lower while watching the image preview. Once you are done, then go back to Image>Mode>RGB Color, and your done.
My Microscope Stuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Printing Question SF Lights Canon EOS Digital Cameras 1 27th of October 2008 (Mon) 07:23
Printing question 05Xrunner RAW, Post Processing and Printing 7 14th of October 2008 (Tue) 13:36
Yet another printing question. Bootlegger0173 RAW, Post Processing and Printing 2 28th of January 2008 (Mon) 19:54
Printing question.. dakkon RAW, Post Processing and Printing 3 24th of July 2007 (Tue) 09:15
Printing question turbo212003 RAW, Post Processing and Printing 2 17th of July 2007 (Tue) 16:49
