#1 |
How do you guys actually do your long exposures? I have a 30D and the RS-80N3 shutter release. The other night I thought I'd try 1/2 hour of 30sec exposures while having dinner, and try to stack them using Deep Sky Stacker for star trails.
I set the camera to continuous shooting, when doing long exposures I always use mirror lockup, I set the exposure time to 30secs, pressed the shutter release once to get the mirror up, then again to start shooting and slid the hold button over to continue shooting. I only ended up with the one shot. Did I have too many wines beforehand and forget something or thought I did something but didn't? Or maybe I shouldn't have enabled MLU? Does that stuff the continuous shooting? Do you use the same shutter release method? Or do you have/use the timer one where you can set longer exposures? Or do you have some other way of controlling times and shots? |
| sponsored links |
#2 |
I'm guessing it's mirror lock up, because with that you need to press the shutter twice, but I'm not sure. I did something similar last night, setting the camera going taking 30s exposures, and shot about 200 images, and it worked a treat. (I love this set-up-and-go-away form of Astrophotography!
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam. |
#3 |
Ok, thx. Will do some testing... sober this time.
| sponsored links |
#4 |
Yep, if you use mirror lock you'll need to trip it twice and that means no automated exposures. I have the digital Canon remote. The advantage is setting the exposure time and not having to time it with a watch or keep an eye on the digital counter on the top of the camera. I'd really like a remote control type model for totally hands off triggering but can't justify the added cost.
I bring along a collapsable three step mini ladder that has a bar at the top to hold on to. I place it at the camera end of the rig and loop the release/remote switch and cable around it so that when I trip the exposure I can't tug on the camera and introduce vibration. Just have to remember to unwrap the release before slewing the mount/scope to another target and also watch that as the scope is tracking the remote cable doesn't become tight. I've had the cable get tight before and for a second couldn't figure out why my stars suddenly got really long. (operator error)
Steve Canon Gear: 1D Mark IV | 1D Mark II | 5D | 20D | 500L IS (f/4) | 100-400L My Astro Gallery http://s3.photobucket.com/albums/y67...OTN%20Gallery/ |
#5 | |
#6 |
With the right cable you can automate with the laptop using programs like Images Plus and others. When auto guiding I have to keep a close eye on things which means I'm never just letting the exposures go for long periods of time so this method doesn't appeal to me. I'm a hands on type person and not one to set up the gear to image and go watch television. Half of the fun for me is the actual procedure and the other half is being under the stars. Television has very little of interest to me anymore. It's been trumped by the universe and night/day photography.
I'm not sure how you overcome the mirror lock issue when trying to automate exposures. It's going to require two trigger movements to get the exposure started. Maybe there's something out there that can do this, don't know.
Steve Canon Gear: 1D Mark IV | 1D Mark II | 5D | 20D | 500L IS (f/4) | 100-400L My Astro Gallery http://s3.photobucket.com/albums/y67...OTN%20Gallery/ Last edited by Nighthound : 19th of November 2008 (Wed) at 08:29. |
#7 |
Thanks for your input, guys. So if you're not using MLU, do you find the mirror slap has negligible effect on the shots so is not a problem? Guess so.
@Steve - so your remote is the TC-80N3? I think there are other 3rd party timer remote cables out there. Might research them more. |
#8 | |
#9 |
I'm reading reviews of the Aputure timer remote. Seems to be pretty good, and much, much cheaper than the Canon one. Might be sitting under the Christmas tree for me
#10 |
Cool. I'm surprised how identical it looks to the Canon model. Good luck with Santa.
#11 |
If you've got your camera on a decent support then mirror slap shouldn't be a problem at the sort of exposure times we're talking about. If you're shooting 30s exposures and mirror slap causes vibrations for 0.5s then 98% of the light you're gathering isn't going to me affected.
#12 |
Aah, of course. Hadn't thought about it like that, Frank. Thanks for putting it in perspective.
| Thread Tools | |
| Display Modes | |
| 5D mirror lockup | puttick | Canon EOS Digital Cameras | 5 | 6th of July 2007 (Fri) 22:03 |
| Auso Exposure Bracketing + Mirror Lockup + Self Timer - Continuous drive mode? | chet79 | Canon EOS Digital Cameras | 6 | 9th of November 2006 (Thu) 10:37 |
| Shooting Raw...What settings can be changed after shutter release? | clark220grit | RAW, Post Processing and Printing | 31 | 10th of August 2006 (Thu) 10:42 |
| Mirror Lockup | mdaddyrabbit | General Photography Talk | 1 | 2nd of August 2006 (Wed) 22:46 |
| Mirror lockup and WB help on XT | 2005GLI | Canon EOS Digital Cameras | 5 | 7th of January 2006 (Sat) 18:22 |
