Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 28th of November 2008 (Fri)   #1
twistedinsight
twistedinsight's Avatar
Default Lightroom Question : Archiving edited folders
I know the basics of lightroom, and pretty much enough to do what I need it to do at the moment. I know as time goes by and i have more time to research the many possibilities Lightroom has to offer, I'll find out i'm waisting a lot of time and there's better ways to do everything i'm doing
my question is, let's say I have shoots 1 - 10 that I've delivered prints to the families, and there's no more need for them to be on my computer...but I don't want to lose all the color correcting and post processing to the raws that I have done, but i also want to get them off my drive for space purposes.
What's the best way to "export" this where I can keep the Raws, and also keep the editing done to the raws for archiving purposes?
Thank you!
| Canon 5D mkII | Canon 5D | Canon 70-200mm f/2.8L | Canon 28-70mm f/2.8L | Canon 85mm f/1.2L | Canon 50mm f/1.4 |
Check out my website, and my Blog! Comments are always greatly appreciated!
http://www.jrowephotography.com/
http://www.jrowephotography.com/blog/
twistedinsight is offline   Reply With Quote
Old 28th of November 2008 (Fri)   #2
Victoria Bampton
Victoria Bampton's Avatar
Default Re: Lightroom Question : Archiving edited folders
You can save the settings to xmp files, as Bridge would - but be aware that doesn't keep collections, virtual copies, flags, and a few other minor bits. If you don't use those, it's a convenient option (and a good backup even if you keep catalogs too).
You can export to single-job catalogs, to store with the raw files.
You can transfer to a large searchable 'archive' catalog, again using Import from Catalog.
Those are the main options.
Victoria Bampton is offline   Reply With Quote
Old 28th of November 2008 (Fri)   #3
René Damkot
Moderator
René Damkot's Avatar
I convert the CR2 files to DNG. Then back up both on a different DvD for redundancy .
The DNG contains the edit, the CR2 can be edited with DPP if needed.
Not a huge drama if I loose one.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 1st of December 2008 (Mon)   #4
twistedinsight
Thanks you two! I do appreciate the ideas. That really helps a lot.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lightroom: Moving Folders Problem Obtong RAW, Post Processing and Printing 5 2nd of June 2008 (Mon) 21:16
Lightroom Folders and importing Stefan A RAW, Post Processing and Printing 17 7th of February 2008 (Thu) 08:16
Edited RAWs in DPP showing in Lightroom PhilN RAW, Post Processing and Printing 2 29th of April 2007 (Sun) 16:48
Lightroom Question: finding folders in folder list canoflan RAW, Post Processing and Printing 2 6th of March 2007 (Tue) 12:14
How to save Raw edited setting in Lightroom? PeterWs RAW, Post Processing and Printing 3 6th of March 2007 (Tue) 10:46
