#1 |
Anyone made the jump already
Will LR utilize all 8 logical cores? Will i920 give me a huge leap over say Q6600. Yes I know it's expensive, my family makes sure I am aware of this
Lukasz Drogowski Chicago Wedding Photographer canon MARK III / 5D II / 5d / 24-70L, 50 1.4, 85 1.2 M2, 70-200 2.8 IS, Sigma 20mm 1.8 / 580ex / 580exII / 600ex |
| sponsored links |
#2 |
Light Bringer
I had a look at this not long ago, check out this thread. I suspect if price is no object then the i7 will give you fantastic performance. I know CS4 takes good advantage of the four cores I have, no using them all 100% but using most of them most of the time, so it'll probably use eight cores just as well.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
#3 |
As far as hyperthreading it will not help within one program as it only uses unutilized parts of the cpu from one operation for another operation. So unless you are using a program that does something that LR is not doing there is nothing for those parts to do. So maybe you can compress audio in the background. I found it good in the past for some simple multutasking. If my machine was busy doing a bulk job I could get the browser to be a bit more responsive. The real cores are a different matter.
I wonder how much hyperthreading will help on multicore machines as before with single core machine that sort of thing really was noticable. I have not used lightroom but photoshop certainly spools off enough threads to use 8 cores but some of those threads may be timers or doing something else that take up no cpu time. Next month I will have access to an 8 core machine and will do some sort of photoshop tests to see how may cores are used and maybe how much. I will see if I can find something to graph thread count or something. For photoshop I find memory to be one of the big things that helps my machines. I often work on larger (but not multigig) files so that may be why but even with 8GB of memory my swap files would be 12 GB often. The X58 chipset will handle 24 GB of memory but you would need 4GB sticks of RAM as the motherboards I have seen all have 6 slots and I have seen no 4GB DDR3 RAM yet. 12 GB may be enough for most people though. Everyone has to see for themselves what they can use. DDR2 memory certainly is cheap and some chipsets (P45) can use 16GB of DDR2. I think a balanced machine is best between memory, CPU speed/quantity and harddrive speed. And now video card is getting some attention. That way the machine does not suddenly have to wait for a long time for something like a large file save. Photoshop does use lots of hardware components for sure. |
| sponsored links |
#4 |
Darth Noink
I'm at the point of getting all my parts soon and I'm def. going i7 965. I build my PCs based on gaming and I really love the speed!
Link:http://www.maximumpc.com/article/fea...ls_nextgen_cpu
Phase One IQ260, Cambo, Rodenstock Digaron, Nikon D4 X 2, Nikon D800E, Nikon D800, Nikon D600, and Canon 1Ds MK III. Leica M (Type 240 preordered) |
#5 |
I've just ordered an i7 920 system with 12GB RAM so I'll let you know hopefully sometime next week how it performs with LR and CS4.
As for performance, the benchmarks I've read say that even the 920 is considerably faster than the fastest Core 2 Quad Extreme.
My collection of boxes with holes EXIF semper intacta. Gort! Klaatu barada nikto. |
#6 |
Great !!! let me know. Do you use LR at all? If so, any chance you could time batch export of say 100 raw files into jpgs with the old system and then new?
Lukasz Drogowski Chicago Wedding Photographer canon MARK III / 5D II / 5d / 24-70L, 50 1.4, 85 1.2 M2, 70-200 2.8 IS, Sigma 20mm 1.8 / 580ex / 580exII / 600ex Last edited by drogos : 30th of November 2008 (Sun) at 13:07. |
#7 |
Sure, no problem, I use LR 2.
EDIT: Current system AMD FX60 2GB RAM Windows Vista 32bit Lightroom 2.1 100 uncropped 40D RAW files exported to full size JPEG = 7 Mins 12 seconds.
My collection of boxes with holes EXIF semper intacta. Gort! Klaatu barada nikto. Last edited by HankScorpio : 30th of November 2008 (Sun) at 13:31. |
#8 |
http://tweakers.net/reviews/1024/4/h...-pagina-4.html
This site had a review and a comparison of the two platforms. It's in dutch though, but the graphs says it all. Scores are (most of them) in seconds, so lower is better...
400D, Canon 70-200 f4, Tamron 17-50 f2.8, Canon 50 f1.4, 580EXII |
#9 |
Light Bringer
I'll be very interested to see the results with the i920.
#10 |
Tim, you have Q6600 right ? is it OC'ed or stock. Care to share your 100 files batch processing time? You have 40D too so we would have decent comparison
#11 |
Light Bringer
Already done (2 min 20 sec).. I'm overclocked a little to 2.7GHz for now so the results will be a little faster, nothing huge though.
#12 | |
Intel i7 920 12GB DDR3 RAM (yes 12) Vista 64bit Lightroom 2.1 (for this test, now up to 2.2) The same 100 uncropped 40D RAW files exported to full size JPEG = 1 min 56 seconds. I'm happy. Oh and LR 2.2 did it in 1 min 47 seconds.
#13 | |
#14 |
ASUS P6T Deluxe.
| Thread Tools | |
| Display Modes | |
| HELP..Need Input: iMac C2D or G5 Dual/Quad + LCD | Eaton Photos | RAW, Post Processing and Printing | 11 | 24th of September 2008 (Wed) 12:37 |
| CS3 on the intel macbook pro C2D | col4bin | RAW, Post Processing and Printing | 0 | 20th of April 2007 (Fri) 17:54 |
