Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 29th of November 2008 (Sat)   #1
4130
4130's Avatar
Default Question about 580 zoom/diffuser with crop body
I have an XSi with a 580exii and the 18-55 kit lens. I'm unsure whether to use the built-in diffuser panel with the 18mm end of my lens or not.
I considered that the 580 head zooms down to 24mm coverage, but wasn't sure whether this accounted for my 1.6x crop body, making my 1.6x18mm into 29mm full-frame length.
When I'm using the 18mm end of my lens, do I need to be using the diffuser panel? Does the flash know I'm using a crop body?
Any help would be appreciated.
Looking for a carbon tripod and head capable of supporting a 5D body and 35 mm L
4130 is offline   Reply With Quote
Old 29th of November 2008 (Sat)   #2
Wilt
Wilt's Avatar
Default Re: Question about 580 zoom/diffuser with crop body
The 580EXII has the ability to know when a 24mm FL is mounted on APS-C vs. 24mm mounted on FF body. The 24mm zoom head position (without supplemental lens) ordinarily is for a 84 degree FOV with FF, so it will sufficiently cover your 18mm WA setting when used on APS-C, as that is only a 74 degree FOV (same as 28mm on FF/135 format). You only need to use the supplemental flash lens if using the Canon 10-22mm lens in the 10mm-14mm part of its range.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 29th of November 2008 (Sat)   #3
Curtis N
Master Flasher
Curtis N's Avatar
No diffuser panel needed with that lens on that body. It will cover 24mm focal length on a full frame camera, which is equivalent to a 15mm lens on yours.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 29th of November 2008 (Sat)   #4
4130
4130's Avatar
Thanks very much guys! I hate pulling that thing out when borrowing other people's lenses.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The GREAT top-end walkaround zoom question for Crop Cameras The_Camera_Poser Canon EF and EF-S Lenses 4 30th of August 2008 (Sat) 21:25
dumb question of the day.. define a crop body the_doo2008 General Photography Talk 4 1st of August 2008 (Fri) 14:10
Me again (*sigh*) Crop body question Mum2J&M Canon EF and EF-S Lenses 67 13th of June 2007 (Wed) 11:36
zoom lens decision/conundrum (crop body only, please!) narlus Performing Arts 29 24th of January 2007 (Wed) 14:31
580 diffuser question adammazza Small Flash and Studio Lighting 4 18th of December 2006 (Mon) 11:37
