Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 1st of December 2008 (Mon)   #1
jPadilla
Default custom build advice
edit: we have determined that we will be going with 8gb ram max, changing the mobo and 512mb ddr3 vid card.
i started loosely with the set-up recommended on this thread
http://photography-on-the.net/forum/...t=700+computer
since my comp guy is MIA, i turn to the forum to find some advice.
here is a basic list of what i'm looking at. this comp is going to be used 75% for photo using CS4, the other 25% will be spent doing autocad/sketchup, illustrator CS4, and basic computer tasks.
my original plan was to give me room to upgrade to a fast quad core and 16gb of ram.
is this necessary or even reasonable? keep in mind, i've never actually put together a computer but i am very comfortable around electronics.
in the end, i'm looking for something that is going to be sufficient "out of the box" but gives me room to grow without building a new comp for a while.
budget is not necessarily an issue but i'd like to get it in the 600-700 range.
COOLER MASTER Centurion 534 RC
ASUS P5Q Pro LGA 775
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
Western Digital Caviar SE16 WD5000AAKS 500GB
LG 22X DVD±R DVD
EVGA 512-P3-N956-TR GeForce 9500 GT 512MB 128-bit GDDR3
2x CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 800
COOLER MASTER eXtreme Power Plus RS-500-PCAR-A3 500W
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Microsoft Windows Vista Home Premium SP1 64-bit
after rebates, shipping, tax, picking up the case and a keyboard/mouse locally, this should run right around 600
5DIII~7D x2~canon 24-70 f/2.8L~tamron 17-50 f/2.8~canon 70-300 f/4.5DO~canon 50 f/1.4~canon 85 f/1.8
juiced link audio~zoom h4n~jag35 rig~stage 0 motorized dolly~580EX~calumet genesis and arri lighting
http://jonathanpphoto.com/ http://www.istockphoto.com/Mechanicaleye
jPadilla is offline   Reply With Quote
Old 2nd of December 2008 (Tue)   #2
tim
Light Bringer
tim's Avatar
Default Re: custom build advice
Sounds decent, and pretty good value. I'd get more than one disk. There's a cooler that's meant to be better, but I forget what it's called.
tim is offline   Reply With Quote
Old 2nd of December 2008 (Tue)   #3
OdiN1701
User is banned from forums
OdiN1701's Avatar
Don't get the LG burner - get this:
http://www.newegg.com/Product/Produc...82E16827106282
Same price, also does lightscribe. LiteOn products tend to hold out better than the LG's when it comes to optical drives.
OdiN1701 is offline   Reply With Quote
Old 2nd of December 2008 (Tue)   #4
ChasP505
"brain damaged old guy"
ChasP505's Avatar
I like it. It's almost identical to the system I'm building (parts already purchased and received). I went with 2 of the 500gb HDs, one for a data/scratch drive. I felt I needed at least a 650 watt power supply and newegg.com had an Antec on sale for $49 USD. I second the advice about LiteOn drives. I've used them for years, never a problem, foolproof firmware updates.
Chas P
"It doesn't matter how you get there if you don't know where you're going!"
ChasP505 is offline   Reply With Quote
Old 2nd of December 2008 (Tue)   #5
jPadilla
thanks for the responses team. i appreciate the feedback.
i originally had the liteOn but i don't remember why i changed.
i plan on getting another HDD but i'd like to get something faster and the budget doesn't facilitate that right now. i figure this is enough to get me started.
also, i won't be purchasing for a week or two so i'm sure things will change.
you guys have any thoughts about the mobo? should i consider nvidia S/N bridge or does it matter for photo? i'm not a gamer whatsoever
Old 2nd of December 2008 (Tue)   #6
OdiN1701
OdiN1701's Avatar
Stick with Intel chipsets - they built the CPU's, they know them best. They are in my experience the most stable chipsets, vs. the third party vendors that make them.
Old 2nd of December 2008 (Tue)   #7
BottomBracket
BottomBracket's Avatar
Your build looks good. A few comments:
- The Xigmatek HDT-S1283 is an excellent CPU cooler and I readily recommend it. However it is quite tall and may be a tight fit for the case you are looking at. I have a Cooler Master CM690 and the Xiggie fits with barely enough room to spare. The CM690's width is listed as 8.4 inches, while the case you are looking at has a width of 8 inches. It may fit, but barely. Your options are you can chance it, or change the case or the CPU cooler. A good shorter cooler is the Arctic Cooling Freezer Pro 7.
- If you decide to stick with the Xigmatek, you can do yourself a favor by getting the retention bracket for it. With this it is easier to install than the arcane push pins the Xiggie comes with.
- I like that motherboard. You can pair it up with the nvidia based GPU that you selected. However, I would recommend an ATI GPU, if only to have the ability to Crossfire it with another ATI card should you so decide in the future. You don't really need a Crossfire (or SLI setup for that matter) for photo editing, but having an ATI card on that mobo keeps your options open.
- Don't forget to get a tube of you favorite thermal compound. I use AS5 (Arctic Silver 5) and only because it 's the one I have handy around here. There are other choices, such as OCZ Freeze, MX-2, all good stuff.
Pio
Veni, Vidi, Canoni - I Came, I Saw, I Took A Picture With My Canon
Fotopio.com - Gallery of the Meandering Eye
I am a leaf on the wind. Watch how I soar.
BottomBracket is offline   Reply With Quote
Old 2nd of December 2008 (Tue)   #8
ChasP505
ChasP505's Avatar
For my motherboard, I went with the Gigabyte GA-EP45-UD3P, which uses the Intel chips. I've built a couple gaming PCs with Gigabyte MBs and they rocked!
Chas P
Old 3rd of December 2008 (Wed)   #9
jPadilla
thanks for all the great responses.
the case was just a selection of necessity. i actually plan on picking up a case locally to save on shipping. i'll def keep those dimensions/notes in mind.
i have also looking at this power supply:
http://www.newegg.com/Product/Produc...82E16817182030
as for the gpu, i just need something that is decent enough to do cad work (which i don't do very often as i do it in the office every effing day).
i don't plan on playing games, pretty much ever. and i do very, very light video
thermal compound is on the list of local buys. and the retention bracket has been noted.
Old 3rd of December 2008 (Wed)   #10
OdiN1701
OdiN1701's Avatar
If you want to get a better PSU than the CoolerMaster, then look into Antec, Enermax, or Sparkle.
I wouldn't get the Rosewill.
Old 3rd of December 2008 (Wed)   #11
jPadilla
thanks for the info.
would the CoolerMaster be sufficient for what i've got going?
Old 3rd of December 2008 (Wed)   #12
OdiN1701
OdiN1701's Avatar
It should be fine. They aren't the best brand, but not the worst by any means.
Old 3rd of December 2008 (Wed)   #13
ChasP505
ChasP505's Avatar
Here's the Antec PSU I'm using. It was at $49 when I bought it. Half the price of what it sells for in the big electronics stores, no tax, free shipping.
I can't stand PC components or cases with the dopey blue "bling-bling" lights built in. Seems about half of the PSUs available today have the bling lights.
Chas P
Old 7th of December 2008 (Sun)   #14
jPadilla
so...i've decided to go with this board
http://www.newegg.com/Product/Produc...82E16813128359
for the fsb and 16gb ram capacity
and this psu
http://www.newegg.com/Product/Produc...82E16817371015
i want to get the most for my money but have something that is expandable to last me a few years.
like i stated before, this will be used primarily for photo editing and graphic design, but i also do some architectural design. i'm also entertaining the idea of putting in an hd/blu ray drive and using it as a media center.
i'm kinda lost
Old 7th of December 2008 (Sun)   #15
Motley
and this psu
i'm kinda lost
I would reccomend this power supply is way better for a few more bucks...
http://www.newegg.com/Product/Produc...82E16817703005
Motley is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
QUESTION ABOUT CUSTOM WB & CUSTOM MODES Robertogee Canon EOS Digital Cameras 14 23rd of August 2008 (Sat) 11:47
Build your own PC advice pumbaa The POTN Lounge 34 14th of February 2008 (Thu) 15:27
Can I build a studio? Advice please. Mr O Small Flash and Studio Lighting 13 20th of March 2007 (Tue) 01:44
custom parameter advice needed emtp563 Canon EOS Digital Cameras 4 5th of July 2006 (Wed) 11:39
