Thread started 05 Dec 2008 (Friday) 14:52
Is the 50D not compatable with Sigma 530 DG Super?
flute4peace
Dec 05, 2008 14:52 |  #1
I used these flashes with no trouble on the XTi and 40D, but they are having a terrible time communicating with my 50D. They won't recognize the focal length (just go back and forth), and my recycle time has gone from a couple seconds to at least 15-20 seconds (I've tried multiple batteries in both camera and flashes). Has anyone else noticed this? Canon wouldn't help since it's not their flash, and I haven't had any luck reaching Sigma yet. I really don't want to give up on these flashes since they slave, but they're not usable like this.:(
Thanks.
Curtis ­ N
Master Flasher
Dec 05, 2008 19:01 |  #2
If the recycle time is long, it's not the camera's fault. It's a battery issue.
flute4peace
Dec 05, 2008 19:07 |  #3
Curtis N wrote in post #6821544 (external link)
I tried three different sets of batteries, none made a difference, and both flashes had the problem on the 50 but not on the XTi. I finally got through to Sigma, and they did say this was a known issue. I can take the flash off the 50, put it on the XTi and it'll fire off quick like it always has, but put it right back on the 50 and it's horribly slow. Sigma said to send them in for an update, so we'll see what happens. Apparently I'm not the only one to have called them with this issue. Thanks for the response, tho, I appreciate it.
aymanmb
Dec 19, 2008 17:51 as a reply to  @ flute4peace's post |  #4
I believe I have read somewhere that there is a firmware upgrade to make it working with the 50D.
Check Sigma site
Canon 50D | EF-S 17-55 f/2.8 IS | EF-S 55-250 IS | EF 50mm 1.8 | BG-E2N Battery Grip | 580EX II
flute4peace
Dec 19, 2008 21:52 |  #5
aymanmb wrote in post #6911197 (external link)
Check Sigma site
Yes, I sent them in to Sigma and had them back within a week. They are working properly now.:D
40Dude6aedyk
Dec 19, 2008 21:54 |  #6
If you put your Sigma on your 50D, does the "wireless" menu under "Flash control" become active?
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
flute4peace
Dec 19, 2008 22:01 |  #7
40Dude6aedyk wrote in post #6912486 (external link)
No. It still says "flash not compatible or turned off" in the external flash menu (it does give me the option to change compensation and average/evaluative ETTL), but it does communicate and slave (to a light source). I don't remember if it was the same way with the 40D or not - I can check over the holidays when I'll be visiting a 40 again.
40Dude6aedyk
Dec 19, 2008 22:17 |  #8
Thanks. My sigma on my 40D does not activate the "wireless" menu options, but my 580exII on the 40D does. The sigma does act as a master, but you have use the buttons on the flash to control all the settings (for the master and the slaves). With the 580exII, you can use the buttons on the flash or the menus on the camera.
flute4peace
Dec 19, 2008 22:22 |  #9
40Dude6aedyk wrote in post #6912592 (external link)
I thought Canon flashes didn't slave wirelessly at all without a trigger? (but then I don't know much about Canon flashes, obviously, since I've only got the Sigmas).
The Sigmas will slave to another light source, so I've used one on-camera and one off-camera, or I've also used them as slaves to studio lights (like for a background/hair light). It's pretty slick and for the price you can't beat it.
I've not ever looked into triggering them wirelessly. Intrigued....
40Dude6aedyk
Dec 19, 2008 23:00 |  #10
From reading this forum, it does seem to me that many Sigma owners do not use the full features of their flashes. As an example, I can set the power (1/1, 1/2, ..., 1/128 ) of my remote slave Sigma flash from my 40D camera body or from my 580EXII. I don't have to mess with any of the buttons on the Sigma, just put it in eTTL, C1 SL mode with slave ID 2 and I am good to go. That mode will cover all the manual and eTTL stuff that one would need to ever do.
AirbusA380
Mar 22, 2009 02:08 |  #11
Thanks all. Can't seem to find information on the website, though, 40Dude6aedyk.
When I set my flash to high speed sync, HS doesn't appear in the viewfinder.. Guess I need to return it.
-Dan
Canon 300D | Canon 400D | Canon 50D
Canon 17-55mm f/2.8 IS | 70-200mm F4L | 50/1.8 | 50/1.4 | 85/1.8
exposurecontrol
Mar 22, 2009 15:30 |  #12
The Sigma 530DG Super is not compatible with the 50D. I bought one and had similar problems. I was directed to the Sigma website and it indicated the same. You have to send it in for an upgrade for it to work with the 50D. I sent it back and bought a 430EX II instead. No regrets.
Camera: Canon 50D
Glass: Canon EF 24-105 f/4
L IS ; Sigma 70-200 f/2.8 APO DG HSM;
Speedlight: Canon 430 EX II
BOUNCINGNRG
Jul 08, 2009 12:54 |  #13
Yep, real probs on mine, the zoom head just continually hunts when you half bepress the shutter button and will never fire and when firing the flash at 90 its only ttl and doesn't always fire. Have jst email Sigma, hopefully will have a responce soon.
London Wedding Photographer (external link) ¦ Wedding Photographer (external link) ¦Gear List ¦Photobucket  (external link)¦corporate event photography (external link) 'I reject your reality and substitute my own'
2,560 views & 0 likes for this thread
Latest registered member is johnowens
794 guests, 405 members online
