Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 8th of December 2008 (Mon)   #1
BurBunny
BurBunny's Avatar
Default 86mm Circular Polarizer
George (aka the Sigma "Bigmos" 150-500mm OS) and I are heading back to Antarctica next month. While I hate to cut any of the light coming into the Bigmos, Antarctica literally begs for a CP
Unfortunately, the Bigmos has an 86mm front thread, and I'm having difficulty finding these from the usual sources. HVStar doesn't seem to carry any 86mm CPs, let alone multi-coated. Places like Adorama and B&H have been out of the B&W for quite awhile.
Has anyone used the Sigma EX multi-coated CPs? Any other suggestions I should look at. I don't like to skimp on fileters, but I also don't want to spend $300 on this filter which won't get a lot of use otherwise.
Suggestions on options and locations to purchase?
-Amber
Underwater Photographer (Topside Photography Poseur)
Canon 60D | Canon 400D | Canon 60 f2.8 | Sigma 10-20 | Tokina 10-17 FE | Sigma 18-200 DC OS | Sigma 150-500 DC OS | Canon 70-200 f2.8 IS MkII | Canon 17-55 f2.8 IS | Seatool XTi Underwater Housing | Seatool 60mm Port | Seatool Dome Port | Inon Strobes | 67mm macro lenses (2), Woody's diopter
BurBunny is offline   Reply With Quote
Old 11th of December 2008 (Thu)   #2
BurBunny
BurBunny's Avatar
Default Re: 86mm Circular Polarizer
Really? No one's tried a Sigma EX filter yet? No recommendations at all?
-Amber
Old 11th of December 2008 (Thu)   #3
V8Rumble
V8Rumble's Avatar
Since your crop camera does not use the full element, you can try and use something like a 77mm filter and a 86mm to 77 step-down ring and not get vignetting.
30D | 18-50 EX | 30 EX | 55-250 | 150-500 OS HSM
V8Rumble is offline   Reply With Quote
Old 11th of December 2008 (Thu)   #4
Sean
Sean's Avatar
http://www.bhphotovideo.com/bnh/cont..._86mm&x=62&y=9
These are the ones that B&H have. The heliopans from what I have seen are top notch, except in price. The B+W ones are also good. Lots of multi-coated ones at 86mm. B&H are showing instock on a lot of them as well.
Canon 50D - 17-55mm F2.8 IS - 300mm F4L IS - 70-200mm F4L IS - 50mm F1.8 - 580EX II & 430EX - Full Gear Listing
Flickr - C&C Always welcome.
Sean is offline   Reply With Quote
Old 11th of December 2008 (Thu)   #5
BurBunny
BurBunny's Avatar
Not a bad idea, especially for this trip as I will be using it most likely between 200-500 if history is my guide.
Interestingly, the step down rings for 86mm are really rare. There are some rings that step down TO 86mm, and several options for 82mm-77mm, but neither B&H nor Adorama had what I needed. Only one on Amazon, too... which is now on its way to me. For $10 and change, worth a try.
Thanks for helping me see what should have been obvious
-Amber
Old 11th of December 2008 (Thu)   #6
BurBunny
BurBunny's Avatar
Interesting. Wonder why I didn't get these when I searched for 86mm polarizer. Still, would rather not pay $200+ for this trip if I don't have to... am going to see how much vignetting I get with a step-down ring, and then if need be order an 86mm filter. I do appreciate the link, though, so I can actually find them again if need be, and good to see they have the B+W back in stock, which it wasn't when I searched a few days ago.
-Amber
Old 11th of December 2008 (Thu)   #7
ed rader
"I am not the final word"
ed rader's Avatar
[quote=V8Rumble;6861423]Since your crop camera does not use the full element, you can try and use something like a 77mm filter and a 86mm to 77 step-down ring and not get vignetting.[/quote]
i have an 82mm hoya pro 1 i may be selling so PM me if you are interested. i also have a step up ring so it can be used on 77mm threads.
ed rader
ed rader is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #8
BurBunny
BurBunny's Avatar
Update: Just received the step-down ring and it works like a charm! From experiences with underwater add-on lenses and vignetting, I was actually expecting to see entirely black corners cut off by the filter edge. But instead, just a tad corner darkening which is easily fixed by minor levels of lens correction applied in LR. Hooray!
I tested against blue sky (focusing on tree branches in the foreground), at 150mm, 200, 300, 400 and 500mm. I'm presuming that methodology would be most likely to show up any vignetting if it were going to occur?
Thank you again, Ed, for your offer. However, I'm going to stick with the step-down ring at least for this trip and then re-evaluate after more shooting and trials.
-Amber
Old 17th of December 2008 (Wed)   #9
V8Rumble
V8Rumble's Avatar
What did you step down too? 77mm?
Old 17th of December 2008 (Wed)   #10
BurBunny
BurBunny's Avatar
Yes. I already had a 77mm for use with several other lenses, so it was natural to at least try that for economy.
-Amber
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Difference between Circular Polarizer and Linear Polarizer TriguyTodd Canon G-series Digital Cameras 5 30th of January 2011 (Sun) 15:57
Kenko Pro 1D Circular Polarizer vs. Kenko "regular" Circular Polarizer 0xCAFE Accessories & Storage 1 30th of November 2007 (Fri) 12:22
WTB: 77mm & 86mm Polarizer Seasentinel Classifieds: Buy 0 25th of April 2007 (Wed) 07:40
