#1 |
Decided I really needed another flash for popping out the hair since my favorite models (wife and daughter) have dark brown hair. So my setup for this shot is 580 key with extended shoe connector shooting through umbrella, 430 shooting through umbrella for fill, and a 430 with a snoot from behind to bounce off the hair. No pp on this (because I really don't know how!) as I am trying to learn lighting setup at this time. I am pretty happy with the result- for me- but am sure there is much to learn so would appreciate any suggestions.
Also, I like the way the three flashes can be easily controlled from the LCD on the camera back (40D- everything in manual). It has been helpful for experimentation to not have to adjust each individually on the stands.
Gear: Canon 5D III, 5D and 7D | 300 f/2.8L IS | 70-200 f/2.8L IS | 85 f/1.8 | 17-55 f/2.8 | 24-105 f/4L | 10-22 | Zeiss 35 f/2 | TS-E 24II | Alienbees SmugMug Gallery Model Mayhem |
| sponsored links |
#2 |
Welcome to the forum! I think you did a fine job on this photo....I started the same way with my Speedlites then moved up to AlienBees. The only thing I might try differently next time would be to raise the light w/snoot to be more of a hair lite.
DC~ www.propointmedia.com | Galleries of Work 5DMkII, 40D (backup),grips,Elinchrom Ranger Quadra Head S To Go Set,39" Rotalux Deep Octa,Canon 70-200 IS L f2.8,17-85 IS,85L/1.2, Canon 24-70 2.8L 3-AB800,2-AB400 w/CyberSyncs,Vagabond, Cactus V4 triggers,L-358 meter, QF Trio, Turbo SC. |
#3 |
I like the lighting but the eyes are a bit soft
| sponsored links |
#4 |
Thanks! Should the hair light come more from the top and define less of the sides? I started higher, but found that from the side separated more of her hair from the backdrop. Maybe I need to widen up the snoot more to get more hair?
#5 |
Yeah, I shot this at f/5 and still misfocused the eyes a bit I guess. Should I shoot at a narrower aperature you think?
#6 |
how do you get a snoot on a 430EX?
Eric FJR1300 rider 5D mkIII and 1D MkIII 16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4 |
#7 |
My snoot is just a thin sheet of black neoprene (foamy rubber- think wet-suite) rolled into a tube and taped at the seam. Just slides over the 430 and stays snug due to the stretch of the neoprene.
#8 |
Hmm, exif shows 90 mm so I assume it was your 70-200. I have that lens, f5 should be enough for the eyes and really the whole face. I think you just missed it a little. If you still have the pic on the card, throw it back into the 40d or use DPP to see which focus point you used unless you re-composed...
#9 | |
... just checked the image and focus was locked on the near corner of her nearest eye. I know the 70-200 is a bit soft at the wide end so usually try to use more zoom, maybe this was the problem?
Gear: Canon 5D III, 5D and 7D | 300 f/2.8L IS | 70-200 f/2.8L IS | 85 f/1.8 | 17-55 f/2.8 | 24-105 f/4L | 10-22 | Zeiss 35 f/2 | TS-E 24II | Alienbees SmugMug Gallery Model Mayhem Last edited by Stuart Leslie : 12th of December 2008 (Fri) at 14:22. Reason: (checked the image- update) |
#10 |
I don't know. You know her lips and other parts of her face look pretty sharp, maybe just try some selective sharpening of the eyes. If you have the room you could definitely try backing up and using it at a longer focal length but I would think it should still be sharper. Maybe try one with the ambient lights brighter to get a good focus lock to compare or use a flash light to focus.
#11 |
This lighting set-up is greatly improved over you last post, well done.
#12 |
i like the lighting very much . the eyes could use some sharpening.
Rebel XTI --430 EX ll -nifty fifty 1.8 ,canon 18-55mm kit, Sigma 70-300mm. |
#13 | |||
Thanks everyone for the help.
| Thread Tools | |
| Display Modes | |
| First test w\dual setup 580 & 430 | frenchfx | Small Flash and Studio Lighting | 0 | 26th of June 2008 (Thu) 18:33 |
| Outdoor portraits w/ 580 & 430 | jargaguy | Small Flash and Studio Lighting | 6 | 23rd of September 2007 (Sun) 00:49 |
| Question: 580 & 430 Flash Setups | [AP]Red | Small Flash and Studio Lighting | 26 | 5th of September 2007 (Wed) 12:16 |
| Off Shoe 430 & 580 ?? | Trasmc | Small Flash and Studio Lighting | 1 | 7th of June 2007 (Thu) 17:50 |
| differnces between 580 & 430 | terpam | Small Flash and Studio Lighting | 7 | 17th of June 2006 (Sat) 23:17 |
