Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 11th of December 2008 (Thu)   #1
Junior's G7
Junior's G7's Avatar
Default Cross-post: Anyone know how to rotate a G7 .avi 180°?
Here's the thing: I can pretty easily mount my G7 on a 1" ball from my rear-view mirror, and shoot films of track events, high-speed runs, etc. But the camera would be hanging upside-down.
Is there some software to simply rotate the video 180° after the fact, and if so, do you think the perspective would be weird?
Or is there a way to rotate the image on-board, so I wouldn't even have to mess with software?
Whatcha think, am I out there swinging?
Junior's G7 is offline   Reply With Quote
Old 11th of December 2008 (Thu)   #2
jgrussell
Looking around nervously
jgrussell's Avatar
Default Re: Cross-post: Anyone know how to rotate a G7 .avi 180°?
Piece of cake. Takes a little time (since the entire AVI needs to be resampled), but piece of cake. And the price is right. Go download the free VirtualDub.
-- jgr
blog | gear | my birds
jgrussell is offline   Reply With Quote
Old 11th of December 2008 (Thu)   #3
Junior's G7
Thanks! Already downloaded, found the rotate filter, rotated, saved, and previewed! Works great.
The only thing is, the filesize went from 29.1MB to 414MB. (!!!!) Same frame rate and dimensions, etc. Just much bigger. Any idea how to trim that down?
Old 22nd of December 2008 (Mon)   #4
cctsm
You probably saved as an uncompressed AVI. You need to select a different codec: Video -> Compression. The selection available there by default can be a bit sparse; I suggest getting XviD (I'd suggest h.264, but that's a no-no in AVI files). You can download it at http://www.koepi.info/xvid.html - it's also free.
Also be sure that the audio mode is set to Direct Stream Copy, as you have no need to recompress that.
When it comes to XviD, you do have to pick quality settings and such; that is a science in itself, but just experiment. I would try to avoid shrinking the files much below the original size, at least.
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX
Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads
Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB
cctsm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyone know how to rotate a G7 .avi 180°? Junior's G7 Canon G-series Digital Cameras 4 13th of December 2008 (Sat) 03:23
S230 (IXUS v3) - rotate avi files ? zkosty Small Compact Digitals by Canon 12 27th of May 2007 (Sun) 06:12
ZB Ex: Rotate and Actual Rotate Images TomPhotog RAW, Post Processing and Printing 5 2nd of May 2007 (Wed) 03:27
Convert canon .avi to windows media .avi for use in Adobe kwort Canon G-series Digital Cameras 2 24th of April 2004 (Sat) 06:25
rotate avi from portrait to landscape awood General Photography Talk 1 11th of March 2003 (Tue) 12:16
