#1 |
Hello all, i was wondering if it is possible to put high quality images in videos with primere, because currently the images that i put it are turned to complete crap like you cant see the faces or anyhting... Thanks! BTW i m using primere Pro CS3 I am making a video that has both pictures and video... thanks!
40D :20D: Speedlite 430ex 100-400 F/4.5-5.6 L :17-55 F/2.8 IS :28-135 F/3.5-5.6 IS: 18-55 F/3.5-5.6: 10-22 F/3.5-4.5: 70-200 F/2.8 IS |
| sponsored links |
#2 |
Sure. Just import or drag and drop your JPEG or PSD into Premiere Pro. Then drag it down onto your timeline and adjust the length/duration of the still frame. Then right-click and hit "Scale to Frame" which will resize it to your timeline's res. Then you can scale it or move it around at will.
#3 |
but after i export the video it makes the quality crap again?
| sponsored links |
#4 |
it depends on what you export as. you could export as 320x480 with a low bitrate, and yeah, it'll look crap. if you export 1920x1080 H264 at a high bitrate, it should look good.
#5 |
Oh i found out why... its crap before i render it to the final AVI file i was just looking at the preview! thanks for the help though!
#6 | |
You can scale it in the Effects Control palette, this will keep the maximum quality for your output.
www.eboboo.com Body Mount Supporter for professional photography and videography; Canon EOS 7D, 20D; Canon EF 70-200mm f/2.8L IS USM; Canon EF 24-70mm f/2.8L USM; Canon Speedlite 580EX; Canon XL1s |
| Thread Tools | |
| Display Modes | |
| Backup solutions/stories for your digital images & videos | on da move | Accessories & Storage | 0 | 30th of November 2008 (Sun) 13:37 |
| Full frame vs crop image quality at 100% | danielyamseng | Canon EOS Digital Cameras | 28 | 29th of June 2008 (Sun) 04:06 |
| Full frame vs crop image quality | a_kraker99 | Canon EOS Digital Cameras | 18 | 8th of May 2008 (Thu) 13:57 |
| Full Frame/XTI Quality | sevedd | Canon EOS Digital Cameras | 24 | 9th of October 2006 (Mon) 14:21 |
| Where can I find the full length zuga videos? | ianssln | General Photography Talk | 0 | 12th of May 2006 (Fri) 14:18 |
