Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 16th of December 2008 (Tue)   #1
huntersdad
Default Upgrade or Update?
Been looking at requesting CS4 for Christmas and decided before I do so I should check out the computer requirements for the program. After doing so, I have found that I will need to update the video card and add some RAm. Here's the specificson the current setup:
AMD 3000 2.18 GHz processor
Op Sys - Windows XP
System Memory - 448MB (due to using standard video card)
HD Space - 101 GB
Video Card - VIA/S3G Unichrome IGP
Monitor is a 17" Compaq. CPU is a Compaq SR1030NX. Computer and monitor run fine and really only ever used for Internet, some budgetary work and picture processing.
Is it worth it to upgrade the components or is it time to start looking new?
huntersdad is offline   Reply With Quote
Old 16th of December 2008 (Tue)   #2
tim
Light Bringer
tim's Avatar
Default Re: Upgrade or Update?
New.
tim is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #3
MaxxuM
MaxxuM's Avatar
Ditto... Get something new.
Canon 7D & 60D With Grip's
Canon: EF-S 17-55 F2.8 IS, EF 70-200L F4 IS, EF 85mm F1.8
MaxxuM is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #4
ChasP505
"brain damaged old guy"
ChasP505's Avatar
New... The old PC is certainly still useful for less demanding applications.
Chas P
"It doesn't matter how you get there if you don't know where you're going!"
ChasP505 is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #5
BeritOlam
BeritOlam's Avatar
Definitely new, especially if you want to do CS4!
Memory is going to be a couple generations old in that Compaq, and hence more expensive due to less demand. And even with an upgrade to the memory and gpu, the system bus speeds are still frigid compared to the current crop of computers.
Put it this way -- the cheapest new Dell computer you could buy right now would be a massive upgrade from your current system.
And the cost difference (upgrade vs. new PC) would not be nearly as great as the performance achieved, especially if you remember that you can get a nice tax write off (in the US) for donating that existing computer to a charity.
Blessed are the young, for they shall inherit the national debt. – Herbert Hoover
BeritOlam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
update acc2000 Nature & Landscapes 1 17th of November 2009 (Tue) 13:27
EE 2.02 UPDATE Pekka EE 2 Installation 44 30th of December 2008 (Tue) 06:12
To upgrade or not to upgrade, that is the question... JF1980 Canon EOS Digital Cameras 26 30th of November 2006 (Thu) 09:22
