#1 |
Hi all,
Been taking some pictures today at the daycare of my little one and after loading the pictures into Aperture I noticed that many of the pictures show a yellow gradient. It totally varies from none to useless and it's particularly obvious in stack I got from continuous shooting. It's quite frustrating - about 50% of all the pictures I have taken are useless like that, there are a few that don't show any gradients. I've used two different lenses at the event (35L and 85/1.8), so it's not a problem with a lens (or the filter in front of the lens). I've used a 5D for these shots. Notice how the background (snowmen at the wall) in one pair of pictures varies and the foreground (marshmellows) varies opposingly. The fact that it's gradients indicates to me that it's not simply white balance that's off. Does anybody have any suggestions? Many thanks in advance |
| sponsored links |
#2 |
here's two more examples.
#3 |
Strange.
Looking at your last two, settings are identical. So i can only assume that the camera has used a different point to calculate (auto) wb. |
| sponsored links |
#4 |
could it possibly be a problem with your flash? with the little boy picture.. maybe the flash had a full charge for the first picture and only a partial charge for the second shot..
i may be way off base here .....
7D * 40D/w 24-70 L * 20D*17-85 mm*Canon 100-400L IS *Canon 70-300mm*580EX Anyone who has never made a mistake has never tried anything new. Albert Einstein |
#5 |
No flash is registered in exif.
#6 |
how about florescent lighting would that cause this?
Freeze
#7 |
This is taken under florescent lighting and your shutter speed not being set to a correct value. For best results your shutter speed needs to be a close multiple of the power frequencey. In the USA, this is nominally 60Hz so your shutter speed needs to be one of 1/125, 1/60, 1/30, 1/15.
#8 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
Except that I wouldn't go as fast as 1/125 sec., that's correct. Your shutter needs to be at a speed that'll catch one full cycle of the lamp from peak to peak. If you're at a shutter speed faster than the flash sync, you'll see banding, since the entire frame isn't exposed at one time. If you're between the sync speed and the lamp's cycle rate, you may get "funny" exposures since the instantaneous light level isn't what the meter (which gets an average) saw.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#9 |
you guys are great!!!!
So that's why I see more of the banding in the pictures I took with high ISO (even shorter exposures). Essentially, I should be shooting in manual mode, right? Keeping both aperture and exposure time constant at 1/60. I'll have to try this out again. Thanks so much for the tips. What an eye-opener! Dino |
#10 |
smacks head
Thanks for the info, guys. |
#11 |
I'm so glad they keep this stuff on line forever
This just happened to me this weekend,,, any other thing I can read o this?
Canon 5D Classic, Canon 30D, 70-200L F2.8 IS, 50 f1.4; 28-135 f3.5-5.6; 85mm 1.8; 35mm F2.0, 580EX; 430EX, Assorted Strobist Gear; Novatron 240 Kit; Cybersyncs http://christophermarxphotography.com/ http://christophermarxphotography.blogspot.com/ |
| Thread Tools | |
| Display Modes | |
| Gradient erase? | Jadam | RAW, Post Processing and Printing | 2 | 6th of September 2008 (Sat) 15:21 |
| Yellow tinge in sunny pictures. How do I fix this problem? Filters? | NeoTokyo | Accessories & Storage | 7 | 19th of July 2008 (Sat) 18:56 |
| gradient help | azpix | RAW, Post Processing and Printing | 2 | 6th of July 2008 (Sun) 15:50 |
| problem with canon i560 and yellow tint | one028 | RAW, Post Processing and Printing | 3 | 26th of December 2004 (Sun) 18:34 |
| manual white balance yellow yellow yellow | JS4NARO4 | General Photography Talk | 3 | 26th of May 2004 (Wed) 08:38 |
