Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 17th of December 2008 (Wed)   #1
skifurthur
Default Cropping ratios
Pretty much most of the people who post in PA use a 4 x 6 crop for their photos. Early on I noticed that I tended to compose my shots naturally in a 4 x 5 ratio and went with that, not really noticing that I was going counter to the norm. Recently I have saved a bunch of shots that didn't work otherwise in a 1 x 1 crop ration and some of those are now stellar.
Why do you crop the way you do and why the resistance to alternate cropping ratios?
www.amsaddler.com
Capturing the passion of performance
The "simple and sweet" equipment list: 40D, 7D, 300 f/2.8 IS L, 200mm f/2.0 IS L, 70-200 f/2.8 IS L MkII, 17-55 f/2.8 IS, Canon 1.4 extender
skifurthur is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #2
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Default Re: Cropping ratios
You can almost always get 4:5 out of 2:3 but vice versa can be tough if you shot specifically for 4:5.
I shoot 2:3 with some pad when able and then you do whatever you want with it.
One obstacle to "custom crops" is lack of off the shelf custom mattes and frames.
FlyingPhotog is offline   Reply With Quote
Old 17th of December 2008 (Wed)   #3
narlus
narlus's Avatar
i typically shoot w/o post-crop in mind, so most of the shots i keep in 2:3 ratio...lately i've been doing other crop ratios, though...sometimes a 4:5 or square works best. it really depends on the image.
narlus is online now   Reply With Quote
Old 17th of December 2008 (Wed)   #4
johnstoy
johnstoy's Avatar
My first objective is keeping the *in camera* ratio of 2:3...Those I can crop further if needed, individually...
And 4:5, I reserve for printing enlargements, intended for framing in standard frame sizes... There are no standard 8x12 or 16x24 frames... and Custom frames in those dimensions start at $45 dollars and up, per frame...
Therefore, final prints; 8x10, 11 x 14's and 16x20's, are my choice for framing...
John Stoy
www.poconophotos.com
My Gear List
"Are you only Looking or actually Seeing", from Microbiology 101.
johnstoy is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #5
Dermit
...and then there's the new content aware scaling in Photoshop CS4 which allows you to re-ratio the image by stretching the background without distorting the subjects. It actually works better than I expected it to and have already used it once in a real situation where I shot too tight and the customer wanted an 8x10.
5D, 5DmkII, 15mm, 16-35 f/2.8 II L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX, PW X 5, WL X1600 x 3
http://www.pixelcraftphoto.com
Dermit is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #6
narlus
narlus's Avatar
hmm...interesting feature. but not enough for me to spring the $ and move from CS 3
Old 18th of December 2008 (Thu)   #7
BeckyMax
Cropping gives me a pita every time....if I crop to a 4x5, they want a 5x7. If I leave it at the 2:3 ratio, they want an 8x10. If I try to pad it, it seems like there is a ton of headroom and foreground so I tend to not pad enough. I guess more experience will be my only help.
Canon 5d
Tamron 28-75 2.8, Canon 85 1.8, Canon 70-200L F4 IS
Canon 24-105L F4 IS
9 Silverlake backdrops and 4 Photogenic monolights
BeckyMax is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #8
londonblue007
londonblue007's Avatar
I just got CS3, I'm staying with it for a while.
I frame in camera, then figure out the best crop in PP.
Canon 50D; Battery Grip; Sigma 24-70mm f/2.8; Canon 50mm f/1.8; Canon 430 Speedlight;
website Flickr Facebook
philbondphotography@gmail.com
londonblue007 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Maintaining aspect ratios when cropping Stan Melrose RAW, Post Processing and Printing 24 23rd of May 2011 (Mon) 17:07
Cropping wedding pictures/ratios? freebird RAW, Post Processing and Printing 12 6th of June 2008 (Fri) 01:15
Cropping in bridge (saving ratios) Jonny RAW, Post Processing and Printing 0 16th of May 2007 (Wed) 14:06
Cropping and aspect ratios? Valerie S Performing Arts 2 19th of December 2006 (Tue) 06:01
EX Ratios Harry Settle Small Flash and Studio Lighting 6 30th of March 2006 (Thu) 19:53
