Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 18th of December 2008 (Thu)   #1
mikepack
mikepack's Avatar
Default How was this effect accomplished?
How do you think the following photo effects were accomplished? I'm specifically referring to the stilled subject and the blurred background. Thanks for your input!
http://a883.ac-images.myspacecdn.com...5287c96bf2.png
http://a845.ac-images.myspacecdn.com...f414255e54.png
http://a579.ac-images.myspacecdn.com...2cb5443eb2.png
Canon Rebel XSi
Sigma 10-20mm EX HSM - Canon 18-55mm IS - Canon 55-250mm IS
Canon 430 EX and 430 EX II
Elinchrom Skyport Triggers(2)
Last edited by René Damkot : 18th of December 2008 (Thu) at 15:39. Reason: not the posters image
mikepack is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #2
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Default Re: How was this effect accomplished?
Longish ambient exposure with a pop of "second curtain sync" flash right before the shutter closes...
FlyingPhotog is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #3
mikepack
mikepack's Avatar
Cool thanks!!
Canon Rebel XSi
Old 18th of December 2008 (Thu)   #4
Dermit
...and while the longish shutter is open the photographer is purposely (looks like) moving the camera. In that second pic you can see where the photographer moved the camera in a loop motion.
When doing this you need to keep in mind the amount of ambient hitting the subject. If a significant amount is hitting the subject that you do not intened on having motion blur then you may run into ghosting of the subject. The trick is to set the exposure with a long enough shutter to show motion but the exposure itself is enough to expose the lights for the streak effect, but not exposed to gather any significant light from the subjects. So the lower the light on the subjects the better.
5D, 5DmkII, 15mm, 16-35 f/2.8 II L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX, PW X 5, WL X1600 x 3
http://www.pixelcraftphoto.com
Dermit is offline   Reply With Quote
Old 18th of December 2008 (Thu)   #5
René Damkot
Moderator
René Damkot's Avatar
The correct answers have been given (although I'd use 1st curtain sync instead of second, to allow me to "time" the shot).
I've converted the images to links, since they obviously aren't yours if you're asking how it's done
Please take the time to read the Image Posting Rules: Here
Do not post another photographer's photos without permission from that photographer.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How does this effect look? Asmodeus Transportation Talk 12 26th of October 2008 (Sun) 09:57
How is this accomplished? dmbpettit RAW, Post Processing and Printing 4 3rd of October 2008 (Fri) 14:24
How do you get this effect chrispaulphoto RAW, Post Processing and Printing 13 12th of November 2007 (Mon) 12:02
Remote Web access - How's it accomplished ? Buggbairn The POTN Lounge 11 23rd of June 2006 (Fri) 09:05
