Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Closed Thread
Thread Tools Display Modes
Old 19th of December 2008 (Fri)   #1
Jacc
Default Canon just can't build a good camera? 5D Mark II problems published
Canon acknowledges 5D Mk II's black dot problem
At the beginning of December, users of Canon's new 5D Mark II DSLR have reported an issue with the camera, which produces very fine black dots on the right side of bright spots in images shot at night and at high ISO levels. The dots only become visible if the images are enlarged by at least 100 percent on a monitor or large-format prints are created. The problem was acknowledged by a Canon rep back on December 8th, and as of Wednesday, the company has posted a statement on its Australian support site acknowledging the problem, promising it is looking into the phenomenon to discover ways to "improve and/or mitigate" the issue, according to a Friday CNET report. Some Mark II 5D users have found a workaround to eliminate the black dots, suggesting photographers disable the highlight tone priority, lighting optimizer and noise reduction. The photographer who is believed to have shot some of the very first photos that demonstrated the issue, Stephan Horold, believes the issue stems from different optics used in the 5D Mark II, as the 1Ds Mark III DSLR uses the same sensor and does not have the black dot issue. Horold goes on to say the black dot effect gets more pronounced as ISO levels increase.
Canon also announced it is looking into another 5D Mark II concern regarding vertical banding noise showing up when shooting images in sRAW1 mode. The setting produces file sizes smaller than regular RAW images. Before a definitive fix is found, Canon did suggest ways to eliminate this issue. The company gave users three suggestions that will not produce the issue. They consist of setting the recording format to RAW or JPEG instead, setting C.FN II-3 highlight tone priority to 0: Disable if shooting in sRAW1 or using sRAW2 and setting C.Fn II-3: Highlight tone priority to 0: Disable.
Jacc is offline
Old 19th of December 2008 (Fri)   #2
slitherjef
*burp*
slitherjef's Avatar
Default Re: Canon just can't build a good camera? 5D Mark II problems published
Wow...
Out of all of canon's line up, a couple cameras have had a couple problems and now they can't make cameras?
There don't seem to be anything wrong with my 30D, I have had since about a month after it came out. My 300D worked like it was suppost to, it was my first DSLR. My used 20D has not had any problems. My used Elan 7n has locked up on my 1 time, I had to remove the batteries and kept shooting. Not sure about anyone elses cameras...
Now, I have read about the "black dot issue" and find the issue would be annoying, I don't have a 5DII, but maybe one day I will. Canon should have tested further, but you can't really test everything in every condition. Would I get a 5DmkII if I had the money right now? Probably not, not until the black-dot issue gets figured out and fixed
Personaly, I think canon builds good cameras, though a lot of people think canons QC is slipping.
I shot a Nikon once... it didnt make it
slitherjef is offline
Old 19th of December 2008 (Fri)   #3
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
AE-1
T70
T90 (x2)
20D
40D
5D
No problems of any kind with any of them. Yeah, Canon sux...
FlyingPhotog is offline
Old 19th of December 2008 (Fri)   #4
Lazuka
User is banned from forums
Some people get off on finding any fault with a product, sounds like somebody needs a new hobby
Lazuka is offline
Old 19th of December 2008 (Fri)   #5
mcinfantry@me.com
i have a 5dm2, and i cant get it to happen. canon quality control sucks. they cant even consistently make the camera have black dots...
mcinfantry@me.com is offline
Old 19th of December 2008 (Fri)   #6
TheHoff
Don't Hassle....
TheHoff's Avatar
Thank goodness we have another thread to discuss the black dots!
Originally Posted by FlyingPhotog View Post
AE-1
T70
T90 (x2)
20D
40D
5D
Add the 1DS2 to that... king of all Canon's that I've used.. oh yea 1N ain't bad, either
••Vancouver Wedding Photographer ••| [gear list] | Latest blog: 5 steps to stopping image loss
TheHoff is offline
Old 19th of December 2008 (Fri)   #7
brianch
brianch's Avatar
I don't agree with the OP 100% but to some extent I have realized that over the years Canons quality control has dropped quite a bit. I guess it is simply the higher demand pushing Canon to produce more units. Whether it be lenses are bodies, I see more Canon products come back defective then Nikon products, not a huge difference, but noticeable.
Brian C
brianch is offline
Old 19th of December 2008 (Fri)   #8
FlyingPhotog
Cream of the "Prop"
Oy
The best part is, the first three bodies in my list, still get used. They'll sit for months at a time but drop a battery or two in them and a roll of film and they'll answer the bell...
Nope, Canon can't build 'em to last either...
Old 19th of December 2008 (Fri)   #9
FlyingPhotog
Cream of the "Prop"
How many Nikons might be going back directly to Nikon?
Old 19th of December 2008 (Fri)   #10
Sfordphoto
dang, canon suxxxxxxxxxxxx!!!!!!!!!!!!!!!!!!!!!!!!!!
Gear
Sfordphoto is offline
Old 19th of December 2008 (Fri)   #11
disorder
i think my 5D MKII is fantastic. no complaints so far...
disorder is offline
Old 19th of December 2008 (Fri)   #12
Lazuka
all this talk makes me want to get my Y2K mug out
Lazuka is offline
Old 19th of December 2008 (Fri)   #13
Lightmaster
These posts are getting boring....Any new product can have issues out of the gate...I am one of the "early adopters" of new technology. I have had a 50d ( I know its not a 5d mkII )within the first few days of release and have never had any issues. I have purchased cutting edge products that have had gremlins when received. I for one feel as long as these issues are addressed and corrected promptly I am satisfied. I am very happy with the quality of cameras they produce and hope to one day own a 5d mkII despite all the nit picking going on. If you are not happy you can always sell and goto nikon! LOL J/K (off the soap box...heheh)
Canon 5d Mark II, 24-105L f/4 IS, 50mm 1.8 II, 430 ex II,17" Alienware M17x laptop for photo processing and more...yes, its overkill but I love it!
Lightmaster is offline
Old 19th of December 2008 (Fri)   #14
bomzai
Why can't people just make peace with not having 5D2.
I know you want it but for some reason don't have right now, it doesn't mean that you need to look for every new post on the Net on well known issue. I guess there will be no joy in life for these people after Canon releases next firmware.
Camera: EOS 5D Mark III, S100, ™24-70mm f2.8 VC, EF 70-200mm IS f2.8 L II, EF 100mm IS f2.8 L Macro, Σ 12-24 II.
EOS 5D mkII, 20D, EF 24-70mm f2.8 L, EF 24-105mm IS f4.0 L, EF 70-200mm IS f4.0 L, EF-S 18-200mm IS, EF 100mm f2.8 macro
Light: Sun, Speedlite 580EXII, 550EX, 430EX, EL-Skyports, Reflectors, Umbrellas, Diffusers etc.
bomzai is offline
Old 19th of December 2008 (Fri)   #15
Jacc
Maybe because you would expect 4000$ body only priced camera to shoot without black dots and vertical banding?
Jacc is offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Why won't Canon build a camera body with I.S.? jclaveria Canon EOS Digital Cameras 21 31st of August 2008 (Sun) 11:37
Which CF / SD card is good for the Canon 1D Mark III northfaceboy Canon EOS Digital Cameras 25 15th of June 2008 (Sun) 14:09
A good on camera light for a Canon GL2 video camera?? nat869 The POTN Lounge 2 1st of September 2007 (Sat) 06:50
MkIII AF is great, build isn't too good... basroil Canon EOS Digital Cameras 13 26th of August 2007 (Sun) 12:24
