#1 |
Here are a couple of attempts from Sunday using a 450D and 70-200mm F4. Need some advice if I'm getting it right. I really am struggling with the 450D focusing. Not sure if I have all the settings right.
AF Servo, center spot and center weighted metering. Just had trouble tracking the action. ![]() ![]() Choccy... |
| sponsored links |
#2 |
You've got the hang of your metering (although I normally use evaluative metering) and AF settings it would seem, but you need to learn more about exposure for sports photography. I only looked at your EXIF for the first one, but shooting at 1/1000th, f14 and ISO800 has a number of detrimental effects on your photography.
- Your grain/noise will be more noticeable than it needs to be - Your depth of field is HUGE. You've made the mistake that most people make when they shoot sports photography - thinking that shutter priority is the way forward; it isn't. Shoot in aperture priority, keep your lens wide-open (f4 for the lens you used), and let your manipulation of your ISO keep your shutter speed nice and high. This will retain the ability to freeze the action, but will give you a really shallow depth of field and make your subjects stand out more. As for your images, you should try and shoot from a lower perspective (kneel, or get a little stool), crop your images (or shoot them) with the action as frame-filling as you can get and (in reference to the second shot) try and keep the players faces in the picture, as well as the ball. That said, they're a good start into this rather weird and wonderful world so I'm looking forward to seeing some more, if my advice is useful to you.
2x1D Mk.III, 400 f2.8l IS, 70-200 f2.8l IS, 24-70 f2.8l
#3 | |
Lots of good info above.... I will add shoot tight, very tight and crop tighter. |
| sponsored links |
#4 |
Good stuff ^^^
understand the sport. you mention 'tracking'. there's two things to consider. 1) know where the ball is going - shoot with both eyes open and try to anticipate the movement of the ball/players. (don't forget if there are coaches or players on the sidelines, get their reactions!!) 2) find the *real* players - most of the players are just downright boring. if you're lucky, there's a joker amongst them. find that person and let them do all the work for you consider a monopod and don't be afraid to turn the camera on its side to get the vertical shot. have fun! |
#5 | |
My future debate will be a new body. I would like either a 5DmkII or 1DmkIII with a 24-105mm F4. I know I need more practice and think I've understood where I went wrong so hopefully will get better results. I did notice a lot of OoF shots that seemed quite soft and was not sure if the lens is back focussing at all. I have a friend who is a pro togger so will see if he can have a look at it for me. The lens is still under warranty. Choccy... |
#6 | |
#7 | |
Would also add that using spot metering, which the EXIF indicated, can lead to problems, (for example if you are filling the frame and focusing on a white jersey).
Chris Last edited by cpo13 : 29th of December 2008 (Mon) at 19:08. |
#8 |
My advice for settings (to get you started) would be:
Mode: Aperture Priority (Av) Aperture: f/4.0 Exposure Compensation (Ev): +0.6 (also known as +2/3) Metering Mode: Evaluative (the dot with the circle round it) - for daylight/sunlight. Set the ISO speed to whatever you can get and don't go below a minimum shutter speed of 1/640. I would also give you a piece of advice to "FILL THE FRAME"...by which I mean, crop it to as close as possible around the action. Photoshop Elements will allow you to do this (I think...correct me if i'm wrong anyone). You can also "dial down" the +0.6 exposure compensation in Elements too. It will allow you to ensure you get well exposed photos in post-processing. James.
Hi, my name is James...and I'm here to help Anyone upgrading to a mkIV? Got a mkIII to sell...PM Me! My Gear |
#9 | |
Choccy... |
#10 |
This is something i am looking at aswell, as i noticed most of my pics are about 1/320th and 1/500th and are not pin sharp. I can only presume i am too low on the shutter speed.
#11 | ||
I have, very occasionally gone down to 1/500 but with Premiership and Championship football, you get a bit of ball blur with that low. Quote:
Give it a try with experiments perhaps and figure out what works for you. James.
#12 |
If you're concerned about metering and your light is going to be constant (e.g. under floodlights), get a light meter or take a spot reading from a grey card and switch to 'M' for the duration.
It works. Well, it has for me.
#13 | |
It seems you've got an eye for the action, I'd almost guess you probably played soccer quite a bit, thats a definate bonus. The only other tips I would give are too watch your crops and backgrounds. Is there a reason you didnt crop these tighter?
Bill - Sportsshooter page Canon EOS 1ds Mark III x2, 1D Mark IIIx2, 3x 580 EX II, 70-200 IS 2.8L , 85 1.2L, 50 1.2L, 24-105 IS 4L, 16-35 2.8L, 24-70 2.8L 1.4x ext, 2x ext. 300 2.8, 400 2.8. |
#14 | |
Mike |
#15 |
I had a similar experience recently. However, I took meter readings from different parts of the field and adjusted my shutter speed accordingly to get the best exposure I could, depending on what part of the field the action was in. Granted, this is dependant on being able to get full access to the field/arena to allow this, but if you can, it's worth it.
I was lucky in that the lighting only really varied in the endzones, dropping from 1/500th at ISO6400 and f2.8, to 1/400th at ISO6400 and f2.8. It should have been lower than 1/400th but I wanted to try and freeze SOME of the shots.
| Thread Tools | |
| Display Modes | |
| Anybody shoot football (soccer)... | Steve Greenaway | Sports | 13 | 24th of February 2008 (Sun) 12:22 |
| First time shooting football (soccer) | Hawmaw | Sports | 1 | 29th of August 2007 (Wed) 21:37 |
| My first football/soccer shoot. | paulrus | Sports | 6 | 24th of May 2007 (Thu) 05:08 |
| First time Football (soccer) | gsgary | Sports | 18 | 24th of January 2006 (Tue) 15:48 |
| Tips for Night Time Football (Soccer) Pictures | Spencerj | Canon EOS Digital Cameras | 7 | 20th of September 2005 (Tue) 11:09 |
