Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 23rd of December 2008 (Tue)   #1
[shingo]
Default Need some help with the 430ex ii
Ok, I'm testing my new flash, here's a few sample, all the picture are taken at an exposure time of 1/160 sec, iso of 200 with a F-stop of 5,6 and the focal lenght was 18mm with the ef-s 18-55 is.
The first pic is with the flash at 75 degre, second at 60 third at 45 and the last one is with the flash pointed toward the target.
I have 8 halogen set to the maximum power in this room.
Do you have any advise about exposure time in these kind of situation and also about the iso.
It's really easy for me to take picture without the flash because with the sensor, I know what the picture will look like, but with the flash, it's a hole different ball game.
I think with the flash at 45 degre the result are good.
If you have any tips, it would be greatly appreciated because I'm going to do the christmas picture tomorrow in similar situation.
[shingo] is offline   Reply With Quote
Old 23rd of December 2008 (Tue)   #2
[shingo]
Default Re: Need some help with the 430ex ii
the picture 3 and 4
Old 23rd of December 2008 (Tue)   #3
40Dude6aedyk
Is your flash in manual mode or eTTL mode?
Either way it really doesn't matter that much what your shutter speed is because the flash is shorter duration than 1/160th of a second.
Try this experiment:
Put flash in eTTL mode and as in your pic #4.
Take a pictures now with 1/200th, 1/160th, 1/125th.... I predict the pictures will be virtually identical in exposure.
Take pictures now with 1/160th and change ISO from 100, 200, 320, and 400. I predict the pictures will be virtually identical.
Tell me why I predict what I predict. And what do your results show you.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
40Dude6aedyk is offline   Reply With Quote
Old 23rd of December 2008 (Tue)   #4
[shingo]
Well it was in eTTL and I did try with 1/20, 1/30, 1/40, 1/60, 1/100, 1/160 and 1/200 and they pretty much look the same, I didn't mess with the iso.
I guess the flash compensate with whatever exposure I set if the flash is powerfull enough to do so.
I don't know why, but some time I take a few picture from around the same place and one of them will be really daker than the others. Maybe I just have to get used to the flash.
I guess in most situation it is better to bounce from the roof.
Old 23rd of December 2008 (Tue)   #5
40Dude6aedyk
You got it.
Flash probably did not completely charge enough before that shot.
Yep, but you have no people in the photos you showed. You will probably see a bigger difference between direct flash and bounced flash when you put some people with eyes in there.
Old 24th of December 2008 (Wed)   #6
michillebaker
michillebaker's Avatar
Make your self a DIY reflector. That is what i did and it has worked out wonderfully. Here is the link that I used when making mine http://super.nova.org/DPR/Design .
Not a pro by any means.. Just enjoy taking pics.
Gear: Canon 60D, Rebel XSi; Canon 50mm ; Canon 55-250mm IS ; Flash: Canon 430ex II with diffuser My Just order sigma 18-50mm .
My Photo Blog ; My Actions & Tutorial Blog ; My flickr
michillebaker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Difference between Canon 430EX and 430EX II Flash bigguytf Small Flash and Studio Lighting 7 18th of December 2009 (Fri) 14:06
will a 430ex fire another 430ex? birdfromboat Small Flash and Studio Lighting 6 28th of May 2008 (Wed) 05:39
2(430EX) + PocketWizards OR 550EX + 430EX OR ? Davis Small Flash and Studio Lighting 22 15th of May 2008 (Thu) 15:34
Help with 430EX... alongoria Small Flash and Studio Lighting 2 14th of May 2008 (Wed) 20:52
can i use 430ex as master and another 430ex as slave?if so how..i cant seem to do it. macro junkie Small Flash and Studio Lighting 11 11th of January 2008 (Fri) 10:33
